Assassin's Simple/Beginner HTPC Buying Guide - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
post #181 of 15974 Old 01-10-2011, 07:58 PM
skro's Avatar
Quoted: 13 Post(s)
Assassin,
I'm going to use your guide to build an htpc, but while I save up, I'm thinking about throwing in a video card in my custom built whs box and trying out sagetv media server. It seems that any ati 5400 series card would do the trick. Any particular recommendation for a cheap htpc card?
skro is offline
post #182 of 15974 Old 01-10-2011, 08:08 PM
jtrage's Avatar
Originally Posted by cwill2480 View Post
Thanks for the feedback assassin. That is a good deal based on current prices.
I'm still having a hard time wrangling the cost of an SSD versus partitioning the Samsung 2TB HDD for Windows. Is the primary difference simply the speed in starting/sleeping/etc? I'm beginning to think an SSD is just not worth the cost. I've never partitioned a drive before, but looking at a couple videos, it seems like it is a simple step during install of Windows 7. Is that correct? Probably a total noob question, but thanks for any advice.
Can't speak to the cost benefit of the SSD as I'm a noob also. I've partitioned and it was even easy for me.
jtrage is offline
post #183 of 15974 Old 01-10-2011, 08:16 PM - Thread Starter
assassin's Avatar
Quoted: 79 Post(s)
Liked: 242
Originally Posted by skro View Post
Assassin,
I'm just curious why you think you need to add a video card?
assassin is online now
post #184 of 15974 Old 01-10-2011, 08:18 PM
skro's Avatar
Quoted: 13 Post(s)
Sorry. Should have given more details. I have a dual core (not core duo, or i series; it is an e5200 I think) intel processor in a shuttle box with no hdmi out. I need to have hdmi out to make the setup easy (since it is temporary, and just to experiment).
skro is offline
post #185 of 15974 Old 01-10-2011, 08:21 PM - Thread Starter
assassin's Avatar
Quoted: 79 Post(s)
Liked: 242
Yes, the speed is obviously much faster with a SSD. It will boot up in about 15 seconds. Opening programs will be almost instant.
However, with the being said most of the time I simply "wake up" my HTPC which takes about 3 seconds with a Green HD. I am sure that starting up mediabrowser would probably be much quicker with a SSD but as it is now it takes about 10 seconds to get everything loaded.
So if saving a few seconds to you is worth it then by all means go for it.
The other option is that you can just buy the Green drive and partition 50-60 GB for the OS and try it out for a while. If you want to add a SSD later you can easily clone your partitioned OS drive and move it over to the SSD.
I like SSD a lot but as I have stated repeatedly they are by no means necessary. Maybe now you know why.
post #186 of 15974 Old 01-10-2011, 08:28 PM - Thread Starter
assassin's Avatar
Quoted: 79 Post(s)
Liked: 242
In that case definitely. I have a C2D build as well and I run a fanless 1GB sapphire ATI 5450 card and I really like it. The ATI software isn't perfect but you get used to it.
This 512MB card for $25 (yes, twenty five) after rebate will get the job done.
HDMI, plays all 1080p/720p, bitstreams HD Audio, low noise, low heat.
http://www.newegg.com/Product/Produc...82E16814102877
If you want to bump it up to 1GB for and extra $15 (after rebate) then this is the card that I have that works well...
http://www.newegg.com/Product/Produc...82E16814102882
post #187 of 15974 Old 01-10-2011, 08:31 PM
skro's Avatar
Quoted: 13 Post(s)
Awesome. Thanks!
skro is offline
post #188 of 15974 Old 01-10-2011, 08:33 PM
bonscott87's Avatar
I think for HTPC use an SSD is a luxury, not a need (as Assassin says). It's main benefit is speed of booting and program launch. BUT how often are you really doing any of that on an HTPC? Depends on your use but 7MC is just always running for me and go to a web browser once in a while and that's it. Reboot maybe every 2 weeks or so. None of that justifies the extra expense of an SSD in my opinion. Now as a main PC or gaming PC? Yea, I'm all over an SSD if I can afford it.
As for partitioning a hard drive, Windows install walks you right thru it. On my 1.5 TB drive I did a 75 gig C drive and the rest as a D drive. So Windows and any programs go on C. 7MC DVR recordings and all media go on D. On a more "typical" PC I'll usually do a C drive for Windows only, D drive for all programs and games and then an E drive for data. But for a dedicated HTPC I'd rather keep it simple.
