Hauppauge Colossus HD-PVR - Page 19 - AVS | Home Theater Discussions And Reviews
 1Likes
post #541 of 561 Old 12-01-2013, 02:20 PM
riffer's Avatar
Originally Posted by aab1 View Post
What is a CableCard? From a quick search I see it's a PCMCIA card, my PC doesn't have a PCMCIA slot, would I need to add hardware to be able to use PCMCIA cards on my desktop? Do you hook put the cable to this CableCard and the CableCard to the desktop?
Also, I'm with Videotron in Quebec and it's not clear if they support CableCards or not.
In any case, how is a CableCard better than a capture card and cable box (again, I have no idea what a cablecard is or does)?
No cablecard in Canada (except inside Shaw's cable boxes) as the Cable companies are not required by law to allow them as in the US.
I use the Colossus with my Rogers box no problem. I can't use both the HDMI and component out at the same with my box, so I have to pass through the signal from the Colossus to the TV. Included RF Blaster switches the channels, but you may have to set up all the channels manually, as I have
riffer is online now
post #542 of 561 Old 12-01-2013, 02:26 PM
aab1's Avatar
Quoted: 21 Post(s)
Why are you outputting the video signal from your cable box to the TV rather than the video output of the PC itself?
What do you mean by setup the channels manually? What TV software do you use on the PC and does it have a program guide?
I heard the previous "boxed" (non card) version of the colossus had reliability issues and had to be reset every now and then, is this an issue with the Colossus? In nearly 10 years of using Beyond TV and my Hauppage analog tuner card I never had an issue, I'd like something as reliable.
aab1 is offline
post #543 of 561 Old 12-02-2013, 03:51 PM
riffer's Avatar
"passthrough" Cable Box > Colossus > HDTV The signal is unaffected by the computer; the computer doesn't even have to be on (it does have to be plugged in) for me to watch TV.
post #544 of 561 Old 02-01-2014, 11:25 AM
aab1's Avatar
Quoted: 21 Post(s)
I've been using my Colossus for a few weeks an it works great except every now and then it seems to miss the first digit of the channel when IR blasting it to my cable box. I don't know if it's a coincidence but it seems to occur mostly on shows that should record on channel 602, the box often ends up on channel 2 instead, as if it missed the first digit.
Is this a known issue? When I bought the Colossus someone I beleive on these forums recommended I not use the included IR blaster, is this why I was told that and what are the alternatives and how do you configure WMC to use the new blaster if I end up getting one?
aab1 is offline
post #545 of 561 Old 02-01-2014, 01:58 PM
WaltN46's Avatar
Are you using only WMC to record? I have used both WinTV7 and NextPVR and have not had any issues with the blaster. Run blast config and make sure that you have the correct box set. Also, if you click the "Advanced Config" button, you can fiddle around with the delays. Maybe that would help.
WaltN46 is offline
post #546 of 561 Old 02-19-2014, 02:55 PM
ryancharles's Avatar
Based on the this thread I think what I want to do will work, but I wanted to double check before I buy stuff.
Currently I have an XMBC running on windows 7, which connects to my TV via hdmi. My movies sit on a QNAP NAS. Now I have read that NEXTPVR can be used as a good recording back-end, while XBMC can be used as a front end. I am wondering if anyone else is using this particular setup, or if you could recommend another app.
I am with Rogers and have an HD Cable BOX.
I was looking at purchasing a hauppauge colossus card. My goal is to be able to record SD and HD TV as per a schedule and then play back the content via XBMC or NextPVR
My current setup is the following:
Scientific Atlanta Cable Box -> (Coax cable) Rogers HDTV Box-CISCO 4642HD (HDMI)-> Samsung TV
New setup
Scientific Atlanta Cable Box -> (Coax cable) Rogers HDTV Box-CISCO 4642HD (HDMI|Component)-> XBMC BOX with Colossus card (HDMI)-> Samsung TV
My questions are:
1) Would this setup work?
2) Should I use the HDMI or component input on the Colossus card?
3) The HDMI out on the XBMC box is actually a Nvidia GeForce 610 card, which is what I use to stream MKV blu-ray rips from my QNAP NAS to my samsung TV. Would this be adequate?
4) Any recommendations regarding ir blaster that will work?
Thanks in advance.
ryancharles is offline
post #547 of 561 Old 02-19-2014, 03:48 PM
riffer's Avatar
For what it's worth, I have Cisco 4642HD>Component Video Cable>Colossus>Component Video Cable>HDTV and that works.
Also, last time I tried it, the Rogers Cisco 4642HD would not output to both the the component and the HDMI at the same time, if that is a factor.
I still use the crappy WinTV, and my HTPC runs Windows 7, so I can't help much on the rest. Trying a PVR software is on the "to do" list, so if you do try NEXTPVR, please post.
