Yamaha RX-A1000 Computer Blu-Ray Player Sound Intermittent - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-06-2010, 10:13 PM - Thread Starter
2muchtrublshoot's Avatar
I did not have this problem until I got this new receiver. When playing blu-ray discs, the sound stops frequently for about 3 seconds, then starts again. When the sound stops, the receiver display changes from DTS to Decoder Off. Additionally, it does it at the same place in the movie every time. It happens during both action scenes and during low volume scenes. I am running an optical digital cable from my computer's Gigabyte motherboard to my RX-A1000. I also have a new LG blu-ray drive.
Any help would be greatly appreciated.
2muchtrublshoot is offline
post #2 of 4 Old 05-29-2011, 07:24 AM
dosster-avs's Avatar
Had similar problem with ripped mkv files from USB HDD plugged into my S580. Called Yamaha today [got an answer on Holiday weekend Sunday at 9:20 a.m. EST!! That alone makes me glad I chose Yamaha]. Tech had me select PCM output on the BD player, all is well. 5.1 works and sounds great. Wonderful in Pure Direct mode.
dosster-avs is offline
post #3 of 4 Old 05-29-2011, 12:50 PM
audit13's Avatar
Quoted: 37 Post(s)
Liked: 33
What OS and software are you using the playback the files?
Have you tried different hdmi inputs on the receiver? Try another hdmi cable?
audit13 is offline
post #4 of 4 Old 05-30-2011, 05:05 PM
Mondo Rock's Avatar
What about other lossless codecs? E.g. DTS-MA? Dolby TrueHD?
Mondo Rock is offline
Reply Home Theater Computers
