How can I convert a movie with 24 FPS to 60 FPS? - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #1 of 52 Old 11-12-2010, 03:41 AM - Thread Starter
deepdeep1's Avatar
I heard there was software that can convert a movie from 24 FPS to 60 FPS
to get a smooth, clearer Image
Anyone know
deepdeep1 is offline
post #2 of 52 Old 11-12-2010, 03:54 AM
8:13's Avatar
there's a thread called avisynth framedoubling. search for that. one of the replies links to a guide.
There is new, and then you are new.
This is a moral of the bears and their cereal.
8:13 is offline
post #3 of 52 Old 11-12-2010, 04:24 AM - Thread Starter
deepdeep1's Avatar
Where exactly can not find?
post #4 of 52 Old 11-12-2010, 07:06 AM
rplotkin's Avatar
Converting 24p to 60p will not produce an image that is more clear or more smooth than the original.
First, clarity has nothing to do with frame rate.
Second, 24p to 60p introduces jitter, a phenomenon where frames that *should* move smoothly cease to do so (most noticable in smooth pans). This is because 24 does not evenly divide 60, so in converting 24 to 60, some frames are doubled, and others are tripled.
If you want better image quality, the adjustments should be made to your TV. If you are going from a standard def source to a high def TV, then you can also improve image quality (including clarity) with a good scaler (search the video processing forum).
If you want a smooth picture from a 24p source, you need a TV that will refresh at some multiple of 24 (sometimes that is 48Hz, other times it is 120Hz; the latter is divisible by both 24 and 30 (and 60), making it ideal for all sorts of viewing).
rplotkin is offline
post #5 of 52 Old 11-12-2010, 08:22 AM - Thread Starter
deepdeep1's Avatar
HI
CyberLink PDVD Studio versio this playr for Movies
this player can Turn movies from 24/25/29 fps to 60/75 FPS! on line
and Clean fixer FPS
( the player not Sold to Private Clients )
Example :
http://img43.imageshack.us/img43/4167/70018273.png
http://img199.imageshack.us/img199/8519/86572919.png
Where to get this player?
post #6 of 52 Old 11-12-2010, 11:16 AM
vladd's Avatar
Liked: 39
I'm pretty sure there is no such thing as "Cyberlink PowerDVD Studio". That looks like PowerDVD 10 (which you can purchase from Cyberlink's website) with extra DirectShow filters playing an MKV rip. Notice the Haali and ffdshow tray icons at the bottom of the screenshots and the PowerDVD window is showing that it is "File Mode".
vladd is offline
post #7 of 52 Old 11-12-2010, 12:13 PM
babgvant's Avatar
Liked: 30
Not sure why anyone would want to permanently burn pulldown into a file. Anything that makes up information is going to mess up playback.
babgvant is offline
post #8 of 52 Old 11-12-2010, 12:36 PM
8:13's Avatar
Poster named "Subjunk"
8:13 is offline
post #9 of 52 Old 11-12-2010, 01:11 PM - Thread Starter
deepdeep1's Avatar
I found a link to the software and it works excellent software
Call:
PDVD WITH TAZN filter. Rar
Put the file name in Search Files:
post #10 of 52 Old 11-12-2010, 01:15 PM
vladd's Avatar
Liked: 39
How about purchasing it from http://www.cyberlink.com instead of pirating it. The TAZN filter is included with PowerDVD (Ultra version anyway). I suggest you edit your post before a moderator sees it.
vladd is offline
post #11 of 52 Old 11-12-2010, 01:19 PM - Thread Starter
deepdeep1's Avatar
Originally Posted by vladd View Post
How about purchasing it from http://www.cyberlink.com instead of pirating it. I suggest you remove your post before a moderator sees it.
i Sorry no
this software Never sold to the public !
this software Never Gave to the public in the world
only to Number of participants for an impression.
This program has never been in the company website .
Even after a year I would turn the company customer service about this software
his software Was distributed free in my country and in "forum" in my country
for the customer's impression and than i customer turned with questions and problems to the manufacturer of this software :
http://www.cyberlink.com/products/po...iew_en_US.html
The TAZN filter is not included
As here
post #12 of 52 Old 11-12-2010, 01:22 PM
vladd's Avatar
Liked: 39
Your link is bad. And if Cyberlink gave it to a limited number of people, I'm sure that it was not meant to be release to the general public, so it's still pirated. Cyberlink does allow free trials (posted everywhere) but they expire.
CyberlinkUSA can correct me if his company is ok with it being shared.
vladd is offline
post #13 of 52 Old 11-12-2010, 01:29 PM - Thread Starter
deepdeep1's Avatar
Your link is bad
what bad ?
