*Official* Asus E35M1-M Pro AMD Zacate motherboard thread - Page 5 - AVS | Home Theater Discussions And Reviews
Old 02-23-2011, 05:20 PM - Thread Starter
perpetual98's Avatar
Quoted: 18 Post(s)
Just had the PC drop off the network again. Good thing I caught it before my wife's American Idol didn't tape! LOL I hadn't attempted the Realtek update yet. Might try it after things are done being recorded and then get an Intel NIC ordered.
perpetual98 is offline
Old 02-23-2011, 06:58 PM
almostinsane's Avatar
Liked: 26
Yep - Realtek is complete crap. Go with Intel.
almostinsane is offline
Old 02-23-2011, 08:44 PM - Thread Starter
Quoted: 18 Post(s)
Looks like I'll have to order the Intel. Doesn't appear that anyone local carries them.
Old 02-24-2011, 01:48 PM
thaxphenomx's Avatar
I have some questions about this board. I'm thinking about going with this over having to buy a mobo/cpu/graphics card all separate.
1) Was anyone able to bitstream audio through MediaBrowser using Shark007 codec pack?
2) Are you able to playback 1080P and navigate through MediaBrowser at the same time smoothly?
I'm also considering going with an AMD setup with a GT430. I know the GT430 can easily handle 1080p playback and browsing at the same time.
thaxphenomx is offline
Old 02-26-2011, 10:31 AM
joners's Avatar
What is the windows experience index rating for processor and graphics?
joners is offline
Old 02-26-2011, 10:47 AM - Thread Starter
Quoted: 18 Post(s)
3.1 WEI score. Down the list, mine goes:
3.9
5.1
3.1
5.6
7.4 (OCZ Vertex 2 SSD)
Old 02-26-2011, 02:21 PM
mesasone's Avatar
I wonder what would account for the "graphics" score being so much lower than the "gaming graphics" score? If anything, you would think it would be the other way around.
IBEW Local 1643
mesasone is offline
Old 02-26-2011, 02:49 PM - Thread Starter
Quoted: 18 Post(s)
I was kind of wondering that myself. I wonder if it's because the new chipset is DX11? I should really throw a WoW folder onto that PC and see what kind of framerates I get at 1080p.
Old 02-26-2011, 02:54 PM
whiteboy714's Avatar
WEI is a pointless benchmark.
whiteboy714 is offline
Old 02-26-2011, 08:31 PM
mxnerd's Avatar
Did you turn off power saving for NIC?
If you don't move mouse/keyboard for a while, probably the NIC goes into sleep mode?
mxnerd is offline
Old 02-26-2011, 09:35 PM
dj4monie's Avatar
Blu-Ray hardly puts any pressure on the CPU or GPU, fully accelerated 20-30% CPU usage, plenty left over to browse the "net".
A. Thomas -
GSN: djfourmoney
'03 SRT-4 12.74@106 in the 1/4
PSN - DJFourMoney
dj4monie is offline
Old 02-27-2011, 07:05 AM
bjterry62's Avatar
+1
Win 7 has a ton of options in the power profiles section, many of which are on by default. NIC is one of them. Make sure you turn it off.
BT
Just remember, to the MPAA "We're all guilty until..............."
bjterry62 is offline
Old 02-27-2011, 07:10 PM
joners's Avatar
I only ask so I can compare it to my D954GCLF2 Atom 330.
Mines 2.4
3.3
4.4
2.4
3.1
7.2 (Corsair F40 SSD)
It cant play 720p rips, this new Asus board looks pretty promising for me to replace the Atom 330.
joners is offline
Old 02-28-2011, 10:36 AM
mxnerd's Avatar
I can't wait any longer and ordered one last week and just got my board. It's tiny & it's the smallest MicroATX (9.6"x7.2") I have ever seen, almost half size of ATX board.
I confirmed that it support DDR3 1333 (selectable in BIOS), I got DDR3 1600 8GB on the cheap and run it at lower speed. ASUS should change the spec on their web.
mxnerd is offline
Old 02-28-2011, 10:54 AM
crazy8s's Avatar
Has anyone used this with Linux?
I know hardware acceleration isn't supported under Linux (for now anyway) but how does this cope with 720p mkv files?
Would it be pointless for me to buy this board (or any other Zacate board for that matter) if I intend to use it with Linux for HD mkv playback?
crazy8s is offline
Old 02-28-2011, 11:47 AM
cburbs's Avatar
Quoted: 12 Post(s)
What type of cases are people putting this board in?
