Assassin's Simple/Beginner HTPC Buying Guide - Page 384 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
post #11491 of 15974 Old 03-04-2012, 10:41 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I know for certain that Ivy has been confirmed working well in Asus GEN3 Z68 boards for couple months now from other forums including posts from people at both Asus and Intel so while I can speak about all boards and chipsets I do have significant faith it should drop into these specific Asus boards without much issue.
I would think Asrock z68 should also b compatible.
Mfusick is offline
post #11492 of 15974 Old 03-04-2012, 11:15 AM
Paul E. Fox, II's Avatar
Dude!!
It makes me proud to have my cruddy looking pics in your examples!!! What an honor!
Thanks for including me man! I couldn't have done it all with you and your guides
Originally Posted by assassin View Post
I know I have missed some but I tried to find as many as I could.
If I missed you please let me know...
Example PICS
Paul
Paul E. Fox, II is offline
post #11493 of 15974 Old 03-04-2012, 11:18 AM
mattiedread's Avatar
I considered waiting for the Ivy, increase in performance etc, lower power consumption... However, when I decided to go quad core (i5) I felt there was no real reason to wait as even the Sandy appeared to be more than adequate for my needs.
Are people seriously considering swapping out i3/5 Sandy's for Ivy's?
mattiedread is offline
post #11494 of 15974 Old 03-04-2012, 11:36 AM
mariob33's Avatar
Quoted: 88 Post(s)
Liked: 66
Send a message via Skype™ to mariob33
Maybe not i3/5 but perhaps a G to a i3 ivy. Once ll the kinks have been worked of course
In search of video bliss...
mariob33 is online now
post #11495 of 15974 Old 03-04-2012, 11:41 AM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
I am not upgrading. No compelling reason as of right now.
assassin is online now
post #11496 of 15974 Old 03-04-2012, 12:02 PM
Using just a Media Center Remote (the one which came with the DMA 2200) how can you switch the Recorded TV UI from Thumbnails to List?
I can not right click. I know there is a way, as I have done it before I just can't recall.
Edit: I got it, highlight a thumbnail and press 'i' (the information button), option box pops up.
post #11497 of 15974 Old 03-04-2012, 12:18 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
At some point I might... I like at least the option.
Mfusick is offline
post #11498 of 15974 Old 03-04-2012, 12:21 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Great!
post #11499 of 15974 Old 03-04-2012, 02:08 PM
LastButNotLeast's Avatar
Quoted: 1474 Post(s)
Liked: 1069
And so intuitively obvious.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
post #11500 of 15974 Old 03-04-2012, 05:32 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Really good deal after rebate.
Kingston HyperX 8GB DDR3 1333
$21 AR
http://www.frys.com/product/6618884
post #11501 of 15974 Old 03-04-2012, 06:12 PM
flocko's Avatar
$21 AR
Wishing HDD would come down to those price ratios . "Wish in one hand and crap in another and see which one fills up first "
Really nice find though !
flocko is offline
post #11502 of 15974 Old 03-04-2012, 06:41 PM
jrmac3's Avatar
I haven't been able to get the streaming working properly.
The things I have done was add extender formats as suggested in community.mediabrowser.tv and installed the Shark's Codec Pack.
I also checked a couple of media files using GraphStudio mentioned in Paid Guide 2.
What I see is for the Dark night the Video Input is "WMVideo Decoder DMO" and for Ratatouille it is "Microsoft DTV-DVD Video Decoder". They all had "Microsoft DTV-DVD Audio Decoder" not the "LAV Audio Decoder" as showen in Guide 2.
Any suggestions appreciated.
jrmac3 is offline
post #11503 of 15974 Old 03-04-2012, 06:43 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
PM sent.
post #11504 of 15974 Old 03-04-2012, 08:58 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
I went a little old school tonight (Paid Guides 1 tab) in creating guide #91.
Guide #6: Downloading Windows and installing from a USB or DVD
First, installing from a USB is lightning fast (about 7 minutes on my last test).
Second, you can legitimately download and install Windows while you are waiting on your Installation Disc or license number.
Finally, you can "test out" Windows in this manner without having to actually buy the product. This is great if you are on the fence having never used Windows before.
Enjoy!
post #11505 of 15974 Old 03-04-2012, 09:56 PM
lkstaack's Avatar
Originally Posted by dsc1000 View Post
I have a windows 7 ultimate 64 machine with a nvidia gt430 hdmi video card. I just tried to hook it up to my new Mitsubishi HC6800 projector. You can see the boot up and the windows logo but when it gets to the desktop the screen go blanks. Is it a frequency issue? Any help would be appreciated.
