TotalMedia Theatre 5 - Page 25 - AVS Forum | Home Theater Discussions And Reviews
post #721 of 3744 Old 01-04-2011, 10:19 AM
SamuriHL's Avatar
Originally Posted by dougnliz View Post
DXVA in MPC
Maybe try the ffdshow DXVA decoder and see if it makes any difference.
SamuriHL is offline
post #722 of 3744 Old 01-04-2011, 07:11 PM
Li On's Avatar
hi,
My setup is the Optoma GT720 DLP projector with 720p120 DLP Link 3D playback, ATI HD5570 (passive cool), Win7 64bit, cat 10.11, TMT5. Connection is 5570 DVI-HDMI to GT720 for video, 5570 HDMI-HDMI to Pioneer 23TXH receiver for bitstream HD audio.
For 3D playback, 5570 output 720p120hz to projector, and the projector will automatically switch on DLP Link 3D mode. For playback 2D content, I need to manually switch off 3D mode on the projector.
But few days ago, I tried config 5570 output at 720p60 to the projector for 2D content playback. That way I don't need to manually switch off 3D mode in projector.
But, once I start a 3D blu-ray in 720p60 mode, TMT5 (or the display card) will automatically switch to 720p120hz, and the projector also automatically switch on 3D, since the signal becomes 720p120hz. Once I stop the 3D blu-ray playback, my HTPC will automatically drop back to 720p60hz, and the projector also automatically turn off 3D mode. The whole operation seems very neat!
I never thought HTPC/TMT5 can do this auto resolution change depends on content! Nice!
regards,
Li On
Li On is offline
post #723 of 3744 Old 01-05-2011, 09:28 AM
rinorho's Avatar
Hi,
Has Anyone problems with mkv files?
I'm trying TMT5 and find (but with TMT3, too ):
1) A lot files are not fluid, whereas same files on KMPLAYER work fine
2) Impossible to change audio linguage or to activate subtitles
Playback Blu-Ray disc is perfect!!!
rinorho is offline
post #724 of 3744 Old 01-05-2011, 09:50 AM
SamuriHL's Avatar
1) Are they VC1?
2) Correct, it's impossible at the moment.
SamuriHL is offline
post #725 of 3744 Old 01-05-2011, 11:56 AM
rinorho's Avatar
Originally Posted by SamuriHL View Post
1) Are they VC1?
1) I created them directly from BD (DVDFAB decrypter HD, no compression)
rinorho is offline
post #726 of 3744 Old 01-05-2011, 11:59 AM
SamuriHL's Avatar
Ummmmmm, ok. That's great, but, completely fails to answer my question. I asked if they are VC1...
SamuriHL is offline
post #727 of 3744 Old 01-05-2011, 01:38 PM
GeoZ01's Avatar
Originally Posted by T.Wells View Post
Jason,
Thank you very much for your response and sorry that I am just getting back to you on this topic.
For those of use with a an anamorphic setup (check the 2.35:1 CIH forum), when using a proper vertical stretch in combination with an anamorphic lens and 2.35:1 screen, there is no distortion at all.
So yes, when one uses vertical stretch on a 16:9 screen on 2.35:1 material, I agree, it look horrible. But our setups use scalded like those from DVDO and Lumagen to perform our vertical stretch. If TMT offered that functionality (stretch not zoom), it would be great.
I hope you can offer this feature in the future.
Kind regards,
T.Wells
i hope too that this feature will be included one day.
has anybody here managed to use TMT5 with an anamorphic lens? the window control is as far as i've tested not working, so programs like YXY or ARcontrol are useless at the moment. Any other chance to get this problem fixed?
thanks in advance
GeoZ01 is offline
post #728 of 3744 Old 01-05-2011, 04:57 PM
Davinleeds's Avatar
http://www.arcsoft.com/forum/forum_p...ID=35131#35131
"The purpose of diplomacy is to prolong a crisis." Spock, Mark of Gideon, TOS
Davinleeds is offline
post #729 of 3744 Old 01-05-2011, 05:26 PM
ArcSoft_Jason's Avatar
I know VernD has brought this up before. My understanding from him is it doesn't work and can't be made to on its own or with the 3rd party tools you mention.
