XBMC Media Center : Setup Guide, Knowlege Base & Support - Page 111 - AVS | Home Theater Discussions And Reviews
 15Likes
post #3301 of 3315 Old 02-10-2015, 12:03 PM
JDLIVE's Avatar
Quoted: 27 Post(s)
Liked: 32
Send a message via Yahoo to JDLIVE
For live TV, all the XBMC ServerWMC app does is remux the recorded file from WMC, so you're going to need to get WMC working first. Not sure why audio settings would give you a video error? Are you changing audio devices when you switch from 5.1 to stereo?
JDLIVE is offline
post #3302 of 3315 Old 02-10-2015, 03:06 PM - Thread Starter
Dark_Slayer's Avatar
Quoted: 387 Post(s)
Liked: 340
Originally Posted by BlvckBox View Post
My question was, If I set my sound setting back to 5.1 and run live tv on XBMC will it still throw me the "video Error" message?
If you are getting the video error message in WMC that channel won't work in ServerWMC. Are you using WMC for cable or OTA? If cable which provider?
This is for the most part true, but there is a caveat
@BlvckBox you can set audio back to whatever you want in WMC so long as it works. In your XBMC setup your windows audio settings don't matter as much depending on how you do things. If you go with the recommended bit-perfect passthrough option using WASAPI on your PCH as the passthrough device then your "Windows Sound Settings for HDMI" configuration (2.1, 5.1, 7.1) doesn't matter. Hence, you can leave it at 2.1 for WMC and XBMC will passthrough up to 7.1 with wasapi, but you do need to check the "allow exclusive control" text box under settings.
Though, WMC shouldn't have any problem selecting 5.1 either. Do you have a codec pack installed by chance? That tends to break WMC audio if not configured properly
Dark_Slayer is online now
post #3303 of 3315 Old 02-10-2015, 04:31 PM
JamesVG81's Avatar
Quoted: 28 Post(s)
Any one gotten XBMC/KODI to work with an anamorphic lens ? Everything I have read said that XBMC will not streach the image vertically to work properly with a anamorphic lens. I know media play classic with work. But I have been using XBMC for years now and would really like not to have to switch to something else when I switch to a CIH screen. Any one have a fix for this? Thanks
JamesVG81 is offline
post #3304 of 3315 Old 02-10-2015, 05:00 PM
ellisr63's Avatar
Quoted: 283 Post(s)
Liked: 272
I have the latest version of XBMC/KODI installed, along with Windows Media Server, and I cannot get the TV tuner to work in Kodi. Isn't there a way to get it to work without using windows?
Denon 4520ci, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, MiniDSP 2x4s, (4) Klipsch HIPs,  PS3, XBox 360, (3) Intel NUCs, Redmere, Monster HTPS7000, 2 HTS-10 subs, Panasonic AE8000, SeymourAV 180 (195" diagonal) scope screen, Darbee Darcet, Yamaha P7000s, (2) Yamaha P2500s, & (3) Topping 25wpch T chip amps.
The Ellis Family Go Big or go Home HT
ellisr63 is online now
post #3305 of 3315 Old 02-12-2015, 11:38 AM
JDLIVE's Avatar
Quoted: 27 Post(s)
Liked: 32
I wasn't trying to link the two setups, just wondering if maybe he was switching from say, an analog audio connection for 2.1 to an HDMI connection for 5.1 that might cause some kind of HDCP error.
I'm still using MPC-HC as an external player. The Kodi internal player can do a vertical stretch, but the problem is it will override the content aspect ratio. So if you have a blu-ray rip, it's 1920x1080, since all blu-rays are that AR, the black bars are actually encoded as part of the picture. So when you tell Kodi to stretch it, you don't get the desired result since it think it's 1920x1080. There were people requesting a feature to allow this, but the devs basically said, "if you want to do that, then re-encode your videos properly to 1920x810". In other words, they don't understand CIH setups. That was prior to the Gotham release but I doubt it's changed. There was also some talk of a media flag to use as an over-ride, not sure if that ever went anywhere.
JDLIVE is offline
post #3306 of 3315 Old 02-12-2015, 11:40 AM
JohnsonBrewer's Avatar
DLNA Live TV
FYI, for any XBMC (now Kodi) users running the wmc.pvr back end with an HDHomerun Prime, there is now an option to directly stream to the Kodi client via DLNA. That means much faster channel changes and no temporary stream files being written. You do give up the option to record the stream on the fly, but that's a trade-off I can live with.
I too have the HDHR Prime, could you walk me through the steps to get Live TV on Kodi ( installed an Amazon Fire TV ) ? I currently use WMC to record, but I haven't yet installed WMC Server or the wmc.pvr add-on in Kodi if that matters. Thank you.
JohnsonBrewer is offline
post #3307 of 3315 Old 02-12-2015, 11:59 AM
JDLIVE's Avatar
Quoted: 27 Post(s)
Liked: 32
I am using Windows so I'm not sure if there are additional requirements for running it on a Fire, but here's a setup guide. It's got a lot more than just Live TV, but it's in there as well.