I'm having the same problem. HDTV was working fine last night, now I get a blank / black screen as soon as Win7 transitions to desktop. Is this the HDMI bug? Should I load the drivers Assassin posted last year? I was able to boot in basic safe mode (not to the other safe modes) and re-loaded the MS graphic drivers from 1/12/12 without effect.
Lars
lkstaack is offline
post #11506 of 15974 Old 03-04-2012, 09:59 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Did Windows install a new Display driver without you knowing (you don't let it auto update do you???). If so then try to roll back to the other driver that was working and never switch.
Alternatively you can try the drivers that I have listed to see if that helps. Make a restore point first.
post #11507 of 15974 Old 03-04-2012, 10:05 PM
lkstaack's Avatar
Thanks Assassin,
Yes, I checked the video driver and the option to roll back wasn't selectable. I directed it to the MS HD drivers I installed when I first installed my system, but the OS said that the drivers I had were the latest. I also restored from two days ago without effect. "The drivers you have listed"; are you referring to your guides? Should I check guide 2?
Lars
lkstaack is offline
post #11508 of 15974 Old 03-04-2012, 10:06 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Thanks Assassin,
I have that driver listed in my FAQ here at AVS.
post #11509 of 15974 Old 03-04-2012, 10:10 PM
jrock18's Avatar
First build starting soon. The items I purchased so far:
i3-2100 (weekend sale on newegg for $109.99...couldn't beat that!)
GIGABYTE GA-Z68MA-D2H-B3 z68
G.Skill 8gb (2 x 4GB) Ripjaws......I know, overkill
Antec Greenwatts 380 watt
NMedia 5000B
Corsair Force 60gb SSD
I still need to find a good deal on a 2tb internal drive and a blu-ray writer for the optical drive. Looking for feedback/opinons/suggestions on some.
Also, do most buy Win 7 OEM or the retail? Why would I buy the retail if I understand and can end user support Windows myself?
jrock18 is offline
post #11510 of 15974 Old 03-04-2012, 10:19 PM
lkstaack's Avatar
Going to try it now. Thanks.
Lars
lkstaack is offline
post #11511 of 15974 Old 03-04-2012, 10:38 PM
tomandbeth's Avatar
NMedia 5000B
IMO, good choice on the core components. If any quibbles it would be on the CPU as the 2105 has better on die grafics. If you don't expect to go 3D, may not be an issue. DO NOT FRET over that decision. (see posts on Ivy Bridge)
BTW, I have almost the same build- solid as a rock.
Ask yourself "Do I REALLY need a BR writer?" I just snagged a Asus BR reader for $50 shipped from the egg using the promo code. Most backups can be done either on an external hard drive or a netword device of some type (good use for an old computer).
As for the spinner, you're probably aware of the price spike since the flood. That said, WD or Sammy have been favorites in the 2T range. Some have pullled them out of external drive casings. You COULD just run an external drive using Esata, or look for a smaller SATA III drive for now, until prices become reasonable again.
I have used several Win 7 OEM. They are a good choice, with the only problem being that you can't move it to another build if you totally hose the one you're doing.
tomandbeth is offline
post #11512 of 15974 Old 03-04-2012, 10:39 PM
lkstaack's Avatar
OK, installed the old Intel HD video adapter driver, but I'm still getting a black screen after the initial Win7 splash screen. How do I trouble shoot this?
Lars
lkstaack is offline
post #11513 of 15974 Old 03-04-2012, 10:52 PM
tomandbeth's Avatar
One other slim possibility is that your board did an auto update and it reverted to using on board grafics. Since you can see the initial splash screen, go into BIOS and confirm that the first choice is the GPU card.
Yes it happened to me once upon a time.
post #11514 of 15974 Old 03-04-2012, 11:25 PM
lkstaack's Avatar
Hmmmm.... I've always set the bios to onboard graphics. I'm using the integrated graphics on the Intel Sandybridge CPU. Is that incorrect?
Lars
lkstaack is offline
post #11515 of 15974 Old 03-04-2012, 11:39 PM
lkstaack's Avatar
Aaagghh! Why does Bill Gates hate me?
Lars
lkstaack is offline
post #11516 of 15974 Old 03-05-2012, 01:34 AM
mudwiggle's Avatar
Hi Assassin,
I thought I'd just give you some feedback after recently putting together my latest HTPC.
