Assassin's Simple/Beginner HTPC Buying Guide - Page 430 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
post #12871 of 15974 Old 05-02-2012, 08:25 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Your guides are pretty incredible.
I thought they were incredible 6 months ago, and it seems they get better and better.
How do you find the time to do this?
Added my thoughts on the current IVB CPUs over at my blog.
Motherboard recs coming soon.
assassin is offline
post #12872 of 15974 Old 05-02-2012, 09:50 PM
mariob33's Avatar
Quoted: 88 Post(s)
Liked: 66
Send a message via Skype™ to mariob33
Has anyone here had any success with a product called videoredo for managing WTV files and a commercial removal tool. I have been using for a few days and it's awesome. Allows rip/removal of ads in a 1 hour show In 8-10 minutes flat. It's pricey but IMO well worth it.
In search of video bliss...
mariob33 is offline
post #12873 of 15974 Old 05-02-2012, 09:59 PM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
I liked it quite a bit but I didn't end up buying it.
StardogChampion is offline
post #12874 of 15974 Old 05-02-2012, 10:09 PM
mariob33's Avatar
Quoted: 88 Post(s)
Liked: 66
Yeah it's pricey but does a greatjob and end result is bit for bit.
mariob33 is offline
post #12875 of 15974 Old 05-03-2012, 07:57 AM
LastButNotLeast's Avatar
Quoted: 1474 Post(s)
Liked: 1069
I use DVRMSToolbox and the paid ($10) version of ComSkip. Cuts about 18 - 20 minutes of junk from a one hour show, takes about 10 minutes, and uses LOTS of CPU power!
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
post #12876 of 15974 Old 05-03-2012, 08:29 AM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Ivy Bridge H77 recommendations are up at my blog. Enjoy.
Z77 coming soon...
assassin is offline
post #12877 of 15974 Old 05-03-2012, 09:37 AM
Quoted: 93 Post(s)
Liked: 160
ASUS P8H77-I LGA 1155 Intel H77 HDMI SATA 6Gb/s USB 3.0 Mini ITX Intel Motherboard
http://www.newegg.com/Product/Produc...82E16813131841
Yay.
post #12878 of 15974 Old 05-03-2012, 10:31 AM
Hamilcar Barca's Avatar
Hyperthreading!
Hamilcar Barca is offline
post #12879 of 15974 Old 05-03-2012, 11:46 AM
Zon2020's Avatar
Assassin, just wondered if you had ever used a SilverStone SG05B for a mini-ITX build or had any thoughts about it.
Zon2020 is offline
post #12880 of 15974 Old 05-03-2012, 01:00 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
I haven't. I have always been intrigued by those cases though and to me the design makes a lot of sense.
assassin is offline
post #12881 of 15974 Old 05-03-2012, 01:45 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Ivy Bridge section now complete.
Enjoy.
assassin is offline
post #12882 of 15974 Old 05-03-2012, 01:51 PM
Lars99's Avatar
Good stuff!
Lars99 is offline
post #12883 of 15974 Old 05-03-2012, 02:53 PM
rec head's Avatar
Quoted: 75 Post(s)
Liked: 67
Assassin, I have read the guides and saw the part about "Changing Audio Streams in WMC" but I don't quite understand it. Maybe I should back up a little bit and say that I go the guides because I am preparing to build an HTPC so I have not tried it. Maybe it would make more sense if I had hands on.
My real question is about using HDMI for WMC and optical for almost everything else (to play in zone 2 like you mention.) So first of all can I have both HDMI and optical live at the same time? That would be perfect because I would like zone 1 to be HDMI all the time. The Audio Renderer Updater you use in the guide appears to switch out as WMC opens and closes. I would like to leave WMC open all the time.
I'm sorry if this has been covered before but I have not found good search terms to bring up answers.
rec head is offline
post #12884 of 15974 Old 05-03-2012, 03:13 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Not possible in windows 7 using just wmc. This is a limitation of the software and not the hardware.
