XBMC Media Center : Setup Guide, Knowlege Base & Support - Page 37 - AVS Forum | Home Theater Discussions And Reviews
 23Likes
post #1081 of 3419 Old 09-21-2011, 10:18 AM
jimjimmyjones85's Avatar
Originally Posted by GreenEyez View Post
Actually, gnif has more activity on his github where he pushes code updates than on the XBMC forum. Probably doesn`t have time for posting updates and stuff.
https://github.com/gnif
Last push was from 1 week ago, so he`s alive ))
DO you have to manually do these updates or can it be done auto?
jimjimmyjones85 is offline
post #1082 of 3419 Old 09-21-2011, 10:48 AM
jim tressler's Avatar
Quoted: 16 Post(s)
manual - you can get the nightlies at http://mirrors.xbmc.org/nightlies/
jim tressler is offline
post #1083 of 3419 Old 09-21-2011, 12:32 PM
steelman1991's Avatar
Quoted: 215 Post(s)
Liked: 116
Jim
These development releases will not include any of gnif's commits or work - the AE branch is seperate and HASN'T been amalgamated with the master yet. At the moment the only way to get it is to build from GIT yourself
steelman1991 is offline
post #1084 of 3419 Old 09-21-2011, 12:46 PM
Quoted: 215 Post(s)
Liked: 116
Hmm, have you tried removing the Episode X from the name or the "-"? I have them like this : "Star Wars The Phantom Menace" and scraping worked fine, with both MCM and the internal XBMC scrapper. usually, you want to look on the moviedb site to see how they are named in case something like this happens.
Sound advice as always GreenEyez, particularly the point of ensuring an exact match to the source. Not always possible where 'special' characters exist, but in most cases dropping those from the title, gives a valid result.
post #1085 of 3419 Old 09-21-2011, 12:55 PM
Quoted: 16 Post(s)
I'm just talking nightlies.. none of the experimental stuff.. but thanks for the tip
Originally Posted by steelman1991 View Post
Jim
post #1086 of 3419 Old 09-21-2011, 12:58 PM
Quoted: 215 Post(s)
Liked: 116
My bad should have read your answer more fully
post #1087 of 3419 Old 09-21-2011, 01:01 PM
Quoted: 16 Post(s)
no problem.. just glad to know about github.. might try it to see what I can break!
post #1088 of 3419 Old 09-21-2011, 02:05 PM
GreenEyez's Avatar
I think what Jim was asking (or atleast what i understood) was if gnif needs to manually update his github account or can he set an automatic update to push updates to it.
Well, yes and no. Yes, some git clients have an auto-update feature, or you can write a script to do it, but you need to actually write new code or make modifications to your local project file folder to have something to update in the first place. So yeah, he`s alive, but probably doesn`t have time to work on it so much atm, i remember he disappeared for a month at one point due to work related issues
GreenEyez is offline
post #1089 of 3419 Old 09-21-2011, 02:27 PM
Cragglemiester's Avatar
Thanks for you help on this one, removing the episode made the difference and all 6 are added to the library,
Cragglemiester is offline
post #1090 of 3419 Old 09-21-2011, 02:44 PM
GreenEyez's Avatar
Thanks, yeah, i`ve had this issue in the past with a TV Series called "$#*! My Dad Says". I couldn`t enter those special caracters due to Windows folder naming limitation, XBMC and MCM could not identify the show if it was named "Sh*t my dad says", since the tvdb.org used the special chars in the name, eventually ended up making my own .nfo files, what a proverbial pain in the ... it was
post #1091 of 3419 Old 09-21-2011, 06:26 PM
Quoted: 16 Post(s)
I looked at the github stuff and its greek to me.. Ill stick to nightlies until the audio engine is put in there
post #1092 of 3419 Old 09-21-2011, 06:59 PM
GreenEyez's Avatar
Github is the place where software developers make a copy of their uncompiled project file. If don`t know how to code in C++/C or at least know how to compile, you`re screwed
post #1093 of 3419 Old 09-21-2011, 08:23 PM
charlievoviii's Avatar
XBMC won't play my 1080I 25fps contents. when i select a video i can hear the sound but no video and it doesnt even switch to video screen. I know my projector doesnt do 25fps, so i even turn off the switch display to match video frame rate, still nothing. help please
charlievoviii is offline
post #1094 of 3419 Old 09-24-2011, 05:26 AM
joeydrunk's Avatar
Quoted: 14 Post(s)
In case you don't know you can always go back and rename the movie whatever you want once the scraper finds it. So you could go back in now that they've been found and add the numbers 1,3, and 6 or whatever. I have to do this a lot with foreign movies. Even when their released in America with the US name it won't find it so I have to look up the original name, change it to that, let the scraper find it and then change the name back to the English version in xbmc. Just go to your library, hit "c" and "edit title".
