What am I doing wrong--Choppy audio? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 12-28-2010, 06:41 AM - Thread Starter
sloaniebaloney's Avatar
I have a legally owned copy of Goodfellas on BluRay. I am using the Bluray as a testbed before I buy more. What I would like to do is make a backup of the Bluray, store it on my PC and then serve it to perhaps Popcorn Hour's NMT, assuming I can get this to work.
I have a dual boot iMac computer with Win 7 on one partition and Snow Leopard on the other. I use the Windows partition to try to make a backup. My goal is to back up to a 2TB HD (FAT32) and then serve movies from the other partition, Snow Leopard.
Every time I make a backup of the movie, the video plays okbut the audio is choppy. I test the playback through Cyberlink's PowerDVD.
Here is the process I use.
1) I have AnyDVD running in the background.
2) I start TSRemux
3) I specify the source file to 00000.m2ts on the bluray disc, which is the largest file
4) I specify the destination which is on the 2TB FAT32 HD
5) I pick the only video stream listed which is VC1
6) I pick the audio stream 0, which I believe is Dolby Digital 5.1
7) I choose M2TS as the output format
I have tried this process twice, once with the Bypass Audio alignment option checked and once with it not checked; the result is the same.
I click Remux and wait.
When it is done, I load the new m2ts into PowerDVD and play it. The video comes across ok initially but the audio is choppy. Also, if I move further into the stream both the audio is choppy and the video seems to stutter, kind of like it can't catch up.
My conundrum is that I don't want to spend $300 for something like Popcorn hour if this isn't going to work. I've always wanted a media server to store my backups, but if it's not going to work I might as well just pop my owned blurays into a bluray player.
Any help or instructions as to what I'm doing wrong, or how to get this to work would be greatly appreciated.
sloaniebaloney is offline
post #2 of 9 Old 12-28-2010, 08:28 AM
Andrew Hornfeck's Avatar
Quoted: 31 Post(s)
I don't do BR so I can't comment directly... I was expecting an issue with choppy playback, not a question of how to properly rip a BR disc. I'm sure there are plenty o' posts on the subject...
Andrew Hornfeck is offline
post #3 of 9 Old 12-28-2010, 08:42 AM
audit13's Avatar
Quoted: 37 Post(s)
Liked: 33
Have you tried just ripping the entire movie with AnyDVD to your hard drive and using your computer to make sure everything is okay?
You may have to format the drive as ntfs if you want to store m2ts files in excess of 4 gb in size.
audit13 is offline
post #4 of 9 Old 12-28-2010, 09:41 AM
Serra's Avatar
2) I start TSRemux
That all just seems wrong... and a lot of work. Plus, storing BD on HD is just really expensive, space wise. Seems like it might be easier to drop the BD into the player when you want to watch it, as you suggest.
From my personal experience, BD take a ton of space and while I do watch mine using a method like what you are talking about, I never seem to have enough space to store more than a handful and any one time. Mostly I burn them to the HD, watch them and delete them for space later. If you are talking about only 2TB of space, you'll find you will not have much of a library, more like a stack.
As for the choppy audio, BD is a huge bandwidth hog. You might need to use NTSF and larger sector size to get it to work, then BD is a huge processor hog too and tough on video. The whole thing can get expensive PC wise.
The whole popcorn hour thing sounds wonderful, but my experience has been that for DVDs it would have been awesome, for BD, not so wonderful, because before you know it you've got 30TB of disk drives for your video library and still trying to find room for just a couple of more BD....
Serra is offline
post #5 of 9 Old 12-28-2010, 06:01 PM
wraslor's Avatar
any reason you're not just ripping to mkv? using something like makemkv?
wraslor is offline
post #6 of 9 Old 12-29-2010, 06:10 AM - Thread Starter
Thanks for all of your responses.
First off, Serra, what you say makes perfect sense. At this point, it's more of a "I want to get it to work" rather than is it feasible to backup my collection this way. For me, I bought a 2 TB drive for $120 which should hold roughly 70 movies. I plan to buy only the movies that I wish to view more than once, this might be around 200 or so, so 3 2TB drives in not cost prohibitive for me.
Also, last night I reformatted my HDD and reran TSRemux and had the same issue. Basically what happens is that Goodfellas starts out with great audio and video in sync for the credits and the opening of when they're in the car but once they get out of the car the audio and video becomes choppy. When I relocate the stream to farther in the movie the video is in slow motion and the audio is still choppy, again, like it's trying to catch up. This is frustrating to me. Like I said, it's more of a personal goal to get this working than a feasibility issue. The movie plays fine from the BD drive and I can't imaging that the HDD would be slower.
Tonight I will troubleshoot more to see if I can just play the original m2ts on my computer. I believe I was able to do this...play it from the BD drive with AnyDVE and without remux and it worked fine. I'd like to say it is something I'm doing wrong with TSRemux, but I have no idea what. There's not very many options, at least in the GUI, not sure if there's a CLI or not.
Wraslor, or anyone else...what is the benefit of using makemkv over TSRemux? Do you think this will solve the issue? I'd certainly give it a try. Is there any difference in quality...my assumption is that MKV is just another container so quality depends upon the formats in the container...but why would that possibly work over m2ts?
Thank you all.
post #7 of 9 Old 12-30-2010, 02:09 PM
wraslor's Avatar
I was thinking it may be a codec issue and using mkv would help eliminate that as a possibility. As far as I know you should be ok with mkv it can still carry 1080p and hd audio. Maybe give a shot just to see?
wraslor is offline
post #8 of 9 Old 01-02-2011, 08:20 AM - Thread Starter
Actually, this was very simple and I feel dumb for not figuring this out sooner. My HDD is plugged into the USB port on my G15 keyboard...I am out of USB ports even with a hub. Of course, the G15 only supports USB 1.0, ugh. I swapped it with another cable, the HDD now going through USB 2.0 and everything plays back find using Power DVD.
Thanks for all your help.
post #9 of 9 Old 01-02-2011, 10:34 AM
Quoted: 31 Post(s)
Glad you've got it figured out!
Speaking for myself, at 2TB I'd believed it was a SATA HDD and after rereading the thread saw NO MENTION of how you had it connected. Often it's the little things we forget to mention in our configuration that cause the biggest grief!
Reply Home Theater Computers
