Assassin's Simple/Beginner HTPC Buying Guide - Page 412 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
post #12331 of 15974 Old 04-01-2012, 12:35 PM
LastButNotLeast's Avatar
Quoted: 1733 Post(s)
Liked: 1339
Originally Posted by jacket_fan View Post
Is there something in the bios setup that I need to toggle or set for a remote keyboard and mouse to work?
I'm no expert, but I don't think there is any way to get a remote keyboard and mouse to work. You need a wired keyboard and mouse for setup, then the remotes will work once the system boots.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #12332 of 15974 Old 04-01-2012, 01:27 PM
Wilky13's Avatar
Originally Posted by Shark007 View Post
correct.
I have the same AVR and I set it to 'Direct' <--- maybe try that setting on the AVR itself.
If your HTPC is showing "HDMI Bitstream (1403)" on the FFDshow icon then it is all setup. The issue is on the AVR. Make sure it is set to decode HD Audio, try some type of 'direct' stream.
I have to return some video tapes....
Wilky13 is offline
post #12333 of 15974 Old 04-01-2012, 01:29 PM
Wilky13's Avatar
http://assassinhtpcblog.com/Shark_007/DTS-HD.png
Wilky13 is offline
post #12334 of 15974 Old 04-01-2012, 01:31 PM
Wilky13's Avatar
Now that my password is reset and I have replaced the solid state drive and motherboard, I have a new problem trying to get things going again. I have a new Gigabyte GA-Z68MA-D2H-B3 motherboard and a new Corsair F80 solid state drive. I booted and it seems the bios is fine and the keyboard and mouse work fine. When I try to install Windows 7, I get to the page that you tell it you want English, and the rf keyboard and mouse do not work.
The frustration is that the installation went so easy the first time.
You probably need to already have Windows installed so that it can install the drivers for the RF keyboard/mouse. Also check you are not plugged into the USB 3.0 ports, as they need drivers also.
Wilky13 is offline
post #12335 of 15974 Old 04-01-2012, 01:33 PM
tydas's Avatar
Yes, that is exactly what I see...now i'm wondering if my chipset is the issue? although from what I've read it should handle this hd audio...oh well...a little more investigation ahead!
tydas is offline
post #12336 of 15974 Old 04-01-2012, 01:38 PM
Wilky13's Avatar
Maybe, have you been able to play HD audio through that AVR before? I had fiddle with my Pioneer for over an hour before I set it to 'direct stream'. Then all my formats worked.
Wilky13 is offline
post #12337 of 15974 Old 04-01-2012, 02:23 PM
tydas's Avatar
Yes, I bitstream from my bluray and i get HD-MSTR display on AVR...i've been thru every setting on AVR and I'm pretty sure its set right...so frustrating...its got to be some driver or other issue on the HTPC
tydas is offline
post #12338 of 15974 Old 04-01-2012, 02:37 PM
Liked: 1339
Try plugging in the HDMI cable from the computer into where the BDP is now. Maybe your AVR is particular about inputs.
post #12339 of 15974 Old 04-01-2012, 02:41 PM
Wilky13's Avatar
Hmmm.... If your bluray player works then it sounds like your AVR is fine and your getting FFDshow to say "HDMI bitstream", so your codec setup sounds okay, too. And your setup page is good? http://assassinhtpcblog.com/Shark_007/ffdshow%201.png
And your mixer page is set to "same as input"? http://assassinhtpcblog.com/Shark_007/ffdshow%202.png
Paste a screen shot of your 2 pages.
Wilky13 is offline
post #12340 of 15974 Old 04-01-2012, 04:02 PM
jacket_fan's Avatar
Thanks Wilkey, but my son figured it out. The dongle for the keyboard and mouse neeeded to be in USB port 1. I had it in 3. i would have never figured that one out. Makes no sense to me but it worked. I am now n the process of using the guides to get back to where I was before the drive crashed on me.
Mark
jacket_fan is offline
post #12341 of 15974 Old 04-01-2012, 04:55 PM
tydas's Avatar
i'm honestly ready to wipe my drive and re install..not a huge deal..when I find the time...which after tonight won't be till Friday...I'll try and post some screen shots later...
tydas is offline
post #12342 of 15974 Old 04-01-2012, 05:09 PM
Wilky13's Avatar
One last thing I would do is go to your motherboards website and download/install the latest drivers.
Wilky13 is offline
post #12343 of 15974 Old 04-01-2012, 05:13 PM
amcdoc's Avatar
Getting more and more frustrated with my htpc built with Assassin guide as a template.
now im getting this error after 3 seconds of video playback, I have iso files. They are the problem, My one Mkv files words well. I have mounted via virtual clone the iso and used Mikinho Mount Image program and made setting in mediabrowser.
Video Error: Files needed to display video are not installed or not working correctly. Please restart Media Center and or restart the computer
Ive tried that without help.
Im using Lav. Should I uninstall and try shark codecs?
Im running mymovies and mediabrowser.
any suggestions?
amcdoc is offline
post #12344 of 15974 Old 04-01-2012, 05:44 PM - Thread Starter
assassin's Avatar
Quoted: 132 Post(s)
Liked: 254
I
any suggestions?
Try a different iso mount.
Why are you using mymovies and mediabrowser? I wouldn't exactly call that a "template".
assassin is offline
post #12345 of 15974 Old 04-01-2012, 06:21 PM
hollatbk's Avatar
Can anyone point me in the direction of a guide to ripping 3d movies for playback in wmc/mb
hollatbk is offline
post #12346 of 15974 Old 04-01-2012, 06:27 PM - Thread Starter
assassin's Avatar
Quoted: 132 Post(s)
Liked: 254
Unfortunately for 3d you have to use paid software like tmt5.
assassin is offline
post #12347 of 15974 Old 04-01-2012, 06:57 PM
hollatbk's Avatar
To rip it or play it?
hollatbk is offline
post #12348 of 15974 Old 04-01-2012, 07:22 PM
amcdoc's Avatar
HI, there, love your guide, for anyone new to this, they should buy it, invaluable for the long haul.
