green light on the motherboard - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 11-28-2010, 12:38 PM - Thread Starter
srini0603's Avatar
I just built a new htpc. after putting everything together when I turned the power nothing happened and there is only a green light on the motherboard.
I thought that PSU is faulty. so tried to jump start the PSU and
it works fine.
took everything out and tried to put it again and still its the same.
to check if RAM is faulty, removed the RAM and powered it up and still its the same?
tried with the minimal setup ( just RAM and CPU. NO HDD or DVD) still the same green light.
is the PSU not giving enough supply to power the board? or could the motherboard will be faulty? if the motherboard is faulty can the green light still work?
can someone help me on what could be wrong?
my spces are:
motherboard is Intel DH57JG
processor is Intel i3 550
RAM is 4gig ddr3 1333 (one stick) Patriot PSD34G13332
No GPU
case is apex mi-008 ( the psu is 250W, it comes with the case)
srini0603 is offline
post #2 of 18 Old 11-28-2010, 12:42 PM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 242
it works fine.
my spces are:
No GPU
Does it post? Do you get any beeps when the power button is pushed? Is the CPU fan spinning?
assassin is online now
post #3 of 18 Old 11-28-2010, 12:51 PM
DJWikiera's Avatar
Do you have the Processor voltage connector plugged in also?
DJWikiera is offline
post #4 of 18 Old 11-28-2010, 12:56 PM - Thread Starter
srini0603's Avatar
nothing other than the green light on the motherboard. cpu fan does not spin and the psu fan also does not spin. I tried to jump start the psu and the psu fan runs when jump started.
if the motherboard is bad would the light still glow on the board?
yes 2x12 and the 2x2 both are connected.
post #5 of 18 Old 11-28-2010, 01:00 PM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 242
Yes, the light can still be green even if the board is bad.
Make sure the power button and other headers are connected correctly. Its odd that the CPU fan won't even spin up even for a second or two.
post #6 of 18 Old 11-28-2010, 01:57 PM - Thread Starter
srini0603's Avatar
all the headers are connected properly. just the green light. can the power switch on the case be bad and so it does not turn the power on?
can the power switch on the case be bad?
post #7 of 18 Old 11-28-2010, 03:50 PM
SUBCOB's Avatar
First check the power switch either hook up to the wrong connector or backwards on the motherboard or the switch may be bad. The light you describe sounds like it is the standby power indicator.
If this is not it, your motherboard may be grounded somewhere. Remove the board from the case, set it up on some foam, put the memory in and connect the power supply. Leave you hard drive disconnected. See if you can post. If so turn off and hook up your hard drive. See if it will boot. If so then there is a good chance that you shorted out the MB. This can happen by over tightening the mounting screws, or some metal shorting out somewhere between the MB and case.
SUBCOB is offline
post #8 of 18 Old 11-28-2010, 03:52 PM
SUBCOB's Avatar
Yes the power switch can be bad, I have only seen a couple though. You can remove them and check with a volt meter to see.
SUBCOB is offline
post #9 of 18 Old 11-28-2010, 03:59 PM - Thread Starter
srini0603's Avatar
the green light which I mentioned is near the 24 pin connector.
post #10 of 18 Old 11-28-2010, 04:50 PM
DJWikiera's Avatar
Like SUBCOB said, the green light is a +5v standy light. Do a bench test on the system like SUBCOB mentioned. You could short the 2 power pins with a screwdriver to see if the switch is bad. Possible the CPU or fan isn't seated properly, reinstall both.
post #11 of 18 Old 11-28-2010, 05:42 PM
blue_z's Avatar
Quoted: 12 Post(s)
it works fine.
What do you mean by "jump start"?
I have two EE degrees, but no idea what you mean.
Actually I like to assemble everything outside the case first. It's easier to see & hear if anything goes awry.
my spces are:
No GPU
Verify that the input voltage switch (the red slider near the power receptacle on the PSU) is set to "115".
Regards
P.S.
If you did something like this for "jump starting" the PSU:
http://www.overclock.net/faqs/96712-...upply-psu.html
then
1. that is not a good idea or test because the PSU is unloaded, and a switch-mode PSU should not be operated without a minimum load.
2. just because the internal fan spun up does not mean that the 12v, 5v and/or 3.3v rails are all good.
blue_z is offline
post #12 of 18 Old 11-28-2010, 06:08 PM - Thread Starter
srini0603's Avatar
use a paper clip on the 12v power supply and check if the psu fan works. there are so many videos in youtube for that.
http://www.youtube.com/watch?v=WoIMkx6Uuzg
yes its set to 115v.
post #13 of 18 Old 11-28-2010, 07:56 PM - Thread Starter
srini0603's Avatar
if the RAM is bad, still the cpu fan should spin correct?
and if I connect the sata cable from the psu to the dvd drive, shouldn't the dvd drive eject button work?
post #14 of 18 Old 11-28-2010, 08:04 PM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 242
1. Even if the RAM is bad the computer should start up (lights come on, fans spin, hard drives spin, etc) for a few seconds and then shut down. You should hear a "beep" if there is a speaker hooked up to the motherboard and this is first part of the "post". After that you should see the bios screen.
2. Yes, it should eject.
Sounds like it could be a bad PSU. That's why I like full ATX PSU from reliable manufacturers.
post #15 of 18 Old 11-29-2010, 07:20 PM - Thread Starter
srini0603's Avatar
guys finally it worked. I connected the floppy drive 4 pin to the motherboard where you need to connect the chasis fan, and thats the reason nothing happened.
as soon as I removed the floppy 4 pin from the motherboard it worked fine and it booted up.
thanks all for your help.
post #16 of 18 Old 11-29-2010, 07:35 PM
terryj47's Avatar
Well that's a new one. Glad I've never done anything like that
terryj47 is offline
post #17 of 18 Old 11-29-2010, 07:46 PM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 242
I'm just happy you didn't get the grey smoke of death.
post #18 of 18 Old 11-30-2010, 06:57 PM
SUBCOB's Avatar
Congrats and enjoy!
SUBCOB is offline
Reply Home Theater Computers