It's something I want to look at since he mentioned these are freeware apps but it hasn't reached the top of the heap yet. It's a tough one because we don't have an anamorphic setup at all, so we're pretty ignorant of that particular segment and you guys haven't been noisy enough via customer service to bump up the priority through the official channels. (Not saying you should have to be, but that's the reality of limited development resources.)
ArcSoft_Jason is offline
post #730 of 3744 Old 01-05-2011, 05:42 PM
randalthor's Avatar
I'm thinking about buying TMT 5. For a long time now, I didn't want to buy it, because I was happy going the mkv route. I used Another Eact3to Gui Plus and MakeMKV to make mkvs; and then I'd use mpc-hc to play them back. But then I started running into blu rays with 1080i vc1 video on them. (Darn you British television! /shakes fist/) I can't find a player that can handle playing a 1080i vc1 mkv.
So I've decided that I'll still primarily make mkvs, but whenever I run into a blu ray that has 1080i vc1 video on it, I'm going to rip it to a blu ray file folder. And since TMT is the only program that plays blu ray file folders, it's really my only choice. I wish I had made this decision a couple of days ago when the sale was going on. Oh well. I had a few questions for you guys.
I own AnyDVD-HD, and I plan on having it running in the background, can I expect very few problems with TMT 5? Is bitstreaming working? I have an ati 5870 graphics card hooked up to a Denon receiver. I am currently able to bitstream all of my mkvs. Does TMT 5 play nice with Media Browser? And last and most importantly, do any of you know when TMT 5 will next go on sale again?
"Here on the moon, our weekends are so advanced, they encompass the entire week." Ignignokt from Aqua Teen Hunger Force
randalthor is offline
post #731 of 3744 Old 01-06-2011, 02:03 AM
rinorho's Avatar
but sincerely I don't know if they are VC-1... I created them by DVDFAB. There is a method to check it?
Anyway, now I've the confirm that TMT not support mkv file (a partial support, without all audio tracks and subtitles, equal as NOT SUPPORTED!!)
ARCSOFT MUST be HONEST with the customers... mkv files are not supported!
thanks
bye
rinorho is offline
post #732 of 3744 Old 01-06-2011, 02:27 AM
jong1's Avatar
Quoted: 250 Post(s)
Liked: 199
If you bring up the Information window (right-click, Information) it should tell you. Does for Blu-ray, but I don't use TMT for mkv so I don't know if that is different. If the Information Window does not tell you install MediaInfo
jong1 is offline
post #733 of 3744 Old 01-06-2011, 03:48 AM
magnusr's Avatar
Quoted: 33 Post(s)
Liked: 30
Just reporting a 3D bug in Arcsoft TotalMedia Theatre 5. Test 3D blu-ray: Avatar.
ATI 6950 with Catalyst 10.12. Windows 7 x64. PowerDVD 10 Ultra Mark 2 with latest update. TV: Samsung 63" Plasma with HDMI 1.4.
Ended up with huge black borders when 3D started (image did not fill the entire screen). My 63" was like a 52" lol
The latest PowerDVD 10 Ultra Mark 2 with latest patch was a success and filled the screen correctly
Sound: Dynaudio Xeo 4, TV: LG 55EF950V, HTPC: Intel i7-6700 with GTX 1070
magnusr is offline
post #734 of 3744 Old 01-06-2011, 04:26 AM
balky's Avatar
Quoted: 255 Post(s)
Liked: 171
thanks,
but sincerely i don't know if they are vc-1... I created them by dvdfab. There is a method to check it?
Anyway, now i've the confirm that tmt not support mkv file (a partial support, without all audio tracks and subtitles, equal as not supported!!)
arcsoft must be honest with the customers... Mkv files are not supported!
bye
+1
Compared to what you can get from free stuff it's a bit of a no pride in self pride to claim support for mkv...
balky is offline
post #735 of 3744 Old 01-06-2011, 05:45 AM
cybrsage's Avatar
Liked: 154
thanks
bye
Sure it is supported. Can you play a MKV file and have sound? If you can, then it is supported. Not supported means it will not play. For example, try to use a printer not supported by Apple on an Apple computer.
It is just not 100% full support - which is no surprise given the open and changing nature of MKV.
