Windows 32bit or 64, wich works better for HTPC use? - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 147 Old 08-02-2013, 12:01 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Originally Posted by StardogChampion View Post
You guys realize the last post in this thread was six months ago and that someone joined AVS just to post a math lesson that you're replying to and freaking out over.
But, you keep feeding the trolls...
LOL!
Sammy2 is offline
post #122 of 147 Old 08-02-2013, 12:13 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Originally Posted by Sammy2 View Post
It is? Really? For HTPC use? The only difference in HTPC's is how many extenders you can run at the same time off the machine.
Considering I have not built a system with 3GB of Memory or less in many years- Yes it is.
32bit is limited to 3GB of RAM- who does that these days? Every build I do is 8GB, and even with 4GB you still want 64bit. If your starting today installing I see no point in installing 32bit OS. 32bit stuff still runs on 64bit so why not ???
Mfusick is offline
post #123 of 147 Old 08-02-2013, 12:28 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
But that is a far cry from being compared to dial up for HTPC use. The only time you ever come close to maxing out the RAM is during extender use. I know this for a fact. I have a 32 bit system with 4Gb (3.6Gb usable) that has been running just fine for over 2 years now. I did this for simplicity of codec set up at the time. It works great and Doesn't come even close to maximizing the RAM or CPU when it is feeding the HTPC and one extender at the same time. It can do another one for sure but I think that a 3rd will bog it down to the point of stuttering but at that point it is both RAM and processor cores (i3-550 here) that are both the issue. Fortunately I don't have a bunch of viewing on an extender going on in my set up.
If I were to do it today, I't go x64 for sure but I'm also not going to go back through and set up my system again under x64 as x86 gets the job done and should not be considered analogous with dial up compared to Cable internet.
Sammy2 is offline
post #124 of 147 Old 08-02-2013, 12:44 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Your assuming everyone has 4GB biggrin.gif How about those that have 16GB biggrin.gif It's almost certain to always be using more than 3GB eek.gif
The amount of RAM you use has to do with how much you have. Windows seems to manage that. Using over 3GB is not hard at all when you have 8GB like most on this forum do.
Mfusick is offline
post #125 of 147 Old 08-02-2013, 12:49 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I am at work now on my office PC. All I do is email and MS word and Excel. No games or anything crazy. With multiple tabs and my email client open I cruise around at over 3GB.
This is a 2600K CPU (which hardly stretches it's legs) and only 8GB of Gskill DDR3 1600mhz.
Pretty common ram and pretty common applications. Using over 3GB is not hard if you have 8GB+ Windows manages how much you use so you almost never use 100% of what you have, unless you have too little.
Mfusick is offline
post #126 of 147 Old 08-02-2013, 01:28 PM
cybrsage's Avatar
Liked: 154
Other than you, who is freaking out and trolling the thread?
cybrsage is offline
post #127 of 147 Old 08-02-2013, 01:32 PM
cybrsage's Avatar
Liked: 154
All in all, most HTPCs have no need for more than 4GB of RAM. Sure, if you have many extenders you do, or if you use the HTPC for transcoding or other things you do. A case was made that a HTPC used to watch TV, BluRays, etc., only actually needs 2GB of RAM. You are cutting it very close with that, though, so I would say to use at least 4GB.
cybrsage is offline
post #128 of 147 Old 08-02-2013, 01:33 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I was genuine in my response. I did not notice the age of the thread. I only look at the post above mine, and it was like the same day. I was sincere in my reply too.
I later realized it's an old thread.
But- little has changed on the 32bit vs 64bit issue. Go 64bit and do not look back. No one is building 1GB and 2GB DDR2 systems anymore. 4GB DDR3 is considered entry level and 64bit is warranted.
Mfusick is offline
post #129 of 147 Old 08-02-2013, 01:36 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Right- but why choose 32bit over 32bit. Even 4GB you should probably go with 64bit these days.
I think the argument about how much ram you need is different. Your right most times you need 2GB, but everyone knows more ram is nice. Why cut it close? Most use 4GB on budget builds, and actually 8GB most of the time. High end is 16GB+
Even 4GB could use 64bit well. No need to install 32bit these days. It's time has passed.
Mfusick is offline
post #130 of 147 Old 08-02-2013, 02:27 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I used 32 bit in 2011 when I was having codec issues. It made things simpler at that time. My HTPC runs fine and is all set up to go. I don't have extra time to re-do it although I even have a spare SSD to set it up on. If I were doing it today I would go with 64 bit which I have had on my PC with 8Gb RAM since I built that i5-650 in 2010. This is where all the heavy work is done (ripping, transcoding with Plex, etc) but the HTPC doesn't need 64 bit windows or more than 4Gb of RAM unless you are running a houseful of extenders or transcodeing on the HTPC. I can attest to this fact as I use it every single day without issue.