Someone forced you to use the software?
you Not even seen it at all
There is also a request that if you benefit from the option tazn write to Cyberlink
yes CyberlinkUSA can correct you
post #14 of 52 Old 11-12-2010, 01:38 PM
vladd's Avatar
Liked: 39
what bad ?
No, "bad" as in I click it and it does not go to anywhere.
I won't hold my breath waiting.
With PDVD 9 and 10. Here's a screenshot of it listed in GraphStudio ("Tzan" not TAZN):
vladd is offline
post #15 of 52 Old 11-12-2010, 02:03 PM - Thread Starter
deepdeep1's Avatar
click on what ? Do you even download the software ?
hold your breath
You're wrong all the time,
this Tzan FILTER here converts to 75 FPS
Tzan in 9 or 10 not doing anything
I'm sorry I can not be Bibi Sitter
post #16 of 52 Old 11-12-2010, 02:47 PM
aldo37's Avatar
I hate bibi's . They burp alot.
aldo37 is offline
post #17 of 52 Old 11-12-2010, 05:44 PM
vladd's Avatar
Liked: 39
The link you posted:
And no I didn't download the software. I own legal copies of PDVD and I will stick with them rather than use some random illegal copy from the web with no idea where it originated.
No idea what it does. You said that it did not exist and I've shown that it does.
Lol. Welcome to ignore.
vladd is offline
post #18 of 52 Old 11-12-2010, 10:46 PM - Thread Starter
deepdeep1's Avatar
Again you are a bit rude
I do not work for you! or your slave !
I do not owe you anything!
you want to see the world's best software, great
look for the Software alone
If you run the software you see the difference and what can be done !
I brought pictures above show an increase of FPS
You do not bring anything !!!
you can see the fps 70.44 fps and 47.7 fps
If PDVD 10 does it so bring photos
If you have these options bring picture you little girl
If your software pdvd 9/10 does not do it
poor creature" vladd" don't come back to my Threads !
As you said you have no idea what the software do !
girl again i am not your Bibi Sitter
http://img203.imageshack.us/img203/790/98758280.png
look in this Picture why PDVD takes 500 MB?
Is your software takes 500 MB?
post #19 of 52 Old 11-12-2010, 11:06 PM
pupsin's Avatar
If you don't want to look like a complete jerk, I would suggest not insulting people that were trying to help you. And, when you pirate software it's stealing from the developer, so you wouldn't like it if I came and stole your computer would you?
pupsin is offline
post #20 of 52 Old 11-12-2010, 11:45 PM - Thread Starter
deepdeep1's Avatar
trying to help you.
Help me on what ?
Read the nonsense written by you
pupsin=vladd
Again you lie I did not steal anything
you write I stole !
you have evidence ?
Watch out for a claim against you !
pupsin=vladd
You threaten to steal my computer?
This criminal
People pay money in court on such threats!
post #21 of 52 Old 11-13-2010, 12:39 AM
vladd's Avatar
Liked: 39
Originally Posted by mariner888 View Post
Greetings vladd.
Do you know what the TAZN filter is supposed to do?
Here's a link to the [link removed] taken from doom9 if you would like to play with it.
Best regards.
From what I'm seeing, it's supposed to increase convert the FPS of movies to 60 or 75. I have no real interest in trying it. 75 FPS is worthless to me and you're most likely better off using standard on-the-fly pulldown conversion when necessary. As babgvant mentioned, burning that conversion into a file is not the best method. That and I'm not really interested in overwriting my legal copy of PowerDVD with an illegal one.
If anyone can prove to me it's not an illegal download, I'd be happy to try it but the fact that it can only be found on known warez sites has me more than suspicious.
As I previously mentioned, the filter is already available in legal PDVD versions (but named "Tzan" not "Tazn") but there seems to be no way to utilize it or to set the properties. It's possible that the original uploader, figured out how to do that, modified the binaries and repackaged it.
vladd is offline
post #22 of 52 Old 11-13-2010, 02:41 AM
vladd's Avatar
Liked: 39
This version of the Tzan filter was actually available to retail customers. I found a backup of my PowerDVD 8 Ultra (build 1531) and registered the filter. Sure enough, I was able to use it in GraphStudio and change the properties.
I still don't see it being much use though, all it did for me was increase judder. Granted, this was on a 1080p m2ts. It may work better on non HD sources like a DVD.
From the looks of it though, one of the options seems consistent with the TheaterMode options in PowerDVD, so it's possible that this filter is used for TheaterMode processing.
vladd is offline
post #23 of 52 Old 11-13-2010, 03:24 AM - Thread Starter
deepdeep1's Avatar
http://www.downloadatoz.com/dvd-vide...erdvd-8-ultra/
http://www.filecrop.com/serial-Cyber...-8.0.1531.html
http://www.downtr.net/12866-cyberlin...531-final.html
1. What is your version of the 3 types?There are lots of online versions?
2. How many MB is considering software?
3 CPU What model exactly
4. Which cable you have exactly? Full Model
5. Screen a precise model
6. Operating system which model?
How did you change GraphStudio for what?