I will say that support should be far better than it is, though.
cybrsage is offline
post #736 of 3744 Old 01-06-2011, 07:56 AM
SamuriHL's Avatar
thanks
bye
ArcSoft has been quite honest about what is and is not supported. Jason has fully agreed that the support in TMT is not even close to what you can get with a free solution. And as Jong said, use mediainfo. How you create them isn't important. It's what the streams are that matter. I ask if they're VC1 because TMT has a bug that doesn't hardware accelerate VC1 files. And that can definitely cause issues on some machines. I would check the ones that are giving you problems and see what codecs they are.
SamuriHL is offline
post #737 of 3744 Old 01-06-2011, 07:59 AM
SamuriHL's Avatar
It really should at *LEAST* match what we can get from a freeware player. I find it sad that it's getting killed pound for pound on MKV support by MPC-HC+ffdshow. That needs to be addressed at some point.
SamuriHL is offline
post #738 of 3744 Old 01-06-2011, 08:10 AM
tehowell's Avatar
TotalMedia Theatre 5.0.1.86 is released.
NEW FEATURES:
1. Support Intel Sandy Bridge systems
2. Support Aero in Media Center plug-in
3. Add De-noise and Smoothness in Media Center plug-in
4. Support source/drive selection with keyboard in standard UI
5. ATI Catalyst 10.11/10.12 driver support
BUG FIXES:
1. Fix folder path issue for hard-drive content sent to Media Center plug-in
2. Launch Media Center plug-in in full-screen
3. Fix mouse cursor appearing during playback issue
4. Improve AV sync on some platforms
5. Fix no sound issue in some audio switching situations
6. Fix "endless splash screen" conflict with some applications
7. Fix chapter/title UI display issue
8. Fix "update the player" (red screen) error with some discs
Although TMT now opens full screen (without the .lnk workaround), it is still opening on the opposite monitor to 7MC on my two monitor setup (in my office). Not an issue for single monitor setups.
Samsung UN65JS8500 65" SUHD TV FW1455; Yamaha RX-A750BL Receiver FW1.77; Samsung UHD-K8500 UHD BD player, FW1005, w/dual HDMI; one to TV (video), one to AVR (bitstream); Arris DCX-3600M Cable STB; Nvidia Shield Android TV Update 3.2, Server: Windows 10 Home and Emby Server.
tehowell is offline
post #739 of 3744 Old 01-06-2011, 08:16 AM
Erighan's Avatar
Quoted: 14 Post(s)
Hey all, quick question.
Can TMT 5 be integrated with MediaBrowser with regards to playing VOB files through folder structure?
I can get TMT 5 to play sDVDs via folder structure by manually playing the video through TMT 5, but when I try to play through MB, TMT 5 launches but does not play the video.
I selected the MC version of TMT 5.exe in the MB external player tab and believe to have setup the other options as well. However, no matter what I change, I just can't get things to work. Are there parameters to set? If so, what are they?
I've browsed the MB forums and came across a few posts where people commented on the "buggyness" of TMT 5.
Erighan is offline
post #740 of 3744 Old 01-06-2011, 09:08 AM
RocShemp's Avatar
Quoted: 12 Post(s)
I just noticed something last night. I can't find the dynamic range options on TMT5. I always would set them to off on TMT3 but I don't even see the options in TMT5. Where are they?
NEW FEATURES:
BUG FIXES:
Tried it with my most extremely problematic disc (Kick-Ass, not that any were preoblem-free just that this was the worst) and it played without stuttering.
However, although I got audio from the main Lionsgate logo (when the disc first loads), the main menu and the actual feature remained silent. I had to use ReClock to get audio. Still, it's a vast improvememnt from how it was before.
RocShemp is offline
post #741 of 3744 Old 01-06-2011, 11:15 AM
rinorho's Avatar
Windows information showed me:
VC-1
1920x1080 13-50 Mbps
DTS
I don't agree with cybrsage. Video shuttering is very frustrating experience, besides more frustrating is to hear all the movie in other language without subtitles possibility. Sorry, I can call THIS, "Not supported", simply.
At the moment, TMT for me represents the best way to playback Blu-ray Disc or Blu-ray stream from the folder. It's fantastic, but mkv files playback is other thing.
