Assassin's Simple/Beginner HTPC Buying Guide - Page 325 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
post #9721 of 15974 Old 01-19-2012, 05:05 PM
Skylark's Avatar
Originally Posted by assassin View Post
Installed the 80GB Intel SATAII SSD into my laptop today that I got for $80 AR.
Its like a whole new machine. In case I forgot how awesome these things are I just reminded myself.
Was that in addition to an internal spinner? Or is that the only storage drive "internal" to the laptop and you're running external spinners?
Sky
Skylark is offline
post #9722 of 15974 Old 01-19-2012, 05:10 PM - Thread Starter
assassin's Avatar
Quoted: 170 Post(s)
Liked: 275
Sky
Took out a 500GB Seagate Momentus.
Replaced it with the Intel SSD.
This is in my ASUS CULV laptop (1.3 GHz Intel Core 2 Duo)
assassin is offline
post #9723 of 15974 Old 01-19-2012, 05:35 PM - Thread Starter
assassin's Avatar
Quoted: 170 Post(s)
Liked: 275
This is why I recommend the 60-64GB size as the smallest you should get (also that's the smallest SATAIII SSD that is available)
I have Windows 7 x64, all updates, Microsoft Office installed. No HTPC software yet. So as you can see 30GB is too small and 40GB cuts it really really close.
60-64GB is just about right for HTPC.
Edit: Just realized that I have about 7GB of misc. crap from my old drive on the SSD as well. So subtract that from the total above.
Oh, and Windows just found 16 more updates. So apparently I am not done there either.
assassin is offline
post #9724 of 15974 Old 01-19-2012, 05:43 PM
Skylark's Avatar
Quite a difference going from a 500GB to an 80GB. Those Western Digital Passport external drives that get power from the USB port sound like a good way to get the additional storage without too much transporting hassles.
Skylark is offline
post #9725 of 15974 Old 01-19-2012, 05:47 PM - Thread Starter
assassin's Avatar
Quoted: 170 Post(s)
Liked: 275
Actually I forgot that I have about 7 GB of stuff from my old Seagate drive on the SSD as well.
I don't need a lot of storage on the laptop with my server, desktop, numerous other HTPCs, etc.
assassin is offline
post #9726 of 15974 Old 01-19-2012, 06:24 PM
ShoutingMan's Avatar
Quoted: 252 Post(s)
Liked: 52
Is the SSD beneficial in a machine running 24/7 as a dedicated media computer / DVR?
Are there any recommended HTPC cases that hold three internal drives (and at least one external bay for a blu-ray)?
ShoutingMan is offline
post #9727 of 15974 Old 01-19-2012, 06:36 PM - Thread Starter
assassin's Avatar
Quoted: 170 Post(s)
Liked: 275
SSD is not necessary but is a very nice luxury to have. Once you use one you will never want to go back.
For affordable cases holding at least three drives take a look at the NMedia cases. They are very large.
The GD04/05 Silverstone cases only hold 2 hard drives and 1 ssd.
assassin is offline
post #9728 of 15974 Old 01-19-2012, 06:53 PM
thefever's Avatar
Got my motherboard in today. Just finished doing a clean install of 7. Was curious about the stability of Media Center Studio. Last time I installed, it was the messed up version of it, and WMC wasn't the same afterwards.
thefever is offline
post #9729 of 15974 Old 01-19-2012, 07:03 PM - Thread Starter
assassin's Avatar
Quoted: 170 Post(s)
Liked: 275
My experience has been variable with it.
I wish the developer would come back or at least hand it off to someone. This is why for some pieces of software I am all for throwing the developer a few bucks to keep them interested. MCS would be one of those pieces of software that's worth a few bucks as gratitude.
assassin is offline
post #9730 of 15974 Old 01-19-2012, 07:42 PM
Zon2020's Avatar
I took out a 350gb hard disk and replaced it with a 64 gb ssd, but for that laptop, that's plenty, and I only had about 28gb on it. For another laptop I used a 128 because it had about 70gb of data (my wife's iTunes files). We have plenty of desktops, so our laptops are used for portability and travel and not for data storage so we don't really need that much storage space. If I need temporary storage a big flashdrive will suffice. But a 128 will generally be more than enough for a laptop for me. If you're using a laptop as a primary PC, that's probably not going to work for you.