As an aside, why do you have one cable box going into another?
New setup
My questions are:
Thanks in advance.
All I can say
post #548 of 561 Old 02-19-2014, 05:01 PM
hey riffer,
Just out of curiosity as this is pretty new to me. What do use your setup for if not for recording? Just curious.
How the quality with HD channels?
I don't have an issue using component instead of HDMI.  Do you know if I would be able to do this:
Cisco 4642HD>Component Video Cable>Colossus>HDMI from nvidia 610 card>HDTV? I still want to be able to leverage the nvidia graphics card as my onboard cpu isn't powerful enough to stream my content. I imagine this should work, but just curious.
If you're using component. How do you get the audio to the hauppauge card and then from the PC to the TV?
Also, does the colossus come with a blaster and if not, any recommendation on what to buy? Also, does all the software I need come with the card?
I will surely be posting to document my progress and help other people out. It'll be sweet if it works.
post #549 of 561 Old 02-20-2014, 06:01 AM
WaltN46's Avatar
New setup
My questions are:
Thanks in advance.
Colossus works with NextPVR. I use it. The only issue I have is Live TV, which doesn't seem to work particularly well with Colossus in the current 3.1.1 release (channel changing is hanging). Scheduled recording works fine. You can use WinTV7, that comes with colossus, for Live TV. WinTV has no built in guide, so they try and link it to the Titan TV service. This sort of works, but I have found NextPVR is more reliable at recording than WinTV. NextPVR is not a commercial product, so it may take a bit of patience to get it setup. I don't use XBMC. NextPVR is sufficient for what I need, which is basically an on screen guide and recording. I don't know about your cable box. I have a Verizon FIOS Motorola box, and it can output component and HDMI simultaneously, so there is no issue. It also has SPDIF audio out, which I use. If you use RCA type audio, colossus will not give you Dolby Digital surround. You need to set your cable box to ALWAYS output HD video. I think most of them have this setting. Colossus and NextPVR (and WinTV7) will have issues if you are switching between HD and SD output. Colossus, in particular, does not do a good job with SD video in my experience.
HDMI is subject to rights management. If you don't want this hassle, you'll need to go with component video out. Depends on what you plan to record.
Colossus comes with a blaster (at least mine did). You don't actually need to buy an additional one. Your computer will need to be fairly close to your cable box.
Can't comment on your 3. because I don't have that box. Sounds as if it should work fine though.
WaltN46 is offline
post #550 of 561 Old 04-13-2014, 03:35 PM
aab1's Avatar
Quoted: 21 Post(s)
Although it's a rare event, sometimes my Hauppauge Colossus will tune my cable box to a channel missing the first digit (which luckily in most cases is the same channel in non-HD), for example the box ends up on 64 instead of 664, or 6 instead of 606, etc.
As soon as I bought the Colossus I was recommended to avoid the included IR blaster, is this a common problem with the Colossus' IR blaster?
Is there a fix for it and if not what alternative blaster do you recommend that I can use with WMC and the Colossus card?
Thank you
aab1 is offline
post #551 of 561 Old 04-22-2014, 11:37 AM
rds11's Avatar
Anybody using TMPGEnc Authoring Works 5.0 to author Colossus captures to blu-ray discs ?
I have a HD-PVR 1212, but TMPGEnc always wants to reencode 1080i video files I capture with the Hauppauge 1212 because it's not fully blu-ray compliant. I'm hoping that the captures from the Colossus are compliant, and thus wouldn't need to be re-encoded in order to be archived to disc.
Or maybe someone could provide me with a short sample of a 1080i capture so I can test it ?
rds11 is offline
post #552 of 561 Old 04-23-2014, 05:01 AM
WaltN46's Avatar
I'm no expert on this, but the Colossus always records to TS files. I don't think that TS files can be burned without some kind of transcoding, or at least being put into a different container.
WaltN46 is offline
post #553 of 561 Old 04-25-2014, 08:36 PM
dj4monie's Avatar
Thank you
If your using WMC, you can change change over your network. You'll have to Google for it and Missing Remote is likely the best place to find that information now.
A. Thomas -
GSN: djfourmoney
'03 SRT-4 12.74@106 in the 1/4
PSN - DJFourMoney
dj4monie is offline
post #554 of 561 Old 06-29-2014, 08:35 PM
Billanderson's Avatar
Colossus HDMI/Component
I have a Hauppauge Colossus video capture card installed and working in my computer. I learned a couple of years ago when I installed the Colossus that if I used an HDMI cable to connect to my set top box (it was some sort of Motorola provided by RCN Cable), many channels were blocked by HDCP, but if I used component cables everything was fine. So I used component.
Now I have moved to another city and I have an Xfinity box in my living room connected to my big flatscreen, and I have a secondary, smaller Xfinity box in another room connected to the Colossus. The secondary Xfinity box has component output and it's working fine with my Colossus -- no HDCP problems.
