XBMC Media Center : Setup Guide, Knowlege Base & Support - Page 105 - AVS Forum | Home Theater Discussions And Reviews
 23Likes
Old 02-20-2014, 09:22 AM
ElJimador's Avatar
Quoted: 116 Post(s)
Liked: 109
Originally Posted by brickie View Post
As for the slowness of the interface...I would have to respectfully disagree with you.
Actually you're not disagreeing w/me since I didn't make any comment about the speed of the interface. I've never had a Pi and so my only comment based on a few reports from this forum and others is that I didn't know how stable it was. Really appreciate you sharing your experience though. I've been wondering for a while how Pi performs with XBMC and now I'm even more convinced I made the right call going w/the Celeron NUC.
ElJimador is offline
Old 02-20-2014, 09:30 AM
brickie's Avatar
Quoted: 24 Post(s)
Liked: 25
Actually should have quoted groove 93, but yeah I believe you made a great choice.If slow and steady won the race, it would get the gold! LOL smile.gif
AM I THE ONLY OASIS IN THE DESERT OF STUPIDITY......" SIR BRICKENBOCKER"
brickie is offline
Old 02-20-2014, 10:23 AM
groove93's Avatar
Quoted: 117 Post(s)
Liked: 74
Originally Posted by ElJimador View Post
The XBMC wiki on the Pi says you can buy DTS rights for just a few bucks and pass it through to your receiver (DTS up to 5.1 at least, not sure about DTS-HD). Have you tried that?
I was able to get DTS audio to work by just sending it as PCM (with a non hdmi receiver), but that was a while back and I no longer use XBMC because I got tired of tinkering with the system as a whole on both my HTPC and Raspberry Pi. Again, I never had an issue with speed issues, it was pretty solid using both Raspbmc and Openelec. Watching Live TV worked great as well.
Now I'm using the Raspberry pi for Strictly audio through the use of Volumio/Raspyfi, and have Chromecasts connected to my Pioneer Receiver and my Son's TV for streaming content.
groove93 is offline
Old 03-13-2014, 07:53 PM
Osirus23's Avatar
Quoted: 102 Post(s)
Liked: 256
I'm having choppy playback when I playback video at 24p. Im running XBMC on Windows 7 via HDMI to my AVR. I have an NVidia GTX 580 GPU and DXVA2 is enabled as well as sync playback to display option.
I've tried disabling DXVA2 as well and nothing changes. I have the latest drivers from NVidia. 24 Hz playback is still too choppy to watch. The player works good when it outputs 60 Hz though and other 24 Hz sources play fine on my system such as Blu-ray player and WDTV Live SMP.
And way to correct this? I know 24p playback on HTPCs has been a headache for some.
Osirus23 is offline
Old 03-13-2014, 08:42 PM
mrfattbill's Avatar
Quoted: 96 Post(s)
Liked: 89
Make sure xbmc isn't set to use full screen window.
Bill
mrfattbill is offline
Old 03-14-2014, 06:07 AM
Osirus23's Avatar
Quoted: 102 Post(s)
Liked: 256
So use "true" fullscreen instead? I believe its set to whatever the default setting is as I haven't changed that.
Osirus23 is offline
Old 03-14-2014, 08:59 AM
mrfattbill's Avatar
Quoted: 96 Post(s)
Liked: 89
Correct, I remember reading somewhere when I was having this issue that if you were using a "windowed full screen" then 24p would never work correctly.
Bill
Old 03-14-2014, 09:08 AM
Shape of Grey's Avatar
Had the same issue. As others have said, go into System settings and un-check "Use full screen window instead of true full screen." Worked for me.
Shape of Grey is offline
Old 03-25-2014, 07:34 AM
LucaT's Avatar
Quoted: 63 Post(s)
Hi guys,
I set MPC-HC as external player but for the video files it doesn't work
Code:
<playercorefactory>
        <players>
        <player name="PlayISO" type="ExternalPlayer" audio="false" video="true">
        <filename>C:\Users\XXXXX\AppData\Roaming\XBMC\userdata\PlayISO.bat</filename>
                        <args>"{1}" /fullscreen /close</args>
                        <hidexbmc>false</hidexbmc>
                 <hideconsole>false</hideconsole>
                 <warpcursor>none</warpcursor>
                </player>
<player name="MPC-HC" type="ExternalPlayer" audio="false" video="true">
        <filename>C:\ProgramFiles(x86)\MPC-HC\mpc-hc.exe</filename>
                </player>
                </players>
                <rules action="prepend">
                <rule filetype="*.iso" video="true" player="PlayISO"/>
           <rule filetype="*.avi" video="true" player="MPC-HC"/>
           <rule filetype="*.mkv" video="true" player="MPC-HC"/>
           <rule filetype="*.mts" video="true" player="MPC-HC"/>
       </rules>
 </playercorefactory>
I tried even with filetype="avi" or filetype="avi|mkv|m2ts" but still nothing
It shows "external player activated" on the top but not working
LucaT is offline
Old 03-25-2014, 09:27 AM
LucaT's Avatar
Quoted: 63 Post(s)
Changing with:
Code:
<rule filetype="mkv|avi|m2ts" player="MPC-HC"/>
<rule filetype="iso" player="PlayISO"/>
File avi works but ISO don't work, the file.bat doesn't start
How Can I set it?
