TotalMedia Theatre 5 - Page 22 - AVS Forum | Home Theater Discussions And Reviews
post #631 of 3744 Old 12-24-2010, 03:42 AM
SamuriHL's Avatar
Originally Posted by dougnliz View Post
Can you point me to some good information on doing this process? I've tried MakeMKV and can't seem to get the MKVs to work right from HDDVD.
Doug
That's what I'm using. MakeMKV. If that's not working for you, then check into Another EAC3 GUI. That will use eac3to to rip the streams and mkvtoolnix to put it together.
SamuriHL is offline
post #632 of 3744 Old 12-24-2010, 06:07 AM
dougnliz's Avatar
I'll give it another try. It's been a while since I've done one. The problem I was having was that I couldn't get the MKV to play the 5.1 audio. But at the time I was using an older HTPC with an older receiver. I now have up to date equipment with bitstreaming.
Thanks for the response.
Doug
dougnliz is offline
post #633 of 3744 Old 12-24-2010, 06:13 AM
SamuriHL's Avatar
Doug
I think in 1.6.1 he updated the HD DVD code, so, yea, give it a try again. I personally play the resulting MKV's with MPC-HC + ffdshow + haali so I get full bitstreaming with even the HD audio tracks. I keep hoping TMT will get updated to handle the same MKV playback that we get with *freeware*. sigh. Some day maybe.
SamuriHL is offline
post #634 of 3744 Old 12-24-2010, 09:53 AM
dougnliz's Avatar
I'm also playing with MPC-HC and ffdshow. I don't have haali installed though. What's the benefit of that?
dougnliz is offline
post #635 of 3744 Old 12-24-2010, 09:54 AM
SamuriHL's Avatar
For me, better control of subtitles.
SamuriHL is offline
post #636 of 3744 Old 12-24-2010, 05:01 PM
dougnliz's Avatar
OKay so I backed up a step and I can't even get 5.1 audio from the HD-DVD ISO. So it makes sense that the MKV doesn't work. But I'm at a loss. Bitstreaming blu-ray works awesome. Why wouldn't HD-DVDs work? I don't have an HD-DVD player on this PC, so I may have to try hooking up my old XBOX drive.
Any ideas why HD-DVD would be different?
Doug
dougnliz is offline
post #637 of 3744 Old 12-24-2010, 07:23 PM
gorthocar's Avatar
Doug
It has been a while since I've tried an HD DVD, but I thought TMT only supported decoding them to PCM, and not bitstreaming them. Is your speaker config setup to be 5.1?
Bazinga!
gorthocar is offline
post #638 of 3744 Old 12-24-2010, 07:40 PM
salacious's Avatar
You are right, TMT has never supported bitstreaming of HD codecs from HD DVD
__________________________
Blu-Rays 100
HD DVDs 65
DVDs 300+
salacious is offline
post #639 of 3744 Old 12-25-2010, 02:33 AM
Davinleeds's Avatar
It did in the original release of TMT3. Use ClownBD for HDDVD to BD and you'll get the audio.
"The purpose of diplomacy is to prolong a crisis." Spock, Mark of Gideon, TOS
Davinleeds is offline
post #640 of 3744 Old 12-25-2010, 05:51 AM
salacious's Avatar
I've been an ArcSoft user since version 2 and I don't ever remember it bitstreaming DTS-HD/TrueHD although I'm getting old and my memory is going
Blu-Rays 100
HD DVDs 65
DVDs 300+
post #641 of 3744 Old 12-25-2010, 05:57 AM
SamuriHL's Avatar
The *VERY* first version of TMT3 ever released had a bug that allowed it to bitstream HD DVD. Unfortunately, it was one of the most unstable builds I've ever seen. So, the tradeoff isn't worth it. Convert it to a blu-ray ISO using ClownBD and then you can mount it and bitstream it with the latest builds.
SamuriHL is offline
post #642 of 3744 Old 12-25-2010, 06:04 PM
Davinleeds's Avatar
It was during the Xonar HDAV 1.3 rein. In the before times.
post #643 of 3744 Old 12-25-2010, 06:54 PM
James Mos's Avatar
Anyone know if there's a setting to stop the sub-control panel from coming up every time I start a movie in TMT5? I haven't been able to find any setting for that anywhere.
James Mos is offline
post #644 of 3744 Old 12-25-2010, 07:40 PM
dougnliz's Avatar
Is there some special way to do this? I tried converting Flags of our Fathers but it keeps giving me an error:
This doesn't seem to be a valid EVO/VOB file.
Is there a specific option I'm missing. Or do I just have a bad disc?
The disc reads okay though. I can play the movie or make an ISO with AnyDVD.
dougnliz is offline
post #645 of 3744 Old 12-25-2010, 08:33 PM
dougnliz's Avatar
Nevermind.... I didn't have AnyDVD running when I was trying to do the conversion.
