Assassin's Simple/Beginner HTPC Buying Guide - Page 426 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
Old 04-27-2012, 04:35 PM
calinative68's Avatar
Originally Posted by tilldeathand1 View Post
Hello
First time looking into a HTPC. First off I am very thankful everyone on here that provides info/tips/advice, it all has been very helpful and have made be want to attempt to build one.
Here is what I have put together (almost all of the items are from this guide):
-ASUS SATA 6 Gb/s DisplayPort Intel Z68 Micro ATX DDR3 2200 Intel LGA 1155 Motherboards P8Z68-M Pro
-Intel Core i3-2100 Processor 3.1GHz 3 MB Cache Socket LGA1155
-G.SKILL Ripjaws Series 4GB 2GBx2
-Antec EarthWatts EA-380D Green 380 Watt 80 PLUS BRONZE Power Supply
-SilverStone Front Panel and SECC Body Micro ATX HTPC Computer Case GD04B
-Lite-On 12x Internal Optical Blu-Ray BD DVD CD-R Writer Burner
-Crucial 64 GB m4 2.5-Inch Solid State Drive SATA 6Gb/s
-Seagate Barracuda 7200 3 TB 7200RPM SATA 6 Gb/s
-Western Digital Caviar Green 2 TB
-TP-Link TL-WN951N 300Mbps Wireless N PCI Adapter
I do have one question but cant seem to find the answer. I want 2 internal HD and 1 SSD as well as a Blu Ray Drive. Will all four of these items fit in the case that I have on my list??
Looks good! I would also recommend paying for the guides.
calinative68 is offline
Old 04-27-2012, 04:48 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Originally Posted by LastButNotLeast View Post
I used a black Sharpie over the green light of my Asus BDR and it helped a lot.
You can unplug the wire to the LED altogether, but I prefer knowing if the computer is on or asleep.
On Battlefield, I can offer no advice.
Michael
A couple things I have tried...
Opaque fingernail polish
Black marker
Unplugging the LED header
Some people love the lights. Some don't.
assassin is offline
Old 04-27-2012, 06:44 PM
Joe 6 Pack's Avatar
I'll probably just get used to it after a while. It's just weird since my other PCs just have the light stay on when the PC goes to sleep.
Just because I don't care, doesn't mean I don't understand.
Joe 6 Pack is offline
Old 04-27-2012, 07:04 PM
SLAYER6669's Avatar
It depends on the board manufacturer. Asus boards are blinkers. I'm not sure what others are. It annoyed me at first too, but I'm not usually in the room when it's sleeping so I just got used to it.
SLAYER6669 is offline
Old 04-27-2012, 07:29 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Seems like a silly problem a piece of tape could fix ...
Mfusick is offline
Old 04-27-2012, 07:56 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Assassin HTPC Europe now active and alive.
Enjoy.
assassin is offline
Old 04-27-2012, 08:13 PM
SLAYER6669's Avatar
Unless you bought the nMediaPC 6000B like I did and you have a fake "Volume Knob" as your power button which has a giant ring around it that blinks! Whoops.
Old 04-27-2012, 08:24 PM
ghostlobster's Avatar
Enjoy.
Awesome!! Congratulations, you jetsetting mofo!
Ray
===Ghostlobster===
ghostlobster is offline
Old 04-28-2012, 02:05 PM
ComptonHPD's Avatar
Just wanted to let you know I donated. I've appreciated all your help!
ComptonHPD is offline
Old 04-28-2012, 05:07 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Thanks for the support. Hope you enjoy the guides!
assassin is offline
Old 04-28-2012, 08:13 PM
bopgaard's Avatar
I could really use some help. I have the following build and wired everything up to the best of my ability, however when i power my machine it seems to continuously cycle on and off every couple seconds. Any ideas. Could the power supply not be pushing enough power? any thoughts?
bopgaard is offline
Old 04-28-2012, 08:58 PM
mariob33's Avatar
Quoted: 88 Post(s)
Liked: 66
Send a message via Skype™ to mariob33
You have plenty of power.. Couple of ideas..
