Assassin's Simple/Beginner HTPC Buying Guide - Page 431 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
post #12901 of 15974 Old 05-04-2012, 09:59 AM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Originally Posted by Tyfoon2 View Post
Are there no performance hits in read/write traffic when e.g. unrarring/parring and at the same time moving (or playing) from the same pooled drive? Sorry but I'm new to this polling thing.
p.s. I used to unrar/unpar all to a seperate drive from the ones actively recording TV from and from the one actively playing HD content. This created better overall performance but is also nor very practical.
I think for just personal/family use you would be better served (pun intended) with a $90 i3 2100 compared to that $240 CPU.
assassin is offline
post #12902 of 15974 Old 05-04-2012, 10:49 AM
HunterX82's Avatar
$20 seperates these 2 drives, with the main difference being 32MB cache versus 64MB cache.
Does that impact an HTPC much anyway??
Western Digital Caviar Green WD20EARS 2TB 64MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive $140
SAMSUNG EcoGreen F4 HD204UI 2TB 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive $120
I'd think that both were similar in terms of power consumption and noise.
HunterX82 is offline
post #12903 of 15974 Old 05-04-2012, 10:56 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Any reason you don't want to do this instead ?
22-148-681 - $109.99 w/ Promo Code EMCNENF23 + Free Shipping!
Seagate Barracuda Green ST2000DL003 2TB SATA 6.0Gb/s Hard Drive -Bare Drive
http://www.newegg.com/Product/Produc...ile-_-22148681
Mfusick is offline
post #12904 of 15974 Old 05-04-2012, 11:05 AM
HunterX82's Avatar
Oh snap good find. No, not really. I have the H67M motherboard so it supports the SATA 6.0Gb/s
post #12905 of 15974 Old 05-04-2012, 11:14 AM
Shanndogg's Avatar
Originally Posted by assassin View Post
I am going to have to disagree with Renethx's recommendations for a server if you are using this just for your own personal use. You can go MUCH cheaper and have a fantastic server.
Now if you are if you are setting up Shanndogg.com and have a ton of server traffic that's different.
Also, I would consider FlexRaid over unRaid at this point.
What would you recommend, or where can I find a suggested list that will better suit my needs? Granted, there are less expensive options on Renethx's list, I just took the higher end one, but his guide is also about 5 months old and I am not able to determine what level of server meets my needs.
It will just be for my own personal use, I just want to make sure I get something that will be solid and able to do the transcoding as I mentioned as well as the in-house serving. I will reexamine the info on Flexraid as well and am wondering if you recommend Flexraid for a specific feature or ease of use over unRaid?
Shanndogg is offline
post #12906 of 15974 Old 05-04-2012, 11:27 AM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
There is really no consensus that I have seen that you *have* to go with server parts to build a good and reliable home server. I built mine with a G530 CPU ($50) and an H67 motherboard ($80) and its rock solid stable.
Since you are wanting to use your server as a pseudo-HTPC you might consider WHS 2011 + FlexRaid. Using WHS allows you to install many of the software programs that you might want to use such as utorrent, media center master, Sickbeard, Couchpotato, SABnzbd+, media shares, MySQL, Mediaportal TV Server, etc.
The combination is pretty easy to use and FlexRaid supports multiple drive failures whereas unRaid only supports a single drive failing, storage pools, easy to use interface, ability to remove FlexRaid and still access all the data on your drives, etc.
BTW you also could run Win7 + FlexRaid on your server as well.
assassin is offline
post #12907 of 15974 Old 05-04-2012, 11:30 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
6.0gps SATA 3 and 64mb for $109.
Seemed like better answer to your question.
But for record the 32mb cache is just fine for HTPC. As is a SATA 2 3.0gps drive. There's like no real world difference in speed at all. Get the best deal .
Mfusick is offline
post #12908 of 15974 Old 05-04-2012, 01:08 PM
Shanndogg's Avatar
Just reviewed a lot of the info on the Flexraid site and it seems a lot easier to set up at first glance compared to unRaid (at least to me). I am also glad to see it does real time as well as snapshot- I previously was going off a comparison chart that indicated it only did snapshot. If I go with WHS and Flexraid (Raid-F + Pooling), it costs the same as unRaid, so looks like I am leaning that way now as you suggested.