Zon2020 is offline
post #9731 of 15974 Old 01-20-2012, 01:56 AM
amitkr's Avatar
Excellent thread..will be starting my build soon
amitkr is offline
post #9732 of 15974 Old 01-20-2012, 04:27 AM
joeydrunk's Avatar
Quoted: 14 Post(s)
I'm down to 2gb remaining in my 64gb SSD
joeydrunk is offline
post #9733 of 15974 Old 01-20-2012, 06:08 AM
rodg1984's Avatar
I looked at this using Google Chrome and can verify that both of those files are there and functioning as intended. Try a different browser if you can't access them for some reason.
I got them downloaded. Not sure if it was an error on my part or my browser. Whenever I single left click each file it opens a new tab with info like I had mentioned, but once in that new tab I can right click and "save target" and it seemed to have worked. So, I seem to be back on track now. Thanks again for checking!
rodg1984 is offline
post #9734 of 15974 Old 01-20-2012, 07:20 AM
cburbs's Avatar
Quoted: 94 Post(s)
Liked: 29
I just put a 120gb in mine as well - it's like a new machine.
"You’re KILLIN’ ME Smalls! "
Sony 55EX500 Settings
cburbs is offline
post #9735 of 15974 Old 01-20-2012, 07:21 AM
cburbs's Avatar
Quoted: 94 Post(s)
Liked: 29
you might want to clean that up a bit.
cburbs is offline
post #9736 of 15974 Old 01-20-2012, 07:25 AM
krooooog's Avatar
OK. I got everything installed and most of the software up and running. Everything looks and works great so far. Thanks to Assassin and his guides!
One "hardware" question. I'm trying to do all my configuring on a monitor rather than using the connected projector. However, I've noticed that if the HDMI cable is connected to the PC, the video automatically switches to the Projector and the LCD monitor just shows the wallpaper. Is there any way to toggle the monitors? I've tried Windows-P but that doesn't seem to do anything.
Software-wise, I'm up to the point where I am setting up Windows Media Center and trying to install the Netflix plugin. I get to the 55% installation and it fails, as reported in Guide #4... however, no matter what I do, Netflix doesn't appear in WMC. I've tried reinstalling, rebooting, installing Silverlight separately, and nothing seems to work.
Suggestions?
-Tim
krooooog is offline
post #9737 of 15974 Old 01-20-2012, 08:32 AM
mariob33's Avatar
Quoted: 95 Post(s)
Liked: 76
Send a message via Skype™ to mariob33
Suggestions?
there is a WMC update/download you need to run and then it shall show up. there are two fix options
Open Media Center, choose Settings, General, Automatic Download Options, and ensure that the 'Download when connected' is enabled. The Netflix tile will appear after the next Media Center Guide download time has passed.
2. Open Media Center, choose Settings, General, Automatic Download Options, and select the Download Now button at the bottom. It may take some time depending on your connection speed.
In search of video bliss...
mariob33 is online now
post #9738 of 15974 Old 01-20-2012, 10:44 AM
Tizi's Avatar
You can get more space back by turning off hibernate at the DOS promt, reducing the size of the virtual memory, and limiting how much Windows uses for recovery.
Tizi is offline
post #9739 of 15974 Old 01-20-2012, 10:54 AM
n3x6's Avatar
Hey Assassin,
Just wanted to say thanks for all of the excellent work on your guides. Huge fan and supporter. I have been looking through various forums discussing Media Browser and XBMC, and notice you have guides that cater to both and each have its merits.
So I definitely won't ask which one is better, but I am curious what your thoughts are on the Aesthetic aspects of both are. From your perspective do you prefer one over the other?