Scott
bonscott87 is offline
post #189 of 15974 Old 01-10-2011, 08:46 PM
cwill2480's Avatar
Thanks guys. I think you confirmed the way I was leaning after thinking about it some more. Really nothing but a luxury for an HTPC as bonscott87 mentioned.
cwill2480 is offline
post #190 of 15974 Old 01-11-2011, 04:10 PM - Thread Starter
assassin's Avatar
Quoted: 79 Post(s)
Liked: 242
Anyone have any build pics?
post #191 of 15974 Old 01-11-2011, 05:01 PM
skro's Avatar
Quoted: 13 Post(s)
I hope this question is considered on-topic for this thread.
I've seen in another thread on AVS that most people find Netflix playback inferior on an HTPC compared to standalone blu-ray players, ps3, etc.
I was really surprised by this. However, I wonder if it has to do with the horsepower of the HTPC, or if it is just a generally accepted fact that the Netflix experience on an HTPC is inferior to a standalone box (I saw 1 mention of less available HD content on PCs vs. dedicated boxes).
Since I've never built an HTPC before, and I'm considering building the one recommended in this thread, I thought I'd ask...how do you find the Netflix experience with a core i3 HTPC? I don't consider this "low end" (it is recent tech, just not max clock speeds), but maybe a higher end CPU is necessary to get a Netflix experience similar to that on standalone boxes.
Thoughts?
skro is offline
post #192 of 15974 Old 01-11-2011, 06:05 PM
bswiz's Avatar
Quoted: 66 Post(s)
Let me first add my thanks to Assassin and others who have helped out in this thread. I have just started to think about an i3 build and the suggested components are really close to what I was coming up with on my own.
A few questions:
1) Does that suggested nMedia case have an LCD? It appears to. If so, what does it display? For this case (or others with LCD), what do they display and how are they configured?
2) What does the silver knob on the case control?
3) I saw a mention of the i3 having trouble with XBMC (due to DXVA). Can anyone elaborate? Does it mean watching videos with XBMC/i3 will be horrible or is it something that only affects some specific type of video, bitrate, etc?
About the only thing making me consider XBMC over Win 7 MC is that (as far as I have been able to find) there is no way to view Hulu and Comedy Central shows like Daily Show and Colbert Report from within MC. I don't want to have to exit MC to launch a browser if I can help it. XBMC has a couple plugins that very nicely integrate Hulu and other online content.
4) Any pros/cons to using a 5400rpm 2.5" HDD? A friend has a WD Scorpio he bought and never used that I could have. I don't need a lot of local storage in the HTPC since I have a NAS.
5) Any other suggestions for a case with integrated IR receiver? I see the Antec Microfusion but not crazy over the silver, and really don't think I need or want an LCD.
Too bad I missed the Shell Shocker yesterday on Newegg, I might have just jumped on it and figured out the rest of the components as I go!
bswiz is offline
post #193 of 15974 Old 01-11-2011, 06:31 PM
skro's Avatar
Quoted: 13 Post(s)
+1 to hear our resident experts chime in on the DXVA issue that others have mentioned. Is it a horsepower issue, or an instructions issue with the i family of processors. What is the real world impact of this "issue"?
skro is offline
post #194 of 15974 Old 01-11-2011, 07:35 PM - Thread Starter
assassin's Avatar
Quoted: 79 Post(s)
Liked: 242
A few questions:
The case I posted is simply one of a multitude of cases. Don't think that you have to get that particular one or there are no other cases that won't work as well.
1. It has a space to add an LCD but if I remember correctly doesn't come with one. I have never actually done this. For me I don't see the need. If you do add one you can usually control it with included software. I actually would prefer a case with no lights if they offered it.
2. The silver knob is an oversized power button.
3. I don't use XBMC. I have never had any issie with any format on mediabrowser/WMC.
4. Very few cons, imo. There are actually a lot of pluses to using a 2.5" drive if you don't need the storage. Less size, less power usage, less noise (usually), etc.
5. I wouldn't buy a case because of the IR receiver (because there simply aren't that many). Instead I would buy a case that I liked and add something like this for $30. It works with any WMC remote in Windows 7.
http://www.newegg.com/Product/Produc...-191-_-Product
post #195 of 15974 Old 01-11-2011, 07:36 PM
Frankgg's Avatar
Overclocking results for the i3 540 & ASUS mobo...
Sticking to stock voltages, I pushed the BCLK from 133 to 200, overclocked the CPU from 3.06Ghz to 4.01Ghz, and the iGPU from 733Mhz to 900Mhz.
Just got done running Intel Burn Test and FurMark at the same time, its purdy stable!
