Tagging into MKV container - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-18-2011, 11:41 AM - Thread Starter
VTCop's Avatar
Hi! I have decide to capture my olds vhs tapes into my computer, and I had decided to make into MKV.
I have Windows 7, and now my problem is that Windows 7 is not able to edit the metadata of a MKV file, such as rating, tags, keywords, title, comments, etc...
I have tried with MP4 and windows explorer is capable to do this without problems, simply right-click the file and click on Details.
I have searched for other software to edit my MKV's and add rating and tags, but I have no found any.
Why MKV doesnt support tagging?
I have read that MP4 container also support H264/X264 codec, then... is best MP4 than MKV?
VTCop is offline
post #2 of 5 Old 01-18-2011, 03:16 PM
Servicetech571's Avatar
"Media Center Master" (to autotag metadata) and Mediabrowser (to view metadata in WMC) will resolve this.
Servicetech571 is offline
post #3 of 5 Old 01-19-2011, 01:58 AM - Thread Starter
VTCop's Avatar
Sorry, I dont want to create a xml file with the tags. I use metabrowser, but i want that the tags goes into the mkv file, not separtely. Some like in a JPG or in a MP3 or a MP4
VTCop is offline
post #4 of 5 Old 01-19-2011, 06:36 AM
It's easier just to create a folder for each movie and xml it. I fought it too until I finally saw the light. If you name the MKV/MP4 correctly (name with year) mediabrowser will normally pick it up, even w/o a xml file.
post #5 of 5 Old 01-20-2011, 01:53 AM - Thread Starter
VTCop's Avatar
I want the metadata goes into the mkv file because so I can search for tag with Windows Explorer and I will found images, videos, docs, etc
VTCop is offline
Reply Home Theater Computers