Changing the streams refers to 2 audio streams in one container (english and french or dolby digital and truehd, for example).
assassin is offline
post #12885 of 15974 Old 05-03-2012, 06:15 PM
rec head's Avatar
Quoted: 75 Post(s)
Liked: 67
Any other solution?
rec head is offline
post #12886 of 15974 Old 05-03-2012, 06:23 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Any other solution?
Sure. Use HDMI for WMC and 7.1/5.1 digital surround sound.
Then use WMP with analog output.
assassin is offline
post #12887 of 15974 Old 05-03-2012, 06:40 PM
rec head's Avatar
Quoted: 75 Post(s)
Liked: 67
So I can't have WMC using HDMI and another program using optical? Can I just assign which output each program uses? I don't actually need one source going to both HDMI and optical. I don't listen to tv/music in the other zones but I do listen to my FLAC library with MediaMonkey and podcasts through itunes. Using the optical for the music is especially important.
Sorry for the PITA questions but I want to be able to set up everything from the start to work how I need it to.
rec head is offline
post #12888 of 15974 Old 05-03-2012, 06:41 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Some programs can do this. But not WMC which is what you asked about.
JRiver and maybe XBMC are a few.
assassin is offline
post #12889 of 15974 Old 05-03-2012, 06:59 PM
rec head's Avatar
Quoted: 75 Post(s)
Liked: 67
So using the method in your guide I would need to exit WMC (which would use HDMI) to allow the other programs to use the optical out? Would WMC still record tv shows in the background?
rec head is offline
post #12890 of 15974 Old 05-03-2012, 07:05 PM
mariob33's Avatar
Quoted: 88 Post(s)
Liked: 66
This is what's great about videoredo no encoding/rencoding to rip out commercials..it's fast and not resource intensive.
mariob33 is offline
post #12891 of 15974 Old 05-03-2012, 07:09 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
I don't really understand what you are asking.
Recording doesn't use anything. You setup what you want to record and it records it to your hard drive. You don't even need a HDMI cable or HDTV connected to record. It is not until you watch what you recorded that you are actually using the HDMI output.
assassin is offline
post #12892 of 15974 Old 05-03-2012, 07:14 PM
rec head's Avatar
Quoted: 75 Post(s)
Liked: 67
I understand that about how recording works. My concern is that I exit WMC so I can listen to music via MediaMonkey and then don't start WMC when I'm done listening to the music and a show doesn't get recorded.
rec head is offline
post #12893 of 15974 Old 05-03-2012, 07:16 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
No, WMC does not need to be open or running to record. Your computer need to be on or asleep.
So use whatever program you like outside of WMC for your audio.
assassin is offline
post #12894 of 15974 Old 05-03-2012, 07:17 PM
rec head's Avatar
Quoted: 75 Post(s)
Liked: 67
rec head is offline
post #12895 of 15974 Old 05-04-2012, 02:39 AM
Shanndogg's Avatar
Finally getting my HTPC parts in, but I really need your help on my server build to go along with it. I got the template from the Renethx guide and am going with unRaid. Here's what I'm thinking so far for a 20 drive build:
Case: Antec Twelve Hundred V3
HDD Cages x4: ORCO SS-500 5 Bay
PSU: PC Power and Cooling Silencer Mk II 750W
CPU: Intel Xeon E3-1230 Sandy Bridge 3.2GHz
Motherboard: Supermicro X9SCM-F MBD-X9SCM-F-O LGA 1155 Intel C204 chipset microATX with IPMI
Memory: Kingston ValueRAM KVR1333D3E9SK2/8G DDR3-1333 ECC CL9 2 x 4GB Kit
HBA x2: SUPERMICRO AOC-SASLP-MV8 PCI Express x4
Cable x4: 0.5m SFF-8087 to Four SATA Forward Breakout Cable (3ware CBL-SFF8087OCF-05M)
Flash Drive: SanDisk Cruzer Fit 4GB USB 2.0 Flash Drive
My question is mainly regarding the CPU. Originally I had it as a Xeon E3 1225 as in Renethx's guide, but I was recommended the E3 1230 instead since the motherboard already has a video chip. Furthermore, since I don't plan on running a virtualized served, I could save some cash and go with an i3.