Also just on a side note, are you still using Media Browser as your primary front end?
n3x6 is offline
post #9740 of 15974 Old 01-20-2012, 11:02 AM
joeydrunk's Avatar
Quoted: 14 Post(s)
Not at all, I know.exactly what's in There
post #9741 of 15974 Old 01-20-2012, 11:04 AM
joeydrunk's Avatar
Quoted: 14 Post(s)
Edit: cleaning I do periodically but I have every thing there I want
post #9742 of 15974 Old 01-20-2012, 11:16 AM
krooooog's Avatar
Thanks.... That worked!
-Tim
krooooog is offline
post #9743 of 15974 Old 01-20-2012, 12:06 PM - Thread Starter
assassin's Avatar
Quoted: 170 Post(s)
Liked: 275
Originally Posted by n3x6 View Post
Hey Assassin,
I really like both. I have been using XBMC lately because I have been doing some testing on it.
I have both installed. I think its really a personal preference which you like better. Both are absolutely awesome.
assassin is offline
post #9744 of 15974 Old 01-20-2012, 12:58 PM
mongoosenco's Avatar
Was throwing some parts together for an HTPC and want to use for some gaming as well. How does this look so far?
SAMSUNG EcoGreen F4 HD204UI 2TB SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Seasonic SS-560KM Active PFC F3, 560W ATX12V V2.3/EPS 12V V2.91, 80Plus Gold Certified, Modular Power Supply
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
ASUS Maximus IV Gene-Z/GEN3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 ...
LITE-ON Black 12X Blu-ray Burner with Blu Ray 3D Feature SATA IHBS112-04 - OEM
Mushkin Enhanced Chronos Deluxe MKNSSDCR120GB-DX 2.5" 120GB SATA III MLC Internal Solid State Drive (SSD)
SILVERSTONE Black 8.0mm aluminum front panel, 0.8mm SECC body GRANDIA GD04B Micro ATX Media Center / HTPC Case
I Still need to pick a graphics card and maybe a CPU cooler. Anyone have anything they would change? What graphics car would you recommend that will fit in that case?
mongoosenco is offline
post #9745 of 15974 Old 01-20-2012, 01:04 PM - Thread Starter
assassin's Avatar
Quoted: 170 Post(s)
Liked: 275
Looks like a great build. Just make sure that Seasonic PSU will fit without having to remove one of the fans.
I think the max video card length is 11" with 10" being preferred.
assassin is offline
post #9746 of 15974 Old 01-20-2012, 03:43 PM - Thread Starter
assassin's Avatar
Quoted: 170 Post(s)
Liked: 275
Here is an interesting link with a few videos for those interested.
LINK
assassin is offline
post #9747 of 15974 Old 01-20-2012, 03:56 PM
cpeisher's Avatar
My mouse pointer disappears when i have the Media Center Window maximized. When i have it in windowed mode i can see the pointer fine. I've gone to settings in Media Center and unchecked "always on top" but that doesn't help. How do i get my mouse back with Media Center in a maximized window?
cpeisher is offline
post #9748 of 15974 Old 01-20-2012, 04:02 PM - Thread Starter
assassin's Avatar
Quoted: 170 Post(s)
Liked: 275
Try this:
1]Open Control Panel.
2]Double click on Mouse.
3]Click the Pointer Options.
4]Uncheck the box against Display Pointer trails under the Visibility.
5]Click OK/Apply.
assassin is offline
post #9749 of 15974 Old 01-20-2012, 04:07 PM
cpeisher's Avatar
That's it! Thanks.
cpeisher is offline
post #9750 of 15974 Old 01-20-2012, 04:18 PM
cpeisher's Avatar
I'm having trouble playing certain mkv files from my collection, and i assume it's a codec issue. For most of the files in question i get a blank screen and choppy audio. Here is a screen shot showing the graph studio split, and the stats for the movie in media browser.
cpeisher is offline
Reply Home Theater Computers
Rosewill Windows Vista Certified Media Center Infrared Remote Control Rrc 126 , New Logitech Harmony One Keypad Touch Screen Advanced Universal Remote Control Infrared Display Lcd