Sammy2 is offline
post #131 of 147 Old 08-02-2013, 02:56 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I agree. We should stop argueing:D 32 bit is fine. My point was in 2013 you should probably ditch the 32bit and go 64bit at this point. You going back three years in time as your justification why you have 32 bit, which is fine. But I am talking about today.
Mfusick is offline
post #132 of 147 Old 08-02-2013, 03:04 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
BINGO!
Go with Win7x64 today!!
Sammy2 is offline
post #133 of 147 Old 08-02-2013, 03:24 PM
cybrsage's Avatar
Liked: 154
cybrsage is offline
post #134 of 147 Old 08-02-2013, 03:25 PM
cybrsage's Avatar
Liked: 154
BINGO!
Agreed.
cybrsage is offline
post #135 of 147 Old 08-02-2013, 03:42 PM
gazebo's Avatar
Quoted: 14 Post(s)
Every time I see this 32-bit vs 64-bit discussion, I always ask myself this question: Is there finally a 64-bit driver for firewire set top box for recording HD TV programs?
Didn't think so. So 32-bit it is for me, probably forever.
I wished the 64-bit proponents are right, in that by now there should be a 64-bit driver for "everything" out there. And BTW firewire is not dead or obsolete hardware.
gazebo is offline
post #136 of 147 Old 08-02-2013, 03:55 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
madVR is 32 bit as well but it is all about utilizing more RAM.
Sammy2 is offline
post #137 of 147 Old 08-02-2013, 08:45 PM
cybrsage's Avatar
Liked: 154
I wonder if the next Microsoft OS will even have a 32 bit version.
cybrsage is offline
post #138 of 147 Old 08-03-2013, 04:53 AM
tman247's Avatar
Quoted: 56 Post(s)
Liked: 50
My Win7 HTPC is 32-bit with 4GB RAM. Runs like a champ. I'm certainly not going to move to 64-bit for the sake of it. No need at all, but all new systems I now build are 64-bit. When the time comes (if it does, as MS clearly seem to want MC dead and buried) then I'll look at my options, but while I was surprised there was even a Windows 8 32-bit edition, I really can't see Windows 9 32-bit being released. It just wouldn't make much sense. I suppose Windows 8 32-bit was only made available to allow Windows 7 32-bit users to upgrade without having to do a full re-install. Can't see any other reason.
tman247 is offline
post #139 of 147 Old 08-13-2013, 01:58 PM
mcguidance's Avatar
Not to open this can of worms again, but I just bought a cheap version of windows 32 for my build. I have a 8gb of ram, will I be able to run a solid htpc with this set up?
mcguidance is offline
post #140 of 147 Old 08-13-2013, 02:01 PM
bryansj's Avatar
Quoted: 1130 Post(s)
Liked: 560
Your Windows install will only see up to 4 GB of RAM so you have double the RAM you can actually use.
bryansj is offline
post #141 of 147 Old 08-13-2013, 02:48 PM
mcguidance's Avatar
I'm an idiot. Oh well, now I know.
post #142 of 147 Old 08-13-2013, 05:16 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Just send it to me. I'll see that it is taken care of. BTW, what are the timings?
Sammy2 is offline
post #143 of 147 Old 08-14-2013, 06:32 AM
cybrsage's Avatar
Liked: 154
Look up info on RAM drives - you are a prime candidate to use them. smile.gif
cybrsage is offline
post #144 of 147 Old 08-15-2013, 07:20 AM
mcguidance's Avatar
I was lucky enough that the guy had 64 bit on hand, so he swapped it out for me.
post #145 of 147 Old 08-15-2013, 07:31 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
In my experience, the product keys are not bound to 32/64-bit anyway, so even if you purchased 32-bit, you can grab a 64-bit install ISO from official Microsoft sources, and simply install that.
Nevcairiel is offline
post #146 of 147 Old 08-15-2013, 11:18 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
That is what I've experienced too.
Sammy2 is offline
post #147 of 147 Old 08-15-2013, 01:09 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
There is better ways to record cable TVs, it is called CableCard tuner. It saves you money (by not leasing a set top box) and gives you better control (most cablecard tuners support 2 to 6 tuners).
Yes it is.
Sammy2 likes this.
Foxbat121 is offline
Reply Home Theater Computers