Mobo: Intel DH61AG
CPU: I3-2100, using iGPU
Ram 8GB SODIMM (overkill I know but it's all that was available at the time)
HDD for O/S, programs etc: Patriot Pyro 60GB SSD
HDD for media files: 3.5" 2TB Seagate
Case: Silverstone SG05
Windows 7 64 bit
Power Supply 180W external power brick
XBMC 11 Eden RC2
I have to say, this thing is awesome! I previously had a Q6600 based system employing a HD5670 GPU over HDMI which I thought was good. But perhaps surprisingly, this plays movies even smoother than the discrete card system...I have no idea why. I experimented with every conceivable setting to get smooth play on the old one and it was pretty good. but this is better. It surprised me because everyone was saying the iGPU on Intel wasn't as good. Anyway, very happy there.
The system doesn't use Harware Acceleration and uses approx 40W playing HD files, 30W playing SD files. At idle it runs at 26W and when the HDD sleeps it drops to 20W. I tried using different power bricks (eg. 120W and 90W) but it made no measurable difference to power consumption. Either way it runs very cool and quiet (also much, much better than the old one which would send an annoying hum through my entertainment cabinet).
I tried hardware Acceleration and it works Ok most of the time but some movies it struggles with. Could be XBMC's implementation as much as Intels that causes the problems, but at 40W for HD I'm not worried.
I use my iphone as a remote control (using HippoRemote app and software), but i'm awaiting the Flirc remote to add a bit more WAF.
Using the external power brick allowed me to remove the 300W power supply that came with the SG05 frees up more room for extra HDD's but the DH61AG can only accept 2 internal SATA drives anyway. I could replace the patriot SSD with a mSATA SSD drive and add another large HDD if needed. Or I may eventually move to a server based system.
Anyway, hope this helps anyone thinking of building a similar system.
mudwiggle is offline
post #11517 of 15974 Old 03-05-2012, 05:04 AM
I too am waiting for HDDs to come down. Is there an issue with drives over 2TB? I noticed when installing board drivers there was one (ASRock Z68 mATX) that they had a driver or utility for >2TB...
The 500 drive I 'repurposed' (Seagate Baricuda @7200) is too loud, and I just hate that HDD 'write' scratch the blackboard like sound. Anyway, I was thinking, 'if I'm going to wait for prices to retreat (and, I have until football season), why not pop in a huge drive, like 4TB"... but 2TB are very popular on this forum.
post #11518 of 15974 Old 03-05-2012, 05:15 AM
jrock18's Avatar
Thanks for the input. I am in no rush for the 3d content as of now. I have tossed up just getting a blu-ray reader instead of the writer and may just do that. I definintely want internal on the HD so I have a clean a/v cabinet. Where can I find the egg promo code?
What are the favorites for dual tuner cards? Also, any experiences with running antennas from an attic here? I am looking for input on successful long runs in an antenna, as in what type of amps were used to get the signal throughout the home.
jrock18 is offline
post #11519 of 15974 Old 03-05-2012, 05:20 AM
Oh, one other question. I didn't put a BD in my box, but, I may or I may put an external on the system (no AVR, and I don't think I will anytime soon, I pass sound from the TV to a 20 yr. old Yamaha, works fine). Can you hook an external BD up to the HTPC via eSATA or SATA and use it as if it was an internal (however, pass the signal out directly to the TV/AVR?)
Should I download (the .exe) and/or install MakeMKV? I have a lot of homework to do on file types... but, does this work for regular DVDs, or, Blu Ray only? The reason I ask, while still in Beta it is free.
I played around a little with the new machine yesterday, checked out HULU (installed). This machine already does more than I expected (haven't put photos or music on yet, but, once I have a big drive I'll do all that). I'm psyched, wish the extender did have to reconnect as frequently as it does (powerline), but, it is definitely nice to have that stuff available in the BR.
The Guides are key, as is the advice on this board. Thanks.
post #11520 of 15974 Old 03-05-2012, 05:24 AM
10 or 15 pages back (maybe 20 by now) there was gentleman who ran very long antennas. Interesting posts/discussion. I can't think of who it was... but he ran 250'.
Reply Home Theater Computers
Rosewill Windows Vista Certified Media Center Infrared Remote Control Rrc 126 , New Logitech Harmony One Keypad Touch Screen Advanced Universal Remote Control Infrared Display Lcd