But for a couple of reasons I want to build a second desktop computer using parts I already have -- yes, I have everything I need except a computer case -- to sit in my living room and serve as a multimedia device that can use my flatscreen as a monitor and share captured files via WiFi with my main computer in another room. This would mean, among other things, I would no longer need to pay for a secondary Xfinity box, as I would install the Colossus in the new computer and capture video directly off the main Xfinity box.
But...the main Xfinity box doesn't have component output -- just HDMI. So what to do?
Suppose I tried to use HDMI out of the Xfinity box -- Does anybody know whether I'd experience the same HDCP problems I experienced with the RCN Motorola box? I'll bet I would.
So...
I have seen HDMI to component converter dongles. If I were to purchase one, I wonder whether the component output from it would give me HDCP problems in the Colossus? Or since the signal would be passing through the Colossus's component circuits, would the Colossus just let the signal through as it does now with real Component input?
I need to know the answer before I invest in a new computer case.
Help anybody? Thanks.
Billanderson is offline
post #555 of 561 Old 07-05-2014, 01:38 PM
Liked: 0
hello I have a colossus for some time the tiny encoder has diparu archsoft in showbiz despite having reinstller the driver he can not believe it so I just not adjust the bitrate of my caputre
doysy is offline
post #556 of 561 Old 09-23-2014, 07:44 AM
rds11's Avatar
Just a quick update on the subject of TMPGEnc Authoring Works 5.0: I bought the Colossus, and I can confirm that all recording done at 1080i and 720p with the Colossus will smart render with TMPGEnc Authoring Works 5.0.
1080i recordings done with the 1212 HD-PVR do not smart render on TMPGEnc Authoring Works 5.0 because the encoder use a GOP size above the blu-ray standard (the 1212 GOP size is 64, while the blu-ray maximum is 60).
madmadworld likes this.
rds11 is offline
post #557 of 561 Old 12-26-2014, 09:37 AM
etete's Avatar
Is there any possibility of tweaking either the registry or cap app .ini files in effort to raise the capture bitrate of Colossus (as can be accomplished with some other cards)? While I'm satisfied with the quality of VBR (& CBR) on-the-fly encoding there are times I'd like to perform editing (aside from simple commercials/scene culling) requiring encoding and any additional headroom I can achieve would be very beneficial prior to introducing yet another lossy step.
etete is offline
post #558 of 561 Unread Today, 11:36 AM
billmich's Avatar
Quoted: 129 Post(s)
Liked: 39
All of a sudden my colossus is not "capturing" any video and all the setting have been grayed out.
This was discovered by me late last night and i didn't have a chance to do too much troubleshooting.
Tonight I will hook up the component cabled from my DVR to another TV set and ensure that the signal is being properly outputted. If it isnt, then I turn my attention to the cable box,
but if it IS....what type of internal setting might i want to take a look at? Is there any type of diagnostic that I should run;
perhaps uninstall and re-install the software?
I was led to this because my home run prime tuner was not working last night (Thur),after working perfectly on Wednesday night. and I didnt change a thing at all from oe day to the next and I know the colossus is not dependent on any external issues like Comcast cable
any hints and suggestions would be most appreciated
thank you
billmich is online now
post #559 of 561 Unread Today, 12:49 PM
CountryBumkin's Avatar
Quoted: 74 Post(s)
Liked: 26
I have a Colossus - and will be testing this in a few days - as I just ordered a HDMI splitter that (reportedly) removes HDCP. I am running my FireTV into the Colossus now and it works with HDMI but the Netflix shows won't play due to HDCP.
Also, the Genfen HDMI Detective Plus http://www.amazon.com/Gefen-EXT-HDMI...keywords=gefen removes/strips the HDCP too, but it cost more ($82 vs. $24), so I ordered the ViewHD switch. This: http://www.amazon.com/ViewHD-Port-Po...RHB3HVGGEHVRT2 the reviews on the Amazon site say it removes the HDCP.
CountryBumkin is online now
post #560 of 561 Unread Today, 12:57 PM - Thread Starter
SHS
SHS's Avatar
Quoted: 13 Post(s)
What grayed out?.
Check cable box first to a TV to insure it working
Check the device manager for non working device
Try power the down the system remove it power up that back down and reinstall the device see if that helps any.
If that still a no go test in a diff system, If that still a no go then more then likely it die on you.
SHS is online now
post #561 of 561 Unread Today, 01:01 PM - Thread Starter
SHS
SHS's Avatar
Quoted: 13 Post(s)
That will be the case with Netflix and other even Sat, Cable that automatic enable HDCP on the fly or have it on all the time.
I have that ViewHD ir work just fine
SHS is online now
Reply Home Theater Computers