Considering this will be paired with my HTPC as seen here, and that I want to do transcoding of full bluray files using Plex to Android phone/remote computers, what processor should I go with (or should I make any other changes)?
I am planning to do the transcoding from the server, but if it makes more sense to do it from the HTPC please let me know. I know a lot of you do what I am trying to set up so any insight would be great.
Shanndogg is offline
post #12896 of 15974 Old 05-04-2012, 02:40 AM
Tyfoon2's Avatar
I'm currently using a setup where my HTPC is acting as server and HTPC. It's getting a bit dated and lacking some performance especially when e.g. downloading/decompressing and playing HD content (or even navigating WMC). Also the HD setup is not the best.
A good time to replace everything.
The setup needs to:
a) Actsas the media server for the bedroom system (WMC), sonos etc.
b) is on 24/7 (as it also is used to manage all downloading, decompressing etc.). Have a 100mb optic fiber connection.
c) Is the DVBlink server (IPTV) for bedroom system and other devices (like Ipad etc.)
d) directly connected to my Receiver/TV (HDMI) running WMC (win 7) and used for live TV and all other Media (so core entertainment system)
So in short it's kind of a combo of a mediaserver and normal HTPC. No need to be perfectly quit or beautiful, just to be efficient, powerful (sometimes the un-rarring/parring of files and watching a 3d H264 movie hits the max perf of current system) and reliable (!).
I'm now selecting the hardware and will be using Ivy Bridge I5 3750.
  • I want to protect everything better (had some HD failures in the past). Already purchased FlexRaid to handle this (incl. pooling)
  • wil use approx 8-10 T of HD space max. So thinking of using 4x2T (WD green) of 3x 3T(Seagate)
My main question is with the harddisk setup:
What is the best way to configure this all knowing the usage scenario (especially the combo of being the main HTPC and downloading/unrarring/unparring). Do I put them all in a flexraid config? Do I use a seperate physical HD for the downloading part? Shout I put the OS on a SDD etc?
Any tips are very welcome!
Tyfoon2 is offline
post #12897 of 15974 Old 05-04-2012, 07:32 AM
Liked: 1069
There's no re-encoding here either, it just reads the video file and writes a file that "marks" the commercials so WMP can skip them. If it had to transcode it, it would take a whole lot longer (and keep in mind I'm using a G530, so an i7 probably wouldn't have to work as hard ).
post #12898 of 15974 Old 05-04-2012, 07:40 AM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
I am going to have to disagree with Renethx's recommendations for a server if you are using this just for your own personal use. You can go MUCH cheaper and have a fantastic server.
Now if you are if you are setting up Shanndogg.com and have a ton of server traffic that's different.
Also, I would consider FlexRaid over unRaid at this point.
assassin is offline
post #12899 of 15974 Old 05-04-2012, 07:43 AM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
The setup needs to:
Put the OS on a separate SSD or Hard Drive. You can't pool or include the OS drive in parity in FlexRaid.
I download right to a folder in one of my pooled drives. No issues at all except you should stop your downloads when you want to take a snapshot of the array.
assassin is offline
post #12900 of 15974 Old 05-04-2012, 07:53 AM
Tyfoon2's Avatar
Are there no performance hits in read/write traffic when e.g. unrarring/parring and at the same time moving (or playing) from the same pooled drive? Sorry but I'm new to this polling thing.
p.s. I used to unrar/unpar all to a seperate drive from the ones actively recording TV from and from the one actively playing HD content. This created better overall performance but is also nor very practical.
Tyfoon2 is offline
Reply Home Theater Computers
Rosewill Windows Vista Certified Media Center Infrared Remote Control Rrc 126 , New Logitech Harmony One Keypad Touch Screen Advanced Universal Remote Control Infrared Display Lcd
