Media Player Classic Problems - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 12-15-2010, 08:51 PM - Thread Starter
david_nc's Avatar
I use Media Player Classic to watch ripped BD's and DVD's. Tonight, I tried to watch Avatar after ripping it to a MKV file. It started but had no video. I rebooted and tried again. This time, it played fine, but there are no controls in MPC... by that I mean the skip, pause, play, stop, etc 'buttons' are all missing. Instead, I have a blue progress bar with a blue square for the indicator. The sound and video work fine. The only way I can exit the program is with ALT+F4. I rebooted and tried a couple of DVD rips that I played last night (when MPC was working fine.) I cannot get it working properly now. I'd love to hear any ideas or suggestions on how to get this back to working again. Thanks!
System specifics:
Win7 Enterprise (32-bit)
Asus 5550 HD (ATI) video card
Media Player Classic - Home Cinema 1.4.2758
ffdshow
david_nc is offline
post #2 of 12 Old 12-15-2010, 09:44 PM
Nimo's Avatar
Sounds like you have D3D FullScreen enabled, as far as the navigation menus and such just re check them in the view menu.
Nimo is offline
post #3 of 12 Old 12-16-2010, 08:16 AM - Thread Starter
david_nc's Avatar
I'll check the settings again, but I did have those selected in the view menu. Thanks.
david_nc is offline
post #4 of 12 Old 07-06-2012, 08:39 PM
adrift's Avatar
Sorry for resurrecting an old thread. This is going to sound really stupid, but is there a way to turn off the On Screen Display (OSD) in Media Player Classic? I have no idea how, but somehow it turned itself on by accident. Per dozens of returns on Google I went to Options/Player/Other/Show OSD, but the option there was already non-ticked. What the heck is going on??
adrift is offline
post #5 of 12 Old 07-06-2012, 10:44 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 911
CTRL-j ?
adrift likes this.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #6 of 12 Old 07-07-2012, 07:09 AM
adrift's Avatar
Originally Posted by olyteddy View Post
CTRL-j ?
Wow. I feel like an idiot, but that fixed it. I still can't believe there was absolutely no hint on how to turn on/off the OSD on any of my Google searches. Maybe my Google-fu was weak with this one.
adrift is offline
post #7 of 12 Old 07-07-2012, 05:31 PM
Pagali's Avatar
Quoted: 12 Post(s)
I might be wrong on this, but I'm thinking that Ctrl-J is the command to turn on/off MadVR's Information OSD, not MPC-HC's. Maybe that's why you didn't find the info easily?
Pagali is offline
post #8 of 12 Old 07-07-2012, 05:48 PM
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
I never saw OSD for MPC-HC, how do you turn that on/off?
Mike99 is offline
post #9 of 12 Old 07-07-2012, 05:50 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 911
http://www.avsforum.com/t/1298535/media-player-classic-problems/0_40#post_22197314
olyteddy is offline
post #10 of 12 Old 07-08-2012, 01:41 AM
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
That says "Ctrl-J is the command to turn on/off MadVR's Information OSD, not MPC-HC's". That would mean there are 2 different types of OSD. Ctrl-J does nothing for me.
Mike99 is offline
post #11 of 12 Old 07-08-2012, 04:46 AM
steelman1991's Avatar
Quoted: 211 Post(s)
Liked: 116
It's also the control to turn-off/on mpc-hc's Info OSD - but I think it depends which Outpout method you use whether or not it will display. - I think it only works with EVR Sync or EVR Custom Pres.
steelman1991 is offline
post #12 of 12 Old 07-08-2012, 01:47 PM
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
I just use MPC-HC once in a while to view a video, usually mpeg2 or vob.
Mike99 is offline
Reply Home Theater Computers