JDLIVE is offline
post #3308 of 3315 Old 02-12-2015, 06:58 PM - Thread Starter
Quoted: 387 Post(s)
Liked: 340
You have to install ServerWMC or some other backend to get PVR working in Kodi
I think this is a better guide http://assassinhtpcblog.com/paid-guides-10/#guide40
If you are wanting to also add the DLNA tuner access like JDLIVE has, then you will need to enable DLNA from your HDHomerun Setup first. You still need ServerWMC installed as well
post #3309 of 3315 Old 02-12-2015, 07:12 PM
ellisr63's Avatar
Quoted: 283 Post(s)
Liked: 272
So apparently there is no way to run the HDHomerun Dual tuners without a windows install, correct? I was really hoping I could bypass my windows setup for OpenElec/Kodi, and UnRaid.
post #3310 of 3315 Old 02-12-2015, 07:56 PM - Thread Starter
Quoted: 387 Post(s)
Liked: 340
You don't need windows its just extremely easy
Do you already have unraid or is it "planned" ?
You can go straight to OE from the dual with tvheadend
It's a little more involved
http://forum.kodi.tv/showthread.php?tid=182556
https://tvheadend.org/boards/14/topics/4798
Since the dual doesn't do dlna you can't use any of the cute little dlna workarounds people are trying either. There is also a much more manual setup where you add each available channel as an rtsp stream in your kodi library
@captain_video runs unraid and was looking to use mythbuntu. He may be able to help. You may be able to set up a jail for your backend
post #3311 of 3315 Old 02-12-2015, 08:06 PM
ellisr63's Avatar
Quoted: 283 Post(s)
Liked: 272
I have UnRaid setup already. i have been trying for months to get my tuners setup with OpenElec/XBMC (now OpenElec/Kodi) with zero luck. I will try the links you supplied and contact Captain_video if I am unable to get it up and running. Thanks for the info.
I would be happy if i could just play my recorded tv shows in Kodi that were recorded in WMC.
post #3312 of 3315 Old 02-20-2015, 10:59 AM
Favelle's Avatar
On this new version of XBMC (Kodi?), I can't find the options where I input my receiver's capabilities. It used to by in "System >> Audio Output"....but now that menu is severely limited. I can't get my titles to play DTS-MA because it thinks everything is stereo.
In terms of LFE, size does matter!
Favelle is offline
post #3313 of 3315 Old 02-20-2015, 11:04 AM
Favelle's Avatar
Never mind. Found it. Advanced settings.
Favelle is offline
post #3314 of 3315 Unread Today, 08:08 PM
Liked: 0
Hello all. I am new to the HTPC game. Bought an Assassin HTPC this past January and have really enjoyed it so far.
I've noticed something funky in the last few days playing back .mkv files in XBMC. I have had a few movies that when I play them back they seem to have spots where the scenes play out of order. One movie, Draft Day, did this in two spots. The rest of the movie played fine. And honestly, we watched this multiple times and I don't think it did it before...though I could be wrong.
Tonight we watched Mockingjay Part 1. It had these out of order scenes several times. Probably 6 or 7 at least. It's like it jumps ahead 10 minutes, plays for a minute or so, then jumps back to where the original jump was. Very odd.
I am using MakeMKV to rip the files. Fairly straight forward I think.
I haven't had this happen until the past two days. Is it an XBMC issue? I am on the latest version I believe. Or is it a problem with makemkv?
I did notice that when I ripped Mockingjay Part 1 that there were dozens of files listed all the same size. I just grabbed the first one. Is this some new way to mask which file is actually the correct one?
Thanks in advance for any insight anyone might have!
strobelighthos is online now
post #3315 of 3315 Unread Today, 08:28 PM
ckronengold's Avatar
Quoted: 18 Post(s)
You ripped the wrong playlist.
As an effort to limit the copying of the discs (lets not get into a copyright / fair use discussion), one of the newer copyright protection schemes is to have multiple/dozens of playlists that look nearly identical. Sometimes they all have the same run time. Other times, only one of them will have the right run time, which makes it easier to pick the right one.
When you look in MakeMKV, take a look at the segment maps. You'll see that the segments (consider them like chapters for the purpose of this conversation), will not all be in the same order. And thats probably what you ran into.
The MakeMKV forums are a good source of info for finding the right playlist. Google is your friend here. But you've run into one of the newer copyright protection schemes from the studios. Playlist obfuscation.
Media Room: Epson 5030 / Onkyo NR-709 / OPPO-103
Paradigm Mini Monitors v2 / Atoms (rears) / CC-370
Den: Samsung 59D6500 Plasma & Monoprice in-walls
Server: WHS2011, i5 2500k CPU
HTPC1:Win8 Pro 64-bit, i5 750 Radeon HD 5850
HTPC2:Win8 Pro 64-bit, i3 2105, Radeon 6770
ckronengold is online now
Reply Home Theater Computers