LucaT is offline
Old 03-26-2014, 11:47 PM - Thread Starter
Dark_Slayer's Avatar
Quoted: 667 Post(s)
Liked: 436
Originally Posted by LucaT View Post
Changing with:
Code:
How Can I set it?
Looks like the path to MPC-HC was incorrect in the above playercorefactory
.avi .mkv and .mts wouldn't have worked unless it was fixed. Most every installation I've ever seen uses Program Files (x86) with spaces rather than ProgramFiles without spaces. Also, you'd want m2ts, but probably not ts. Several PVR backends will use ts for live tv, and it won't work in an external player as far as I know. If you aren't using PVR, then you can take advantage of the "order" that applies to prepending rules in playercorefactory. By that I mean, just apply your iso rule first, then make the mpc-hc rule =all. XBMC will process them in order, so iso will never reach the all rule if it's "prepend" rule comes first
What does the bat file look like, and it may go without saying but you aren't actually using C:\Users\XXXXX\AppData right? I take it that is just to shroud your actual username in this post, but obviously that would need to match your real username in the playercorefactory xml
Dark_Slayer is offline
Old 03-30-2014, 08:21 AM
adinis's Avatar
Quoted: 21 Post(s)
I have a question for the members here in regards to folder structure set up for an animal series. The series in question is Mobile Suit Gundam Wing, I have all 49 episodes on, I believe, 10 discs. Now each disc has five episodes and each disc is referenced as Operation 1, 2,3,etc. I consider each disc as a season but when looking up on IMDB it shows up as being Season 1 with 49 episodes. I have tired setting it as a regular season series as
Gundam Wing
Operation 1 (this meaning season 1)
Episode 1
Episode 2
Episode 3
Episode 4
Episode 5
Operation 2
Episode 1
etc.
But by me doing it this way, there is no way to get the meta data for the series. Only way I can do it is just set it up as only being a series with one season. Not really wanting to do it this way but it seems I have no choice. Hope you guys understand what I am trying to accomplish. Any suggestions? Hope
adinis is offline
Old 04-13-2014, 05:40 AM
barhoram's Avatar
Quoted: 125 Post(s)
Liked: 34
My pre-amp can not decode DTS-HD or Tru-HD, however, it will accept Multi Channel PCM over HDMI. Will the current version of XBMC decode DTS-HD and Tru-HD and send LPCM to a pre-amp via HDMI?
barhoram is offline
Old 04-13-2014, 06:26 AM
lulimet's Avatar
Quoted: 94 Post(s)
Liked: 92
Yes, in the audio output settings choose 'analog' instead of 'hdmi'.
lulimet is offline
Old 04-13-2014, 08:20 AM
steelman1991's Avatar
Quoted: 222 Post(s)
Liked: 118
Only 'core' DTS though.
steelman1991 is offline
Old 04-13-2014, 10:13 AM
barhoram's Avatar
Quoted: 125 Post(s)
Liked: 34
So.....which is it?
From this chart it appear that getting DTS-HD is possible with certain cards....
http://wiki.xbmc.org/index.php?title=Audio_hardware_compatibility#Nvidia_Based
barhoram is offline
Old 04-13-2014, 10:23 AM
lulimet's Avatar
Quoted: 94 Post(s)
Liked: 92
If he has an Intel based system then it will decode DTS-HD internally. I know it works with my Intel NUC build.
lulimet is offline
Old 04-13-2014, 10:30 AM
Quoted: 222 Post(s)
Liked: 118
It doesn't because there is no openly available dts-hd decoder. Only DTS core. It will of course bitstream both. but will only decode True HD fully.
I have a habit of assuming everyone uses windows - the above info is for windows OS, other OS may vary.
