Multi Tuner - Multi Monitor Out? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-05-2011, 02:21 PM - Thread Starter
nairdasti's Avatar
Hey All,
I've been a longtime reader here at avs, and was wondering if this is possible.
I have the following setup:
htpc *(quad amd am3, 8gb ddr3)
Ceton quad tuner
Dual ATIhd vid cards *(both hdmi out)
Now, running from this 1 pc, is there a way to run 2 tv-shows on 2 seperate monitors at the same time?
I'm thinking of a setup for ncaa tourney time with multi-games on different screens, with 1 output going to just a tv, *(no sound), and a second "feature" tv with sound going through a 5.1.
Any ideas?
-Thanks!
nairdasti is offline
post #2 of 7 Old 02-05-2011, 02:56 PM
captain_video's Avatar
Quoted: 510 Post(s)
Liked: 336
You can't have different outputs at the same time, even with multiple video cards. You can, however, set up multiple media extenders and run them off the HTPC via a network connection. Check out this site for the ultimate Media Center Home Sports Bar setup:
http://www.hdhomesportsbar.com/
captain_video is offline
post #3 of 7 Old 02-05-2011, 03:42 PM
Davinleeds's Avatar
There's difficulty, but yes you can. I have had TMT on 1, PDVD on 2 and Autumn Wave GT on a third.
Also audio it seems is not that difficult as long as you have displays enabled.
http://forums.guru3d.com/showthread.php?t=337698
As long as the tuner is capable of dual output. It is a PAIN as I have found no way of easy restart. Each time you have setup each display to output manually.
"The purpose of diplomacy is to prolong a crisis." Spock, Mark of Gideon, TOS
Davinleeds is offline
post #4 of 7 Old 02-06-2011, 10:59 AM - Thread Starter
nairdasti's Avatar
captain_video,
not different outputs, but I'm looking more for having, for instance, 2 windows open in windows running 2 different channels off of 2 different tuners, on 1 OS. Also, I'm looking for ways to use my current setup without having to purchase extenders
What do you mean I can't have different outputs running at the same time? Multi-monitor setups have been around for ages, no?
post #5 of 7 Old 02-06-2011, 11:10 AM - Thread Starter
nairdasti's Avatar
Davin,
The streams part I completely agree with, but do you know of any software outside of WMC that can run multi-instances?
post #6 of 7 Old 02-06-2011, 11:45 AM
stanger89's Avatar
Quoted: 2639 Post(s)
Liked: 1354
stanger89 is offline
post #7 of 7 Old 02-06-2011, 11:47 AM
Davinleeds's Avatar
Just a quick search for one:
Plus, it supports multiple TV tuners or capture cards and allow you to watch the videos from different cards at the same time - I don't know if this means multi monitor.
http://www.avermedia.com/avertv/Uplo...are/index.html
Maybe http://www.gbpvr.com/
You could definitely watch a .ts recording on another display with TMT or PDVD or another while watching tuner on another.
Reply Home Theater Computers
