HTPC Software, That Works For Me - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-28-2010, 03:23 PM - Thread Starter
Digit9's Avatar
I'm looking for some HTPC software that will allow me to do ALL the following:
Portable (being able to keep it on a flash / external drive with all my movies)
Pulls up IMDB information (including art, actors, genre, etc. Would be nice to have it cached so I don't need internet everywhere I go to get it)
The ability to search / navigate by actors, genre as well as title)
Multiple formats (xvid/avi, mkv, mp4, wmv)
Multiple folders (for both movies and TV shows)
Low-ish resources (less memory, more video)
Stuff I would like, but not needed:
Plugins (Pandora would be nice)
Minimal easy to read interface (or the ability to add themes)
Does NOT need a TV tuner function or any DVR type functions. Is there any software out that can meet my needs? I've looked up a bunch of different software but none seem to have what I need.
Digit9 is offline
post #2 of 6 Old 10-28-2010, 05:36 PM
shadymg's Avatar
im not sure about the IMDB part...but you might want to check out something like KnoppMyth, the Linux MythTV port which runs 100% off of a CD. Depending on your skillys, you can even customize it some.
_________________________
Mike Garcen
Media Center MVP
MissingRemote.com - The Home for Home Theaters and HTPCs - Reviews, Blogs, Forums & More | Twitter @missingremote
shadymg is offline
post #3 of 6 Old 10-28-2010, 09:59 PM - Thread Starter
Digit9's Avatar
The IMDB part is a huge must though. Also, I'd kind of want something that I can launch straight from my flash drive.
Digit9 is offline
post #4 of 6 Old 10-28-2010, 10:18 PM
ilovejedd's Avatar
Quoted: 76 Post(s)
Liked: 67
XBMC? I seem to recall it having a portable mode.
ilovejedd is offline
post #5 of 6 Old 10-29-2010, 03:47 AM
Servicetech571's Avatar
Media Center Master will download the metadata and put it into folders.
Servicetech571 is offline
post #6 of 6 Old 10-29-2010, 05:35 AM
aphillippe's Avatar
XBMC does everything on the list, out of the box.
-Just set it up in portable mode during installation, point the install folder to your portable hdd and away you go.
-XMBC scans all source folders, scrapes info from your chosen scraper (including IMDB) and sets up a movie/tv library, saving the info locally.
- You can navigate the library by the above, plus you can set up smart playlists that filter by age rating, resolution, all sorts.
-I've never found a file (that wasn't corrupt/broken) that it didn't play.
- You can add as many source folders as you want. these can be set as movie or tv episodes. The files need to be named in a way that the scraper can recognise but most library based systems will need this anyway.
- They are getting there with gpu decoding. It depends on what you mean by low-ish resources. I run XBMC on a low power athlon 4450e and it's fine with 720p. GPU decoding is needed for 1080p. The user interface is fine either way.
hope that helps
aphillippe is offline
Reply Home Theater Computers