joeydrunk is offline
post #1095 of 3419 Old 09-24-2011, 06:13 AM
GreenEyez's Avatar
1080i/25fps? That`s some sort of recording from a digital camera/camcorder, right? Try out the nightly builds, they made some improvements regarding de-interlacing. Also, if you can upload a small sample from one of those recordings so i can test out on my machines and get back at you, that would be great.
post #1096 of 3419 Old 09-25-2011, 12:14 AM
contentedbloke's Avatar
Anyone know when Eden is being released? Waiting eagerly for it!
contentedbloke is offline
post #1097 of 3419 Old 09-25-2011, 05:59 AM
GreenEyez's Avatar
November/December, depeding on the progress.
post #1098 of 3419 Old 09-26-2011, 03:32 AM
no it's not off camera. Im playing BBC Human Planet m2ts file, i even try the nightly build. do you have fileserve, fileosnic, or netload account ? if yes i can upload a sample for you.
post #1099 of 3419 Old 09-26-2011, 04:16 AM
GreenEyez's Avatar
Filesonic doesn`t require a account to download. You can upload a sample on that, thanks.
post #1100 of 3419 Old 09-26-2011, 04:47 AM
Tony_Montana's Avatar
Quoted: 45 Post(s)
Unfortunately, most of BBC`s blurays are VC1-Interlaced (1080i50)
this is problem for every player, not only xbmc.
try to enable DXVA in video playback settings, otherwise you have to set an external player
Tony_Montana is offline
post #1101 of 3419 Old 09-26-2011, 09:00 AM
i must be really stupid cause I am using Aeon MQ 2 and cannot find the settings for Cinema Experience anywhere
post #1102 of 3419 Old 09-26-2011, 07:59 PM
here you go.
http://www.filesonic.com/file/2208669344
post #1103 of 3419 Old 09-27-2011, 12:18 AM
Quoted: 215 Post(s)
Liked: 116
Charlie hosting site won't allow free downloads over 400mb - over that you need a Premium Account - might want to cut down the size of your sample.
post #1104 of 3419 Old 09-27-2011, 03:04 AM
lol thats why i asked if you guys have those hosts account. Anyway I cut it down to under 200megs. Uploading right now. It's still full quality file. Will post once it's done.
post #1105 of 3419 Old 09-27-2011, 03:06 AM
it's works with VLC, MPC, and Power DVD perfectly. XBMC is the only issues. u can hear the sound but no video. I have tried everything. I even posted on XBMC forum. So far in not the only with this issues.
post #1106 of 3419 Old 09-27-2011, 03:46 AM
here is the file under 200megs
Human planet 1080i25fps
http://www.filesonic.com/file/2210554084
post #1107 of 3419 Old 10-01-2011, 06:11 PM
Quoted: 16 Post(s)
What's the latest on 3d support?
Mod's edit: No piracy talk here.
post #1108 of 3419 Old 10-02-2011, 09:12 AM
danbez's Avatar
Quoted: 33 Post(s)
I am having trouble to enable Dolby Digital / DTS. I have enabled them in the Audio settings, and my receiver can handle them just fine. But when I try to play a DVD with a DD track, I get an error message saying that the Audio could not be initialized and that I should check my audio settings.
Any tips?
danbez is offline
post #1109 of 3419 Old 10-02-2011, 10:31 AM
BizarroTerl's Avatar
Quoted: 38 Post(s)
Liked: 46
Audioengine won't make the next release. I have a lot of multichannel flac files that don't play properly with the current XBMC player. My hope was Audioengine would fix it. This sucks.
BizarroTerl is offline
post #1110 of 3419 Old 10-02-2011, 10:37 AM
robl45's Avatar
Quoted: 167 Post(s)
audioengine builds are out there, I am using one for the past few weeks. they are a little buggy though.
robl45 is offline
Reply Home Theater Computers