Old 04-13-2014, 10:36 AM
Quoted: 222 Post(s)
Liked: 118
So.....which is it?
It is possible to bitstream/passthrough a DTS-HD MA stream, but cannot fully 'decode' to LPCM and pass an unaltered stream.
Old 05-05-2014, 07:14 AM
Shape's Avatar
Quoted: 67 Post(s)
Liked: 88
I have an nVidia graphics card and have been using Windows Media Center up until this point. I have a lot of ripped DVDs on my hard drives in folder format. But now I want to start ripping my blu-rays. So I set up XBMC. Trouble is that the video levels are messed up and it is crushing the blacks and whites.
I can't set the TV to use Full RGB because I run my HTPC output (DVI) through my receiver. And everything else that goes through my receiver uses video levels, not full RGB. So how can I set up XBMC to use the proper video levels?
Every thread I find on XBMC.org is some stupid philosophical battle. I just want my video to look right on my TV. How do I set it up?
Josh - GamerTag: ShapeGSX PSN: ShapeGSX
'97 Eclipse GSX - 11.825@117.55mph in the 1/4
Shape is offline
Old 05-05-2014, 07:32 AM - Thread Starter
Quoted: 667 Post(s)
Liked: 436
Install Gotham if not already using it. Go to settings->system->video output and choose the "use limited color range" option
Old 05-05-2014, 07:52 AM
Shape's Avatar
Quoted: 67 Post(s)
Liked: 88
That option is not there in my install.
I installed Gotham yesterday from this page:
http://xbmc.org/download/
Shape is offline
Old 05-05-2014, 07:55 AM - Thread Starter
Quoted: 667 Post(s)
Liked: 436
Change the settings level to expert in the bottom left corner of the main settings screen
Old 05-05-2014, 08:03 AM
Shape's Avatar
Quoted: 67 Post(s)
Liked: 88
Oh, I think I had it set to Advanced. I didn't know there was an Expert setting, too!
Shape is offline
Old 05-06-2014, 11:04 AM
Defcon's Avatar
Quoted: 1117 Post(s)
Liked: 580
I wait for the day XBMC will have a true client server model and not need editing xml files and installing MySql. As well as an updated library management system.
Defcon is offline
Old 05-06-2014, 11:31 AM
lukemb's Avatar
Liked: 115
http://mediabrowser3.com/community/index.php?/blog/1/entry-61-this-isnt-your-fathers-xbmc/
lukemb is offline
Old 05-06-2014, 01:03 PM
ellisr63's Avatar
Quoted: 991 Post(s)
Liked: 412
So is this an addon for XBMC?
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is online now
Old 05-06-2014, 01:21 PM
lukemb's Avatar
Liked: 115
Yes it is, and they have a lot of great stuff going on with it. There's nearly ten of them working on it now, and most of the popular skins are now supported and/or also being enhanced.
lukemb is offline
Old 05-10-2014, 02:55 PM
brickie's Avatar
Quoted: 24 Post(s)
Liked: 25
Maybe it's just me, but did XBMC finally add a way to have multiple source(hard drives) appear as one link natively? Just saw what appears to be that option..Or just wondering if it's always been there and I never noticed it. Right now using Drive Pool to do this,but very nice if they decided to implement it natively. Guess I would still need drive Pool though so my other boxes,(2 wdtv live media players) would be able to see just (1) hard drive..Just found it interesting when i read it..Here it is from their page if anyone else wanted to see it.
brickie
You might notice that XBMC has an "ADD" button in addition to a "BROWSE" button when you are adding a source. After you add your first location, you can add a second location (network or local. you can even mix them) and XBMC will show both folders as a single folder/source.
XBMC will also combine the subfolders within the source/locations. For example, if you had a hard drive for TV shows, but ran out of space, you could make a second hard drive with the same folder paths and XBMC would merge them together to a single directory path. Such as
Hard drive 1/TV shows/
Hard drive 2/TV shows/
and the same is true for an additional nested folder with the same way:
Hard drive 1/TV shows/American Dad/
Hard drive 2/TV shows/American Dad/
You could have half of a show on one hard drive, half on another, and XBMC will show it to you as if it was in a single location by using multiple locations in a single source.
Note: This only impacts the basic "Files view". The default Library nodes will combine things by show even if their files are spread across multiple drives. Most users will not really benefit from using multiple paths in a single source.
ellisr63 likes this.
brickie is offline
Old 05-10-2014, 03:09 PM - Thread Starter
Quoted: 667 Post(s)
Liked: 436
It's been there I know since frodo. I didn't have multiple hard drives when using eden