Is your G530/H67 set up able to do the transcoding from Plex to your phone/remotely, or do you run it from your HTPC instead? I've been going back and forth between having the server do all the services like you mentioned or the HTPC. Any major pros/cons either way?
post #12909 of 15974 Old 05-04-2012, 01:15 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
The G530 does very well for me and yes I use it the transcode files to both my phone and remotely when I travel. However, I wasn't using Plex when I built my server. I would probably use a G620 for a little extra CPU boost or maybe even an i3 2100 if I lived near a Microcenter if I was building the same machine today.
assassin is offline
post #12910 of 15974 Old 05-04-2012, 01:52 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Very good deal
Refurbished Harmony One for $99 shipped after code logi_h1_5412
These don't usually last long. 90 day warranty.
http://www.logitech.com/en-us/promot...gdnq6du6nsmgkk
assassin is offline
post #12911 of 15974 Old 05-04-2012, 02:09 PM
Shanndogg's Avatar
Bam! That's perfect advice since I live near a Microcenter. You and your guides rock! I will go with the i3 2100.
Now I just have to figure out which motherboard/ram- looks like I should have gotten two of those Asus Z68 boards the other day from the shell shocker deal...
post #12912 of 15974 Old 05-04-2012, 02:39 PM
Fastslappy's Avatar
Liked: 749
just keep your eyes peeled on the site they Will be Back !! (The NEW Asus Z77 MoBo's are out !! & one was on sale as well)
Prime Advice ::::: if your set-up to get the e-blast...
1st thing in the morning you can see all the "shell shockers" that will up for the day ... that way you will n0t miss them when they come back up ...
Mike
JAZZ IS NOT DEAD IT JUST SMELLS FUNNY ; FRANK ZAPPA
Fastslappy is offline
post #12913 of 15974 Old 05-04-2012, 03:52 PM
flocko's Avatar
http://www.newegg.com/Product/Produc...82E16813131820
I have been anxious to see a server build with this board as Assassin has asked the forums opinion in another thread and did not seem to garner much response
I feel that with the 8 sata ports and the built in intel ethernet that this could be a really good server board that could also double as kick ass htpc board or a rockin pc board . Another words .... very diverse and also has Ivy capabilities .
A slight down side is that it is a bit pricy . For what u get though , it seems as though it would pay off in longevity .
Just my thoughts
-Flocko
flocko is offline
post #12914 of 15974 Old 05-04-2012, 04:06 PM
LastButNotLeast's Avatar
Quoted: 1474 Post(s)
Liked: 1069
I've been watching that for weeks. The coupon code is new (it was previously offered with "special combo savings," which I found not so special). This is very tempting, though I may hold out for 3TB.
Or I may not.
Thanks for the heads up.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
post #12915 of 15974 Old 05-04-2012, 04:23 PM
Kidsmoke's Avatar
Very good deal
Nice! Thanks for posting, the wife has been complaining about no remote for the new htpc.
Kidsmoke is offline
post #12916 of 15974 Old 05-04-2012, 05:12 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Very good deal
I picked up my H900 refurbed like this for $120 or something. Hell of a deal.
Sammy2 is offline
post #12917 of 15974 Old 05-04-2012, 05:41 PM
scopeyus's Avatar
Originally Posted by LastButNotLeast View Post
There's no re-encoding here either, it just reads the video file and writes a file that "marks" the commercials so WMP can skip them. If it had to transcode it, it would take a whole lot longer (and keep in mind I'm using a G530, so an i7 probably wouldn't have to work as hard ).
I guess the file remains in the wmc library rather than creating a new file in in media browser? I'd prefer the wmc interface since it is easy to delete the show after viewing. You say the file is marked for skipping by wmc; does this happen automatically?
scopeyus is offline
post #12918 of 15974 Old 05-04-2012, 06:05 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Very nice board. I would love to have this as my server board. Tons of features and speed. Intel LAN, with tons of media steaming features.
What thread are you talking about when you say Assassin has asked the forums opinion in another thread ?
Link?
Your right. I have the Z68 ASUS deluxe which is very much like this board's feature set. It was $269 earlier this year. Seems like this board gives you most of the features but with Z77. Your right.
All motherboards are not equal and you do get what you pay for, The memory controller on the Asus Z77's is far superior to other brands. Even Intel admits it's pretty amazing what Asus accomplished.
Nothing wrong with a $99 board from another MFG- but buyers should understand that they are not equal to a $200 Asus.
If I ever see a deal on the next step up Z77 Deluxe I think I will grab it. If not- this board you linked is my other choice.
Mfusick is offline
post #12919 of 15974 Old 05-04-2012, 07:10 PM
Liked: 1069
I feel the need for a new guide!
