Recommendations for an out of the box HTPC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-28-2010, 01:40 PM - Thread Starter
Pinupgrl's Avatar
Hi there !
I am new to the forum and need a reliable recommendation for a HTPC
I have read reviews on them, but still can't seem to get a good idea of which will work best for us.
Basically, all we want to do is watch Hulu and network web sites tv series (FOX, ABC etc...) right now we are watching them on a 13 inch mac laptop and would like to have a dedicated system to watch everything on the big LCD TV.
We have a wireless gateway modem that works great for the laptop watching setup.
Could I get some recommendations on a current out of the box PC (low profile or slim to fit in with the entertainment system) that would work well for what I would like to do ?
The TV does have HDMI inputs and I really don't care how great it looks as far as HD goes, I just want to be able to watch something from the computer on the TV.
Thanks !
Pinupgrl is offline
post #2 of 7 Old 11-28-2010, 03:09 PM
hirent's Avatar
If that is all that you want to view, the best thing to do is to buy an entry-level laptop. They usually hover around $300 and come with Win 7.
All you'll have to do is hook it up to your TV via HDMI and you are set.
Low-profile, inexpensive, off-the-shelf and in your living room.
Few months ago, Walmart had a laptop with HDMI out for $300.
And on BF, BB had a dual-core laptop for $189.
Its not possible to build a system with a slim case with an OS for less than that.
Then if you want, get a wireless KB & M and a MC Remote to operate 7MC from the couch.
hirent is offline
post #3 of 7 Old 11-28-2010, 03:17 PM - Thread Starter
Pinupgrl's Avatar
Thanks for the info !
So, I was also looking at this on Ebay
ebay.com/Dell-Zino-HD-Inspiron-400-Entertainment-PC-/150523395980?pt=Desktop_PCs&hash=item230be4bf8c
What do/does you think ?
Thanks again !
Pinupgrl is offline
post #4 of 7 Old 11-29-2010, 07:49 AM
hirent's Avatar
Thanks again !
Couldn't view it since its not a link.
However, I see it is a Dell Zino which is good choice for a small form factor HTPC.
There is a separate thread on the Dell Zino with lots of useful info. You might want to check it out.
hirent is offline
post #5 of 7 Old 11-29-2010, 11:40 AM
redondoman's Avatar
redondoman is offline
post #6 of 7 Old 11-29-2010, 12:43 PM
JoshDorhyke's Avatar
Originally Posted by redondoman View Post
Dell 580 slim.
http://www.dell.com/us/p/inspiron-580s/pd?~ck=anav
You'd want the Standard i3 version. They are decent spec'd machines but Dell gives no size.
Don't forget to add a wireless adapter and some form or wireless mouse/keyboard/remote.
Peter
JoshDorhyke is offline
post #7 of 7 Old 11-29-2010, 03:42 PM
shaxs's Avatar
Why not just get a Roku or Boxxe Box? They should do most of what you need for cheap.
shaxs is offline
Reply Home Theater Computers