I am using mymovies and mediabrowser because I like the way mymovies rips movies automatically, ipad app, android app, and auto monitoring of folders. Sorry, did not mean to suggest mymovies was in your template. Its not but a lot of users do own it.
I did not install Media center master this time around because of what I thought was corruption of too much meta data.
interestingly, in your guide the settings do allow mediabrowser to fetch metadata (something about providers), I noticed mediabrowser did a fair job by itself for this.
Honestly, would like to run the 2, since they have their pros and cons. From hitting goggle and lots of forums, ive learned they dont offsett each other.
I will try the iso thing by unchecking auto play, see if that works.
amcdoc is offline
post #12349 of 15974 Old 04-01-2012, 07:30 PM
kcsims's Avatar
Just got my build together and I'm having problems. I am running a Intel G620, asus p8h61-i, and 4 gig ram just like listed in the build at the start and all blu ray rips (m2ts) are having problems. They all have artifacts that appear anytime the screen changes from one scene to another. Anything I am missing on the setup or anything?
Edit - Running the newest build of XBMC
kcsims is offline
post #12350 of 15974 Old 04-01-2012, 07:47 PM
amcdoc's Avatar
okay now noted Video Error: Files needed to display video are not installed or not working correctly. Please restart Media Center and or restart the computer
occuring on mkv and iso. this was my second windows install attempt after clean windows install. Now either give up or redo.
I think I will redo but this time word for word thru assassins guide. I will uninstall whs mymovies and mymovies from client pc as well. No more mymovies and maybe things will work??
I dont know, soo frustrating.
amcdoc is offline
post #12351 of 15974 Old 04-01-2012, 07:55 PM
Wilky13's Avatar
That error message is the same I got when I had LAV as my codec. I uninstalled LAV and installed Shark007 as per the Free Guide 1. I have mkv, avi, and mp4, they all work fine now. I do not have iso.
Wilky13 is offline
post #12352 of 15974 Old 04-01-2012, 07:59 PM
amcdoc's Avatar
thanks for the quick post, i will try that first before fresh reinstall, seems darn complicated though.
amcdoc is offline
post #12353 of 15974 Old 04-01-2012, 08:09 PM
Wilky13's Avatar
Naw, the Shark GUI makes sense once you go through it a few times. It makes codec setup a lot simpler than digging into each individual codec (LAV, Halli, FFDshow, etc.) setup pages.
Wilky13 is offline
post #12354 of 15974 Old 04-01-2012, 08:17 PM
Wilky13's Avatar
I want to query everyone's input. I rip 99% of my bluray's to mkv and watch them in Media Browser.
But....
For that 1% of the time I want to throw the bluray in the optical drive and just watch it from there, what is the best plugin that integrates seamlessly into WMC? TMT5? MyMovies? Any others?
Wilky13 is offline
post #12355 of 15974 Old 04-01-2012, 08:35 PM
badgerpilot's Avatar
Quoted: 75 Post(s)
Liked: 45
But....
I have been using TMT for some time now with zero problems. I rip all of my BD's as ISO's. TMT works seamlessly with Media Browser. If you just want to pop a disc in, TMT works great for that too. My HTPC is my go to disc player as well.
badgerpilot is offline
post #12356 of 15974 Old 04-01-2012, 08:57 PM
Wilky13's Avatar
Does TMT5 play in WMC, or does it minimize WMC and play in it's own window? Does WMC pop back up after you stop the disc?
Wilky13 is offline
post #12357 of 15974 Old 04-01-2012, 08:58 PM
joeydrunk's Avatar
Quoted: 14 Post(s)
Is anybody familiar with secodnrun.tv? Pros/cons? Also I just sicovered kylo browser, I think its my new go to htpc browser.. nice, simple, 10ft interface.
joeydrunk is offline
post #12358 of 15974 Old 04-01-2012, 09:08 PM
Quoted: 75 Post(s)
Liked: 45
You hit play, and a screen shows up showing your drives, then the video starts. When you hit stop, you are back in WMC. Very seem less. Remember, I use TMT 5 for all of my playback. If I insert a disc into my HTPC, it just plays. If I choose from a ripped disc in MB, again, TMT 5 starts up and plays the movie. That's one of the reasons I went with TMT is that it works very well in side of WMC as well as MB. I know that many do not want to pay for playback software but for me, this was the best solution.
post #12359 of 15974 Old 04-01-2012, 09:30 PM
mariob33's Avatar
Quoted: 94 Post(s)
Liked: 74
Send a message via Skype™ to mariob33
Originally Posted by wilky13 View Post
i want to query everyone's input. I rip 99% of my bluray's to mkv and watch them in media browser.
But....
For that 1% of the time i want to throw the bluray in the optical drive and just watch it from there, what is the best plugin that integrates seamlessly into wmc? Tmt5? Mymovies? Any others?
tmt5
In search of video bliss...
mariob33 is offline
post #12360 of 15974 Old 04-01-2012, 09:30 PM
mariob33's Avatar
Quoted: 94 Post(s)
Liked: 74
Sort of and yes you come back to WMC
mariob33 is offline
Reply Home Theater Computers
Rosewill Windows Vista Certified Media Center Infrared Remote Control Rrc 126 , New Logitech Harmony One Keypad Touch Screen Advanced Universal Remote Control Infrared Display Lcd