Thanks to all
bye
Rino
____________________________________________________________ ____________________________________________________________ _______________________________________________
Asrock X58 Extreme 3 - i7 950-Noctua nh-c12p se14 - Asus ENGTS450 -Techsolo Tc-380 modded-3x2Gb XMS3 1600 CL8-Mitsubishi HC 3800-Yamaha RVX 1200 - Infinity Delta 60-Yamaha YST-SW300
rinorho is offline
post #742 of 3744 Old 01-06-2011, 11:31 AM
SamuriHL's Avatar
VC-1
DTS
Thanks to all
bye
Rino
Right, ok, the reason I asked about VC1 is that for some stupid reason TMT (both 3 and 5 afaik but I haven't tested with the new build of 5) have a bug where VC1 in an MKV is not hardware accelerated. That's what's happening to you almost guarnateed and why you're getting stuttering. It's not that it's not supported, it's simply that it's a bug. Not sure if it's fixed, but, you can try again with the new version and see if that takes care of it. I agree, that the support needs to VASTLY improve. It's why I don't use TMT5 for MKV's, myself. I would if it would at least come up to the level of MPC-HC+ffdshow. So far, that's not the case.
SamuriHL is offline
post #743 of 3744 Old 01-06-2011, 12:50 PM
Mopar_Mudder's Avatar
Quoted: 27 Post(s)
Liked: 37
VC-1
DTS
Thanks to all
bye
Rino
Just curious as to why you are using MKV? I know you said that your ripping with out using and compression so why not just leave them in a folder format and save a whole lot of troubles?
Mopar_Mudder is offline
post #744 of 3744 Old 01-06-2011, 03:11 PM
rinorho's Avatar
For mkv files, I use Zoom Player with Matroska Code Pack, but there are others players to read correctly this format files...
@ Mopar_Mudder: I think that mkv format file is the most efficient way to backup a main BD part, with multi-audio and subtitles. There are too few players able to read BD format from folder (probably only TMT efficiently).
You can find many resources in mkv format in the web...
bye
Rino
rinorho is offline
post #745 of 3744 Old 01-06-2011, 03:57 PM
Wo0zy's Avatar
I just did the .186 update and have two problems so far.
1. The Information Center still tells me a patch is availale even though it's installed. I seem to remember the same thing happening at some point in TMT3. Minor issue but needs fixing.
2. In the MC player if I untick the box in settings to force Aero on BD playback doesn't start. It just sits at the front screen. If I tick to disable Aero then playback starts just fine. Anyone else tested this yet?
Haven't tested to see if the patch helps with the Reclock issue. That's next
Edit: Same issue with Reclock. Had a feeling that'd be the case.
Wo0zy
Wo0zy is offline
post #746 of 3744 Old 01-06-2011, 03:57 PM
This bug has not yet been addressed. I'm not sure it's specifically that HWA isn't working as I see CPU usage variation between HWA on/off, and a CPU fully capable of software decoding can't play it correctly either. There's definitely a problem dealing with a VC-1 video track inside an MKV created by MakeMKV, but the exact nature of it remains a bit of a mystery (to me.)
post #747 of 3744 Old 01-06-2011, 03:59 PM
Already being worked on.
Does the same thing work okay in the standard UI? Some environments just don't like Aero rendering at all and other perform badly. (That's why the default is to drop out of it.)
post #748 of 3744 Old 01-06-2011, 04:01 PM
SamuriHL's Avatar
Thank you for the clarification. I didn't realize it was a more complex issue. I hope this can get addressed at some point.
SamuriHL is offline
post #749 of 3744 Old 01-06-2011, 04:09 PM
Wo0zy's Avatar
Cool. Thanks Jason.
Aero enabled works just fine in the standard UI.
This is a system with an ATi 4670. I'm running the 10.12 drivers ATM. Updated from 10.9 just before patching TMT.
Cheers,
Wo0zy
Wo0zy is offline
post #750 of 3744 Old 01-06-2011, 05:43 PM
gorthocar's Avatar
TotalMedia Theatre 5.0.1.86 BUG FIXES:
Though this is improved in 5.0.1.86, this isn't fixed for me. While watching a DVD on my Core i5 system, there were multiple times when the mouse cursor spontaneously appeared without the mouse moving, but then it would hide it after a second.
Bazinga!
gorthocar is offline
Reply Home Theater Computers