Is your memory compatible? Try one stick of memory at a time or another type. make sure your CPU is seated correctly. Do you have both 8 and 24 pin adaptors plugged into mb from PSU?
In search of video bliss...
mariob33 is online now
Old 04-28-2012, 09:32 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Celeron G530 $37 + shipping with code SWEEPUP5
https://www.superbiiz.com/detail.php?name=G530BOX&c=CJ
assassin is offline
Old 04-28-2012, 09:55 PM
Lars99's Avatar
Check the cpu fan is plugged into the motherboard.
Check the ram is seated correctly.
Check the ram isn't bad (another computer if you have access)
Check your SATA controller.
Lars99 is offline
Old 04-29-2012, 06:50 AM
bopgaard's Avatar
the ram i purchased was the recommend ram for this build. I also tried a different pair just to rule out it being DOA.
motherboard power supply is plugged in fine.
I did however use some left over short screws I have laying around to secure the mother board. could this be causing it?
I took a picture of my build please excuse the messy wires for now.
bopgaard is offline
Old 04-29-2012, 06:54 AM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Absolutely. You need to make sure it is properly secured and grounded.
assassin is offline
Old 04-29-2012, 07:16 AM
flocko's Avatar
I would fix the screws first and if that doesn't fix it then I would rebuild the system out side the case on a card board box
+1 for sure
flocko is offline
Old 04-29-2012, 08:20 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Best deal going for sure
Mfusick is offline
Old 04-29-2012, 09:32 AM
velillen's Avatar
If he is just talking about what screws he used to attach the mobo to the standoffs i cant see it being an issue. i've used all sorts of screws to go into standoffs (actual mobo screws, HDD screws, ect). Though of course if you have the mobo screws 'd use them first.
I'd honesty do what this video tells you to make sure the psu truly works. I had a psu that would do the on/off thing under a paperclip test so it was easy to know the problem.
http://www.youtube.com/watch?v=5FWXg...=youtube_gdata
After that just try minimal setup (cpu/ram) 24pin and cpu 4pin. If a problem there then least you know where to begin trouble shooting. if it works then you know its something else and can add 1 thing at a time.
Of course if you have a second psu you know works then you could quickly try that as well (again just minimal cpu 4 pin and 24 pin to post)
PSN- Velillen
velillen is offline
Old 04-29-2012, 10:26 AM
Fastslappy's Avatar
Liked: 749
that happened to me on one of my 1st builds years ago ......
get that cardboard box out
And start over ....
did your MoBo come with a tiny speaker ??
that will beep a problem code on start-up
alot of new MoBo's don't include them anymore
......... open a running PC & borrow one if need be ....
my last 2 didn't have the speaker ...
read the Gigabyte MoBo manual again only read the assy part & follow the directions to a tee .
IF you can then get the mobo & all parts working ,posting even starting to load the OS .. then the problem is how you mounted the mobo into the case
You did use the brass stand-offs under the mobo ?? to keep the back of the MoBo from touching the case Right ?
report back .... More than Happy to help .. I've been there, done that & wish someone could of helped me years back ..
unhook everything ....attach one component at a time double check everything as you go
Mike
JAZZ IS NOT DEAD IT JUST SMELLS FUNNY ; FRANK ZAPPA
Fastslappy is offline
Old 04-29-2012, 01:59 PM
LastButNotLeast's Avatar
Quoted: 1479 Post(s)
Liked: 1069
Which is why I used a G530 instead of an i3, and everything works just fine.
I paid about $45 in January.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
Old 04-29-2012, 03:30 PM
bopgaard's Avatar
interesting, I wasn't aware that you could mount a board wrong. I just used the screws that came with the board and screw them into the screw holes that lined up on the case. I wasn't aware of any brass stand offs. Im going to try and pull everything out and re install while following the manual. Thanks so much for your advice.
bopgaard is offline
Old 04-29-2012, 04:01 PM
flocko's Avatar
Please tell me u used the brass stand offs that come with EVERY case.
