Hauppauge Colossus HD-PVR - Page 21 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #601 of 607 Old 02-22-2016, 05:49 AM
Phillip Chapman's Avatar
I have an original Hauppauge Colossus internal PCIe card. Is the card compatible with Windows 10 either with Showbiz or the new Hauppauge Capture program?
I tried installing the latest drivers on Windows 10 but the installer said it couldn't see the serial number on the device and wouldn't install. I was able to install an older driver (via Device Manager) using the inf files and browsing to the driver directory. The card would capture but there's a lot of buffering as the card is struggling to keep up. The card runs fine on the same hardware with Windows 7.
Thanks for any feedback you guys can provide especially if you've successfully installed a Hauppauge Colossus on Windows 10. The Hauppauge website doesn't say the card is supported with Windows 10 on their website, but the info may just be outdated.
Phillip Chapman is offline
post #602 of 607 Old 02-22-2016, 05:58 AM
MozartMan's Avatar
I have original Colossus card. I installed it on my HTPC some time ago when I had Windows 7 Enterprise. I upgraded to Windows 10 Pro last November. I didn't re-install any driver.
I didn't do long capture yet, but short capture tests worked good after upgrading to Windows 10. I use Showbiz. I tried Hauppage Capture program but I had problem with sound.
Did you do clean install or upgrade to Windows 10?
MozartMan is offline
post #603 of 607 Old 02-22-2016, 11:09 AM
It was a clean install which is why there was difficulty installing these drivers in Windows 10: Colossus_Driver_1_8_31093_0.exe. The installer is an *.exe file which would run but it would not detect the serial number on the card and then halt installation.
post #604 of 607 Old 02-22-2016, 11:18 AM
MozartMan's Avatar
Do you have original CD/DVD that came with Colossus?
I would suggest that you install all software from original disk and then run that EXE file with updated drivers.
I think when you install software from original disk it puts serial number somewhere in the registry.
Also, I am sure that EXE file with updated driver doesn't have Showbiz and other stuff.
post #605 of 607 Old 05-07-2017, 02:28 PM
nikknightt's Avatar
Quoted: 72 Post(s)
Liked: 27
1310000-03 with PCI Extender
I'm looking at a Colossus 131201 LF Rev. C1 1511 1310000-03.
Will this card work with a USB 3.0 PCI extender?
Are there any issues with this version of the Colossus?
I'm able to capture 5.1 audio with my 1512 via HDMI - Will the Colossus do the same?
Thanks..
nikknightt is offline
post #606 of 607 Old 05-07-2017, 02:36 PM - Thread Starter
SHS
SHS's Avatar
Quoted: 64 Post(s)
I'm able to capture 5.1 with my 1512 via HDMI - Will the Colossus do the same?
Thanks..
No idea you have try a USB 3.0 PCI extender as I never heard of any that has
Both Colossus 1 and 2 can captured 5.1
nikknightt likes this.
SHS is offline
post #607 of 607 Old 05-07-2017, 02:43 PM
nikknightt's Avatar
Quoted: 72 Post(s)
Liked: 27
Thanks for the input.. I have a low profile PC case..
Just to be clear, The extender I'm referring to is like this one:
https://www.amazon.com/GBSELL-USB3-0...b+3.0+extender
Reply Home Theater Computers
