XBMC Media Center : Setup Guide, Knowlege Base & Support - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 23Likes
post #721 of 3419 Old 04-09-2011, 08:58 PM
mbbransc's Avatar
Originally Posted by thewarm
The Hulu plugin does not work in XBMC. Check the XBMC Forum under plugins.
http://forum.xbmc.org/showthread.php?t=45889
I am on my phone so I'm not checking downloads, but the hulu plugin does work, I've used it. Unless it is currently broken.
mbbransc is offline
post #722 of 3419 Old 04-09-2011, 09:26 PM
joeydrunk's Avatar
Quoted: 14 Post(s)
How do you install it?
joeydrunk is offline
post #723 of 3419 Old 04-10-2011, 06:38 AM
thewarm's Avatar
What does Hulu have to do with downloads?
thewarm is offline
post #724 of 3419 Old 04-10-2011, 07:18 AM
joeydrunk's Avatar
Quoted: 14 Post(s)
I think he meant, because he wasnt home, he couldn't check his xmbc hulu zip file DOWNLOAD on his pc
post #725 of 3419 Old 04-11-2011, 12:32 PM
thewarm's Avatar
I found this on the XBMC forum. You use the "program launcher" to run Hulu Desktop. I'm going to give this a try.
On Windows 7...
Once you've downloaded the Launcher zip, install it from within XBMC:
1) From default skin, open System, then Add-ons
2) Select 'Install from zip file'
3) Navigate to the launcher zip file on your local machine
4) Once installed, return to the home screen and select Programs
5) 'Launcher' should appear in the list of program add-ons
Next, download and install the HuluDesktop client, noting the installation path. Once it's installed, return to XBMC.
1) Open the Launcher program by selecting it from the Programs menu
2) Select 'Standalone (normal PC executable)
3) Browse to the HuluDesktop.installation folder (default install for me was %localappdata%\\huludesktop) and select HuluDesktop.exe
4) No need to pass the app any arguments
5) Set the title to whatever you want it to appear as under the Programs, Launcher menu
When you return to the Programs menu and select launcher, you should see HuluDesktop there (or whatever you chose to name the shortcut).
thewarm is offline
post #726 of 3419 Old 04-11-2011, 02:41 PM
joeydrunk's Avatar
Quoted: 14 Post(s)
On Windows 7...
That's just launching it from the program launcher plugin though. That's not the huluzip plugin. Any time I try to use the launcher it always takes me to the desktop and says "Windows can't find c:\\file name yada yada" whichever file name I try to launch
post #727 of 3419 Old 04-11-2011, 04:31 PM
CitznFish's Avatar
It works for me with HuluDesktop. I had to take my User/(username)/appdata folder and unhide it so launcher could see it. The huludesktop.exe resides in user/(username)Appdata/local I believe... easy to find if you poke around
CitznFish is offline
post #728 of 3419 Old 04-13-2011, 05:45 AM
robl45's Avatar
Quoted: 184 Post(s)
this seems cool, but looks like it lacks a lot of functionality that harmony has. I don't see buttons for launching activities, etc. while the keyboard and mouse would be cool, i would hate to have to use two remotes.
In other XBMC news... seems they have their own remote control coming out; Pulse Eight (yes, it includes a keyboard on the back). They are taking pre-orders ($60).
I also just read that you can buy a Boxee Remote from AMZN for $40. Anyone know how well it works with XBMC (since Boxee is basically XBMC)?
robl45 is offline
post #729 of 3419 Old 04-13-2011, 05:49 AM
joeydrunk's Avatar
Quoted: 14 Post(s)
This would be great for me. I do everything on my xbmc Htpc. So all need it for is xbmc and my avr. That's one thing that no remote has done yet, mouse, keyboaard, and universal remote.
post #730 of 3419 Old 04-13-2011, 06:06 AM
mbbransc's Avatar
joey -
Did you install the hulu plugin from zip? I just checked the XBMC boards and BlueCop (builder) is aware of an issue resulting in "ACCSES DENIED" and he's working on it.
Honestly, I've been focusing my attention towards 7MC lately instead of XBMC and have hulu working there. I know it used to work in XBMC and it sounds like it will again shortly. BlueCop is very keen.
mbbransc is offline
post #731 of 3419 Old 04-13-2011, 06:07 AM
robl45's Avatar
Quoted: 184 Post(s)
right, well TV, Receiver. does it have breakthrough to allow it to control your HTPC while letting the AVR do the volume? can it turn all the things on at once or are you sitting there pushing power for each thing?
robl45 is offline
post #732 of 3419 Old 04-13-2011, 06:26 AM
robl45's Avatar
Quoted: 184 Post(s)
http://www.conspin.com/conspin/andione_media.html
This is a remote!! looks sick.
robl45 is offline
post #733 of 3419 Old 04-13-2011, 06:38 AM
joeydrunk's Avatar
Quoted: 14 Post(s)
joey -
No, I don't yet. thnks for the info, that's good news, hopefully. It's not like I can't go there or anything, I just want the xbmc plugin.I think were all just spoiled and want our media centres to work perfectly and exactly the way we want.
post #734 of 3419 Old 04-13-2011, 06:53 AM
joeydrunk's Avatar
Quoted: 14 Post(s)
That is sick. I've been on the perfect remote hunt, I'm defiantly going to check this out further. Their other hard button universal remote looks really cool too, its got a full keyboard in the back.