Because you don't opening process filter TAZN
do you open protocol for filter tazn ? and how ?
you open the booklet to operate filter tazn ?
You are wrong again
No connection
No connection
post #24 of 52 Old 11-13-2010, 06:44 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
@mariner888: Why do you have to use this particular hacked PowerDVD 8 as if only this version supported conversion to 60/75 fps (apart from the possible reason that you [I mean generic "you"] may not own a retail copy of PowerDVD 8)? The retail PowerDVD 8's Tzan filter works too (I tried both), as vladd wrote.
Anyway the Tzan filter (from either the retail or hacked PowerDVD 8) works in any (?) DirectShow player without a major issue (judder-free or not is another subject). The splitter used is LAVFSplitter v0.11. CPU usage is high (~75% with Q6600). ReClock/EVR reports:
1080p24 MKV ripped from BD movies:
Convert Type ReClock EVR
Bypass 23.976 fps ~24 fps
30 fps 23.976 fps ~24 fps
60 fps 59.940 fps ~60 fps
75 fps 71.928 fps ~70 fps
("No video stream found" in the picture may be atypical.)
480i60(fields) MKV ripped from NTSC DVD movies:
75 fps 75.000 fps ~70 fps
Here is a potential issue: you have to change "Convert Type" from "Bypass" to the fps you like *each time* you play a file (precisely speaking each time a filter graph is created) by opening the CyberLink Tzan Filter Properties (there is no registry value to keep the change). So this method would be practically useless for some (at least outside PowerDVD).
BTW the Tzan filter from PowerDVD 9/10 lacks the "Settings" tab in the Properties, so it is out of control outside PowerDVD.
renethx is offline
post #25 of 52 Old 11-13-2010, 11:37 AM - Thread Starter
deepdeep1's Avatar
Which version you have ?
Which cable you have exactly? Full Model ?
Q6600 Not a good CPU no for software
apart from the possible reason that you may not own a legal copy of PowerDVD 8
Enough with the nonsense my software is legal !
You know my software? You know the model? Weight in mb ?
The software no converts " mkv " to 60 or 75 fps ( what the Code )
sorry you don't have Working model
You do not have the booklet to run "tazn filter "
sorry you don't have Working model for "tazn filter "
This means that your software is not illegal for tazn filter
BTW the Tzan filter from PowerDVD 9/10 lacks the "Settings" tab in the Properties, so it is out of control.
Like I said before "tazn filter " does not work on PDVD 9 or 10
Was an attempt by the company's engineers to provide a weak version in pdvd 9
It was a shame and failure that pdvd did not do anything with "tazn "
It was intended for weak computers
Therefore not published PDVD 9 this option ( tazn )!
Look at your Manual not a word on TAZN why?
post #26 of 52 Old 11-13-2010, 11:46 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Originally Posted by Andy o View Post
it does seem that the Dunning-Kruger level is high on this one.
Yup, everybody is confirming this again.
Example :
Tzan failed to convert to 60 fps in this example??
renethx is offline
post #27 of 52 Old 11-13-2010, 12:20 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
OK, after watching several MKVs in a 60Hz display, I can see the effect of Tzan (overall much smoother motion). Thanks for reminding us of another option, deepdeep1.
renethx is offline
post #28 of 52 Old 11-13-2010, 12:22 PM - Thread Starter
deepdeep1's Avatar
Example :
with version TAZN works and analyzes depth
YOU need video card Strong
with 6870 hd you can get 60 FPS It takes a 60-120 second to to get 60 fps
( You have to remember this movie over 10MBPS+ )
FRAME SCALE X4 - It takes more strength from cpu
Requires a very strong video card in sli or CrossFireX
post #29 of 52 Old 11-13-2010, 12:33 PM - Thread Starter
deepdeep1's Avatar
Why do not you answer the questions?
This is for you that you can better understand the operation!
if you have the Real software this is the only way to see a movie !
post #30 of 52 Old 11-13-2010, 12:45 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Good point. I checked GPU Activity in CCC. CPU is Q6600, GPU is HD 5570. MPC HomeCinema.
Tzan CPU GPU
Bypass 30% 0%
60 fps 80-90% 25%
Scaling is x1. A better CPU is definitely a plus. ATI Stream/AMD APP can be used more effectively.
I wish there were a simple way to turn on Convert 60fps in MPC HomeCinema.
renethx is offline
Closed Thread Home Theater Computers