Yes, it works on the original file and doesn't modify it at all. It is suggested to set it to start 10 minutes after the show finishes recording; there's a "watch" folder, so it's automatic and you don't have to move anything.
http://babgvant.com/files/folders/dv...x/default.aspx
You need DVRMSToolbox (DTB) - 1.2.2.5 and DTBAddin - 1.0.0.7 (R3). It automatically installs a free version of Comskip (which is what it actually uses to detect the commercials), but you're much better off paying the $10 and getting the latest "donators" version (currently 81.036, 4/7/12) of Comskip:
http://www.kaashoek.com/comskip/
The setup of DTB is pretty straight-forward, but you can spend years tweaking the settings in Comskip. Fortunately, you don't HAVE to, but there are some defaults in the .ini file that do need to be changed. Not a big deal.
post #12920 of 15974 Old 05-04-2012, 08:18 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
I'd love to add it if anyone is interested in creating it.
I will cover all costs of the software.
assassin is offline
post #12921 of 15974 Old 05-04-2012, 08:58 PM
Liked: 1069
As I said, $10.
The Comskip forums actually cover it pretty well. I haven't done anything with it after setting it up a few months ago, but I'll look around for a step-by-step when I have a chance.
In the meantime, I'll let the author speak for himself:
http://www.kaashoek.com/comskip/view...php?f=5&t=1197
http://www.kaashoek.com/comskip/viewtopic.php?f=5&t=702
post #12922 of 15974 Old 05-04-2012, 09:08 PM
ryanm1058123's Avatar
been playing with my assassin htpc for a while now.. it is seriously perfect.
the only issue i have is that the processor (G630) isn't strong enough to use Dolphin (wii emulator). small potatoes though. does everything so well! (if i wanted a gaming machine i should have payed more from him)
ryanm1058123 is offline
post #12923 of 15974 Old 05-04-2012, 09:12 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
You just made my night.
Glad you like it.
assassin is offline
post #12924 of 15974 Old 05-04-2012, 10:47 PM
Fastslappy's Avatar
Liked: 749
Just my thoughts
-Flocko
I got 2 builds going with Deluxe version on that MoBo ..It's a great MoBo ! P8-Z77V-Deluxe , it's feature Rich !
Mike
post #12925 of 15974 Old 05-04-2012, 10:50 PM
Fastslappy's Avatar
Liked: 749
Or I may not.
Amazon has the 3TB for just dollars more that that .. I got one , I paid $189 for one(3TB) from Newegg & it was DOA they just refunded all my cash & sent me a free return shipping label ... going back to Amazon ...
Mike
post #12926 of 15974 Old 05-04-2012, 11:09 PM
pokekevin's Avatar
Liked: 102
Happens. I wouldn't say it was neweggs fault
pokekevin is offline
post #12927 of 15974 Old 05-05-2012, 03:32 AM
flocko's Avatar
Have had my fair share of issues with Amazon over delayed shipments . Do I still use them ? Sure . I am just more selective on what I will trust them with. Waited 60 day's on an avr that was "in stock"
I don't think The Egg said , "Hey fastslappy needs a new hdd go get that dead one off the shelf and wrap er up"
flocko is offline
post #12928 of 15974 Old 05-05-2012, 05:50 AM
thefever's Avatar
The key to Amazon is to sign up for prime, and use prime. I love free 2 day shipping, and 3.99 1 day shipping. I only buy stuff on amazon that is "fulfilled by amazon", not a third party.
thefever is offline
post #12929 of 15974 Old 05-05-2012, 05:58 AM
flocko's Avatar
Learned that one the hard way . You are correct . I only do "bought by and sold by Amazon" .
Good point !
flocko is offline
post #12930 of 15974 Old 05-05-2012, 10:03 AM
Fastslappy's Avatar
Liked: 749
Amazon has worked really well for me for years ,now I have Amazon Prime & that's icing on the Cake . But what I do is check both NewEgg & then Amazon for any part I want , I then do the math, taxes & shipping from NewEgg VS Amazon Prime . I do get things off of Amazon that is Not Amazon Direct but really that's just a 3rd choice after the Amazon Prime & NewEgg considerations.
Mike
Reply Home Theater Computers
Rosewill Windows Vista Certified Media Center Infrared Remote Control Rrc 126 , New Logitech Harmony One Keypad Touch Screen Advanced Universal Remote Control Infrared Display Lcd
