Building an HTPC that can control my theater - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-11-2010, 08:31 PM - Thread Starter
pjpoes's Avatar
I'd like to put together an HTPC that can handle all of my music, control my other gear (Oppo Blueray player, Roku Netflix, Pre/pro, projector, etc), and be controlled remotely by an iPad as my remote. What do I need to do this? I don't need a complete rundown on the HTPC itself, but what devices, if any, are available to allow the IR control for those devices that don't have RS232? What software is available to integrate the IR and RS232 commands in the same ways that say an Control4 or Crestron device can do?
Would I be better served trying to integrate an HTPC with a Control4 controller and their iPad control?
pjpoes is offline
post #2 of 4 Old 12-11-2010, 09:34 PM
Bojangles139's Avatar
well, for your music, if you ok with using iTunes, use their remote app. its pretty snazzy. the UI acts just like when your browser music on a touch.
the remote app is done over your wireless network.
infrared is infrared. the source doesn't rly matter, just the command code (the ir blinks).
you could use any IR program out there. it may have preloaded ir commands for your equipment or you should be able to teach it. just need to find one that you like.
unless you want a fancy UI, i might suggest a logitech remote. they work great. i tried using my touch as remote. wasn't a big fan. hard to use in dark room, have to look at it to change any controls (a remote you can run your thumb/fingers over the buttons), and distinct lack of rly nice looking UI's on the apps i found.
but for music control, nothing beats a itunes + touch + remote app.
Bojangles139 is offline
post #3 of 4 Old 12-11-2010, 11:58 PM
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
Well....this gets into the complex territory, but it's doable.
Depending on your budget/time/patience etc etc, you could get a USB-UIRT + girder to control your other devices. Any automation not offered via girder could potentially be done via Autohotkey or something similar.
Now, as far as using an iPad as your "remote", of course is doable, it's just a question of how far does the integration go. It'll also depend on what your main media software is, and how well it plays with the iPad controller software. You may be in for some custom programming.
kapone is offline
post #4 of 4 Old 12-12-2010, 08:36 AM
potts.mike's Avatar
You will probably find a lot more help at www.cocoontech.com.
I personally use a program called cqc that integrates all my different hardware into one point of control and has an ipad interface.
potts.mike is offline
Reply Home Theater Computers