It seems to be working now.
dougnliz is offline
post #646 of 3744 Old 12-26-2010, 08:08 PM
T.Wells's Avatar
Originally Posted by ArcSoft_Jason View Post
You know, in my suggestion for the whole aspect ratio function I'd included vertical stretch as part of the spec for the basic Stretch function. Effectively, if there were black bars on any axis, it gets stretched to compensate for them.
It was a close call though. I really wondered if people who like horizontal stretch on 4:3 would also like vertical stretch on 2.40:1. It's hard to answer myself because I think stretch is awful to begin with, and it's a tough one to judge without actually seeing it in action.
Ultimately, there was a technical issue and so we kept it to just horizontal for now across all the options and then the manual zoom can be used to compensate for 2.40:1 (though granted, zoom rather than stretch and that might not apply.)
But once that's worked out maybe the auto stretch options will include it.
Jason,
Thank you very much for your response and sorry that I am just getting back to you on this topic.
For those of use with a an anamorphic setup (check the 2.35:1 CIH forum), when using a proper vertical stretch in combination with an anamorphic lens and 2.35:1 screen, there is no distortion at all.
So yes, when one uses vertical stretch on a 16:9 screen on 2.35:1 material, I agree, it look horrible. But our setups use scalded like those from DVDO and Lumagen to perform our vertical stretch. If TMT offered that functionality (stretch not zoom), it would be great.
I hope you can offer this feature in the future.
Kind regards,
T.Wells
T.Wells is offline
post #647 of 3744 Old 12-27-2010, 07:21 AM
dougnliz's Avatar
Well I finally got the conversion to Bluray to work and I still have the same problem. Bitstreaming just won't work. I did change my Windows settings to 5.1 speakers and now I get Multichannel PCM through to the Receiver so I guess I'll just stick with that. I would prefer to have the receiver doing the decoding, but oh well. I only have a few HD-DVDs.
Thanks for the help,
Doug
dougnliz is offline
post #648 of 3744 Old 12-27-2010, 07:26 AM
SamuriHL's Avatar
Doug
Does it bitstream actual blu-rays??
SamuriHL is offline
post #649 of 3744 Old 12-27-2010, 07:45 AM
dougnliz's Avatar
Yeah. No problems there. I get DTS-MA or TrueHD no problems from my Bluray ISOs and MKVs.
This particular HD-DVD (Flags of our Fathers) is Dolby Digital Plus. It seems that particular format has issues. At least from everything I've been reading trying to research this.
Doug
dougnliz is offline
post #650 of 3744 Old 12-27-2010, 07:49 AM
SamuriHL's Avatar
Doug
I've never seen anything bitstream DD+, so, yea, that's the issue. Anything with TrueHD or DTS-HD MA will bitstream once converted to a BD ISO structure.
SamuriHL is offline
post #651 of 3744 Old 12-27-2010, 09:10 AM
andersa's Avatar
Quoted: 36 Post(s)
Liked: 33
Doug
I have the same issue here. I've converted HDDVDs with DD+ to BD but DD+ won't bit stream. I've tried TMT5 and mpc-hc/ffdshow.
/Anders
andersa is offline
post #652 of 3744 Old 12-27-2010, 09:14 AM
SamuriHL's Avatar
/Anders
Right, that's because neither the nVidia or AMD cards support DD+ bitstreaming.
SamuriHL is offline
post #653 of 3744 Old 12-27-2010, 09:29 AM
Paul E. Fox, II's Avatar
So how do you handles those titles?
Paul
Paul E. Fox, II is offline
post #654 of 3744 Old 12-27-2010, 09:30 AM
vladd's Avatar
Liked: 39
Decoded to PCM in software then sent to receiver.
vladd is offline
post #655 of 3744 Old 12-27-2010, 09:33 AM
Ahh...I suppose you have to select that each time for that specific instance?
Paul
post #656 of 3744 Old 12-27-2010, 09:34 AM
SamuriHL's Avatar
Nope. TMT5 detects it and decodes it for you without having to switch. At least if you leave it as an HD DVD. Never tried DD+ in a BD container. No idea what it'd do in that case.
SamuriHL is offline
post #657 of 3744 Old 12-27-2010, 09:35 AM
SamuriHL's Avatar
P.S. Vladd, this is one of the reasons I use ReClock, btw. When decoding to PCM, ReClock will do proper channel mapping and force exclusive mode.
SamuriHL is offline
post #658 of 3744 Old 12-27-2010, 10:15 AM
andersa's Avatar
Quoted: 36 Post(s)
Liked: 33
In my case Intel... but apparently DD+ is not supported by Intel either then...
andersa is offline
post #659 of 3744 Old 12-27-2010, 10:19 AM
andersa's Avatar
Quoted: 36 Post(s)
Liked: 33
In my setup, there is no sound at all by defualt. I have to go into the Settings-Audio menu and change to output to e.g. PCM, DTS or DD.
/Anders
andersa is offline
post #660 of 3744 Old 12-27-2010, 11:26 AM
SamuriHL's Avatar
/Anders
Well that sucks.
SamuriHL is offline
Reply Home Theater Computers