Indeed , I would read the manual this timer after dis assembly and just a word of advice , do a minimum set up with just the psu , cpu and ram on a cardboard box just to be safe ... this time . Just get thru the post screen and don't worry about booting cause it will throw a hundred errors due to the fact you are running a minimum set up .
Hang tough !! Ul get it
flocko is offline
Old 04-29-2012, 04:09 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Read the instructions.
Maybe twice in your case.
Not trying to be an ass. Just trying to protect you and your components.
assassin is offline
Old 04-29-2012, 05:12 PM
Liked: 1069
Instructions? We don't need no stinkin' instructions!
Old 04-29-2012, 05:40 PM
Owlpoop's Avatar
Well...I have decided to take the plunge and cut my cable. After reading the build guides on this site I put together the following build using the various recommendations on the first page. If you would be so kind as to look it over to ensure I have spec'd out a system that the components will work together and actually fit in the case I wasn't sure what CPU cooler to get (if it is needed). Many thanks in advance for any guidance and patience!
Motherboard: ASUS F1A75-M - FM1 Socket - A75 - SATA 6Gbps and TPM Support (Hudson D3) Micro ATX
Processor: AMD A8-3870K APU with AMD Radeon 6550 HD Graphics 3.0GHz
Graphic Card: ASUS GeForce GT 430 (Fermi) 1GB (ENGT430)
RAM: G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
HD: WD Caviar Green 2 TB WD20EARX
Blu-ray Drive: Asus BC-12B1ST
Case: Silverstone GD05B
CPU Fan: Need Advice
PSU: Antec EarthWatts EA-380D Green 380 Watt 80 PLUS BRONZE
Operating System: 64-bit Windows 7 Home Premium
Owlpoop is offline
Old 04-29-2012, 06:25 PM
flocko's Avatar
Originally Posted by Owlpoop View Post
Well...I have decided to take the plunge and cut my cable. After reading the build guides on this site I put together the following build using the various recommendations on the first page. If you would be so kind as to look it over to ensure I have spec’d out a system that the components will work together and actually fit in the case I wasn’t sure what CPU cooler to get (if it is needed). Many thanks in advance for any guidance and patience!
http://www.newegg.com/Product/Produc...AMD%20A8-3870K
Wow ... 100 watt cpu a bit toasty for a htpc
http://www.newegg.com/Product/Produc...82E16819115090
A bit cooler running .
Either way your choice of cpu or mine , the heat sink is included so you should be fine .
Both cpu support graphics processing built on the cpu . I would use that first and the see if you need a dedicated graphics card . Maybe take the money saved and srping for an ssd for the o.s. drive . Not needed per se but a nice perk .
Edit : Of course , if you change cpu vendors you will have to change the mother board as well . Personally I have never used Asus but everyone round here seems to be a big fan irregardless of cpu choice and that would be good enough for me !!
The rest of the build looks top notch
BTW.... WELCOME to the forum !!
flocko is offline
Old 04-29-2012, 06:33 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
If you are going to use a discrete graphics card (the GT 430) then there is very little reason to go with the AMD CPU. The Intel G530 or G620 is much cheaper and plenty of CPU for HTPC. It will run cooler and use less wattage as well. And the CPU cooler should be better and quieter for HTPC than the stock 100w AMD coolers.
Your call. I think Intel CPU + NVidia/ATI graphics card makes a very nice and versatile machine.
You also could try the onbard iGPU of either choice before adding the GT430 to see how you like it first and save even more money, noise and heat. That's my recommended approach and there is very little downside.
assassin is offline
Old 04-29-2012, 06:59 PM
bopgaard's Avatar
thanks to everyone for the amazing help so far. I put everything together outside of the case as advised and am still seeing the same issue. Here is a video of what continues to happen.
http://www.youtube.com/watch?v=nlQ81...ature=youtu.be
bopgaard is offline
Old 04-29-2012, 07:18 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Is your CPU cooler completely seated?
Also do you have other RAM you can try? Or have you tried each stick individually in each slot?
assassin is offline
Rosewill Windows Vista Certified Media Center Infrared Remote Control Rrc 126 , New Logitech Harmony One Keypad Touch Screen Advanced Universal Remote Control Infrared Display Lcd