post #735 of 3419 Old 04-13-2011, 07:03 AM
robl45's Avatar
Quoted: 184 Post(s)
http://www.cometsupply.com/mp/CONSPIN/pm/NSPCSR300/
supposedly can buy at link above, blocked at work so don't know. Engadget said it can be used to control computer as well.
robl45 is offline
post #736 of 3419 Old 04-13-2011, 03:19 PM
joeydrunk's Avatar
Quoted: 14 Post(s)
I'm sure all you guys know about this but I just have to say somthing, its so cool. I just figured out than I can download subtitles for absolutely any movie or tv show I have with the click of one button! I can't get over how cool that is!
post #737 of 3419 Old 04-13-2011, 03:24 PM
robl45's Avatar
Quoted: 184 Post(s)
http://www.touchsquid.com/Remote.htm
this remote might be even better, and not running 2.1, running gingerbread right now and might run honeycomb by release in June. wifi, bluetooth and IR, no RF though.
robl45 is offline
post #738 of 3419 Old 04-14-2011, 09:51 AM
CitznFish's Avatar
Real basic XBMC question here..
If I am playing an HD MKV file ( file says 720p Bluray ) and XBMC show's the audio as ac3 2.0 does that mean it's encoded stereo 2.0 or is it version 2.0 of the ac3 spec and I should get 5.1 surround out of it? I keep thinking I should get 5.1 since it's a BluRay but my receiver says PL II Movie. (The receiver decodes DTS and Dolby D just fine though )
post #739 of 3419 Old 04-14-2011, 10:10 AM
dbone1026's Avatar
Quoted: 234 Post(s)
Liked: 116
stereo 2.0
You can use media info on your mkv file to confirm what the audio track is to see if XBMC is in any way affecting the original file
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #740 of 3419 Old 04-14-2011, 10:23 AM
CitznFish's Avatar
Originally Posted by dbone1026 View Post
stereo 2.0
oh, very cool program. And yeah, it's 2.0 stereo stream.
But at least now I know!
post #741 of 3419 Old 04-14-2011, 11:38 AM
211
211's Avatar
Is there anything I need to do with the default XBMC media scraper if I install MCM?
Right now my system is set up and displaying all episodes just fine with the default scraper but I'd like to give MCM a try.
Also is the episode torrenting feature functional? That's my main reason toward switching to MCM so I'd like to confirm that it works (the MCM Wiki's appear incomplete and don't offer much info on the subject)
211 is offline
post #742 of 3419 Old 04-14-2011, 12:47 PM
joeydrunk's Avatar
Quoted: 14 Post(s)
How do most people here play BLURAY discs from xbmc? Do you use a playercorefactor.xml file or just get out of xbmc and open up tmt or pdvd, or have you found a plugin? Also, to bitstream hd audio with your mkv's, ISO's,BLURAY rip folders, etc. what do you use? Do you use mpc-hc w/ ffdshow or shark007 or do you play them through tmt or pdvd, or somthing else.
post #743 of 3419 Old 04-14-2011, 05:59 PM
joeydrunk's Avatar
Quoted: 14 Post(s)
Are there Plugins or can younger the stock ones to do cool things to the dvd and BLURAY covwrs/cas
post #744 of 3419 Old 04-14-2011, 06:01 PM
joeydrunk's Avatar
Quoted: 14 Post(s)
Sorry about that, I'm using my phone. I'm wondering if there are any Plugins that do anything cool to the dvd/bluray covers/cases. Like for example, shiny looking plastic, texture, 3d images etc. Like the wmc coverart plugin.
post #745 of 3419 Old 04-14-2011, 07:48 PM
mbbransc's Avatar
Have you looked at the Skins forum on XBMC.org? There are a ton of official release skins and each one has several different views. And then there are another handful in beta with nightly's you can try. All of the threads have screenshots.
mbbransc is offline
post #746 of 3419 Old 04-14-2011, 07:54 PM
joeydrunk's Avatar
Quoted: 14 Post(s)
I have all of the official skins but I think there's only one, maybe 2, that shows actual BLURAY cases but there's no reflective cover and they look a little ghetto compared to that coverart plugin on wmc I was talking about. Overall I think xbmc looks the coolest of all the media centers. I'm just trying to find somthing for this small area.
post #747 of 3419 Old 04-15-2011, 07:37 AM
thewarm's Avatar
I am also new to XBMC. To my understanding, XBMC does not support the ".png" format which allows transparency. Only ".jpg".
thewarm is offline
post #748 of 3419 Old 04-15-2011, 09:36 AM
JDLIVE's Avatar
Quoted: 99 Post(s)
Liked: 58
Send a message via Yahoo to JDLIVE
I rip my BD discs to a single M2TS file and play them with MPC-HC. I don't bitstream audio, I use ffdshow to decode to analog.
I have a number of reasons to use MPC-HC, for one I understand it and have it set up the way I want. I used it's aspect ratio controls for my CIH setup and pixel shaders to do color correction.
MPC-HC can also play the main feature from a BD disc itself, not sure how well that would work in XBMC.
JDLIVE is offline
post #749 of 3419 Old 04-15-2011, 09:52 AM
joeydrunk's Avatar
Quoted: 14 Post(s)
Do you have that open up from within xbmc using the playercorefactory?
post #750 of 3419 Old 04-15-2011, 10:00 AM
joeydrunk's Avatar
Quoted: 14 Post(s)
Could you elaborate on the "aspect ratios control for my CIH setup and pixel shades to do color correction" Also what do you use to get your m2ts? That's the same file in an ISO, right? Except that you only get the main movie and nothing else. What size is a BLURAY m2ts usually, ballpark.
Reply Home Theater Computers