Real Temp recorded a max die temp of 69C
Frankgg is offline
post #196 of 15974 Old 01-11-2011, 07:41 PM - Thread Starter
assassin's Avatar
Quoted: 79 Post(s)
Liked: 242
Looks like this is not entirely true. Here's some quick results of an even quicker google search...
http://www.howtogeek.com/howto/10613...-in-windows-7/
post #197 of 15974 Old 01-11-2011, 07:43 PM - Thread Starter
assassin's Avatar
Quoted: 79 Post(s)
Liked: 242
Unless you are gaming there is absolutely no reason to overclock a HTPC. Its like using a bazooka to kill an ant.
Actually you DON'T want to overclock because it will lead to more heat and more heat will lead to more noise.
post #198 of 15974 Old 01-11-2011, 08:22 PM
bswiz's Avatar
Quoted: 66 Post(s)
Thanks for the quick responses. I realize that there are plenty of different cases out there, but like the one you suggest, and the price is reasonable too!
I agree with you about not needing/wanting an LCD - just one more distraction.
bswiz is offline
post #199 of 15974 Old 01-11-2011, 08:25 PM
bswiz's Avatar
Quoted: 66 Post(s)
Yeah, somehow I missed this - thanks (again!). Now if you can find a way for me to integrate Colbert Report and The Daily Show into WMC somehow, I'll be in business and have no real need for XBMC.
I know it seems silly to base a media software decision on just a couple shows, but those are the two main shows from cable that I *really* want to integrate into an HTPC.
Edit: The same person who wrote the Hulu desktop integrator for WMC also has one for XBMC integration. So in theory I could use WMC for everything except Daily Show and Colbert and switch into XBMC just for those. Seems a little funky, but I guess it would work!
bswiz is offline
post #200 of 15974 Old 01-11-2011, 09:23 PM
gerryinnv's Avatar
Anyone tried the SilverStone Case GD05B?
http://www.amazon.com/SilverStone-Al...4805503&sr=8-1
I was about to pull the trigger on it at amazon but after reading some of the reviews I decided to hold off and try to confirm. The two that most concern me are:
1) The location of the power supply makes it very far from the P4 PSU connector on the motherboard.
2) That you can't install a DVD drive in this case without blocking the CPU fan.
gerryinnv is offline
post #201 of 15974 Old 01-12-2011, 12:43 AM
Frankgg's Avatar
I get what you're saying, but staying with stock voltages keeps the temp increases to minimum... couple that with a the Big Shuruken CPU cooler, its still running just as quiet as at stock speeds.
Not overclocking a CPU, thats crazy talk!!!!
ETA: I'td be silly not to at least OC the iGPU from 733Mhz (i3 default speed) to 900Mhz (i5 default speed) as it's the same exact iGPU, Intel just lowered the clock speed on it for the cheaper i3's.
Frankgg is offline
post #202 of 15974 Old 01-12-2011, 07:32 AM
bonscott87's Avatar
Thoughts?
Netflix is inferior on PC's for one simple thing: Silverlight. Has nothing to do with horsepower, pretty much any PC will run laps around a dedicated box in terms of horsepower. But Silverlight stinks and Netflix also does not allow a lot of their HD to stream via the PC and no 5.1 either.
Having said that, a couple days ago my wife was sick and watched Aliens (gotta lover her) streaming from Netflix. It was in HD and looked really good. No artifacts and no "stuttering". Call me impressed so MS may have tweaked Silverlight recently to make it better.
Scott
post #203 of 15974 Old 01-12-2011, 07:36 AM
bonscott87's Avatar
Yep, Hulu Desktop integration works great with that plugin. Been using it almost a year now.
As for Comedy Central, there are a couple things you can do. You could use Playon which will then integrate into WMC via the VMC PlayIt plugin.
IF Daily Show is available via RSS feed then you could simply ad that RSS feed to Media Browser and it'll be right in there.
Also check Boxee. I think it pulls in the Daily Show feed as well but I haven't checked it in a long time. The same people that do the Hulu integration also do a Boxee integration plugin.
Scott
post #204 of 15974 Old 01-12-2011, 07:38 AM
bonscott87's Avatar
Looks pretty similar to my Silverston GD04B I have. LOVE that case. I posted pics earlier in this thread but here is another link to my build I did a year ago: http://picasaweb.google.com/bonscott87/HTPC#
1) Shouldn't be an issue.
2) Also shouldn't be an issue. Stock cooler for an i3 is plenty short enough. If you must do an aftermarket cooler then just make sure it's less then the height Silverstone recommends.
On the Silverstone site it looks to me that the GB05 is just an updated version of the GB04 and has a different front panel. http://www.silverstonetek.com/produc...pno=GD05&area=
Scott
post #205 of 15974 Old 01-12-2011, 08:06 AM
bswiz's Avatar
Quoted: 66 Post(s)
Good suggestion on PlayOn. Although it adds cost, looks like it might even be useful to stream some of this content direct to my TV (Sony with DLNA). So could I install the PlayOn SW directly on the HTPC? Would the i3 system Assassin suggested have the horsepower to run PlayOn and XBMC and/or WMC together?
bswiz is offline
post #206 of 15974 Old 01-12-2011, 09:08 AM
galewskj's Avatar
Thanks Assasin for the good recommendations and thanks everyone for a lively discussion.
I am about to build an i3 based HTPC. The sticking point for me is that I think it would be beneficial to have USB 3.0 on the motherboard. The recommended Gigabyte motherboard has USB 3.0 but quite a few people on Newegg and elsewhere are complaining about stability issues. I don't see a micro ATX motherboard from ASUS that has USB 3.0.
Right now I am thinking of buying the ASRock H55M/USB3 R2.0 motherboard or sticking with the recommended Asus P7H55-M PRO that does not have USB 3.0.
Anyone have an opinion? Will it be important to have USB 3.0 in the future?
galewskj is offline
post #207 of 15974 Old 01-12-2011, 10:39 AM
tehowell's Avatar
Will you want/need to copy huge amounts of data back and for from an external device like a thumb drive or hard drive?
I use another machine to manage my media, so I don't need it on my HTPC.
Samsung UN65JS8500 65" SUHD TV FW1455; Yamaha RX-A750BL Receiver FW1.77; Samsung UHD-K8500 UHD BD player, FW1005, w/dual HDMI; one to TV (video), one to AVR (bitstream); Arris DCX-3600M Cable STB; Nvidia Shield Android TV Update 3.2, Server: Windows 10 Home and Emby Server.
tehowell is offline
post #208 of 15974 Old 01-12-2011, 12:10 PM - Thread Starter
assassin's Avatar
Quoted: 79 Post(s)
Liked: 242
You're welcome.
USB isn't essential but if you can get it for the same price as a USB 2.0 board then obviously you go with the USB 3.0.
However, I think that USB likely won't really be that big of a deal in the long run. I like to have it as an option in case there is some sort of cool new peripheral device in the next year or 2 that needs USB 3.0. But honestly anything new will likely run on USB 2.0 just fine. If you hook up an external hard drive full of movies, music and pictures for example USB 2.0 will be more than enough. Its also pretty easy to add a PCI-express card in the future to "add-on" USB 3.0 at a later date.
In regards to the Gigabyte MB stability I saw those comments too. However, I have built 3 i3 systems with that particular Gigabyte MB (as well as other Gigabyte MBs) and all 3 are rock stable with no issues.
Again, my choice of what motherboard companies I think are best was mainly based on reviews, reputation on AVS forum and personal experience. There are other MBs that are extremely capable as well --- I just don't have as much experience with them. I do think the build quality of Gigabyte and ASUS are a notch above most others.
ASRock is a subsidiary of ASUS. In general they make entry level components that usually don't have the bells and whistles of the ASUS boards.
Having used the Gigabyte USB 3.0 board (and loving it) I would buy one again. However I see your reservation with it given some of the reviews. If this is still a major concern I would go with the ASUS 2.0 board.
post #209 of 15974 Old 01-12-2011, 01:28 PM - Thread Starter
assassin's Avatar
Quoted: 79 Post(s)
Liked: 242
I've been looking the past few days for a good illustrated step-by-step building guide until I get mine up and running.
After much searching I have found one that I would have been proud to call my own. It is very good.
http://www.tomshardware.com/forum/27...guide-building
Please use this as a reference till I get ours up and running. I am still waiting on some build pictures using some of the parts that I recommended.
I will also reference this link on post 2 of this thread for now...
post #210 of 15974 Old 01-12-2011, 02:40 PM
bswiz's Avatar
Quoted: 66 Post(s)
I'm really liking the look of the nMediaPC 5000B (as recommended in the OP) and the Silverstone GD04B (as recommended by someone else in this thread).
However, initially I was planning on not installing any optical drive. Does that mean I would have a gaping hole in the case? Or can that little cover be installed somehow without the drive? I do have a extra DVD burner I could install I suppose. Does that cover just attach to the optical drive with double-sided tape or what? So if I added a BD drive later I could just swap the cover onto it?
I think the DVD drive I have is an old IDE, not even sure if it would hook up to these newer motherboards!
bswiz is offline
Reply Home Theater Computers
Rosewill Windows Vista Certified Media Center Infrared Remote Control Rrc 126 , New Logitech Harmony One Keypad Touch Screen Advanced Universal Remote Control Infrared Display Lcd