"Dang! You got shocks, pegs... lucky! You ever take it off any sweet jumps? "
Sony 55EX500 Settings
cburbs is offline
Old 02-28-2011, 12:16 PM
mxnerd's Avatar
I bought this In Win IW-BL647.300TBL at Mwave. I liked it. Very, very quiet, well constructed yet light weight, and spaces to work around. The review at Newegg is not so great about it's power supply though. Will see.
mxnerd is offline
Old 02-28-2011, 12:39 PM
Augus's Avatar
you can check out this thread http://www.avsforum.com/avs-vb/showthread.php?t=1315402
Augus is offline
Old 02-28-2011, 12:48 PM
cburbs's Avatar
Quoted: 12 Post(s)
Do you have the list of your full build - That case looks like the case to my small msi athlon pc.
I am looking to build something that will fit in my audio rack and blend in well...like this
http://www.karmadigital.com/tf5_htpc...e_pc_case.html
cburbs is offline
Old 02-28-2011, 01:21 PM
mxnerd's Avatar
I don't have a list yet since I haven't finalized it.
You can try the following list for HTPC case.
http://www.newegg.com/Product/Produc...case+micro+atx
One thing is sure. I already have a ASUS portable DVD drive, so I'm not going to put a heavy internal DVD drive into the case.
My 8G DDR3 1600 is this AVEXIR AVD3U16000904G-2SW. I got it last month for $69 at Mwave. Was limited to one set though, or I'm going to buy more.
mxnerd is offline
Old 02-28-2011, 01:43 PM
bjterry62's Avatar
Originally Posted by almostinsane View Post
I use Intel NICs in all my systems. Realtek has always been garbage - there's a reason all the non-top tier boards have them - they cost almost nothing to add on where Intel costs a considerable amount more to include.
Wasn't too many posts back the whole board was garbage, now it's only the NIC. Maybe these boards are like fine wine and get better with age?
BT
Old 02-28-2011, 01:54 PM
bjterry62's Avatar
Here.
BT
Old 03-01-2011, 01:29 AM
mxnerd's Avatar
My ASUS WEI score
8GB DDR3 1333
500GB Seagate 3.5" HD
Processor 3.8
Memory 5.3
Graphics 4.5
Gaming Graphics 5.8
Primary Hard Disk 5.7
mxnerd is offline
Old 03-01-2011, 11:23 AM
mxnerd's Avatar
I found BIG differences between video players.
1680 x 1050 monitor. Sorry, I don't have 1080p HDTV yet.
I installed ATI 11.2 driver, & Flash 10.2
Use the following NVIDIA 1080P test video
http://www.youtube.com/watch?v=XITHbsUUlYI
Using Chrome watching 1080P video on Youtube use ~70% CPU, always buffering.
after downloading the same mp4 video (using Jdownloader)
VLC 1.17 ~50% CPU, not usable at all. Will stop completely anywhere in the video for several seconds.
KMP 3.0 ~70-90% CPU, good, but not smooth enough.
Windows Media Player ~22-35%, smoothest, no stutter, no skipping.
Either AMD/ATI need to improve their driver or VLC/KMP, etc need to step up & improve the support of this platform.
mxnerd is offline
Old 03-01-2011, 03:01 PM
mxnerd's Avatar
Well, I played the exact same 1080p test file above on my Athlon X4 2.9G machine (8GB DDR2 800, onboard ATI 4200 HD)and got a complete different result.
The file played absolutely fine with no issue with VLC, yet the KMPlayer keep stuttering and skipping.
Puzzled.
mxnerd is offline
Old 03-01-2011, 05:18 PM
dj4monie's Avatar
Why does AMD have to step up with support for open source video players???
When 98% of the public is going to be using Windows Media Player???
Don't scream because your open source, hardcore internet users video player needs to be updated by the PROGRAMMERS of Video LAN and not the other way around.
The SDK is out there, they can update it as they see fit.
A. Thomas -
GSN: djfourmoney
PSN - DJFourMoney
dj4monie is offline
Old 03-01-2011, 05:42 PM
mxnerd's Avatar
Well, I was just pointing out the issues, whoever interests in this board might like to know.
I don't really use VLC/KMP that often. Windows Media Player is completely fine with me.
mxnerd is offline
Old 03-01-2011, 09:53 PM
jman7's Avatar
Originally Posted by jeffkro View Post
Are those picoPSU's really that much more efficient than something like my Corsair 400W 80 plus certified atx power supply?
I just compared my Asus E35M-1 with my Antec 500 80+ power supply to my Pico-150 power supply with 150 watt power brick. Pico-150 bounced around from lows of 20 watt at idle to 30 watts doing things. Antec 500 watt ran lows of 40 watts at idle to highs of 55 watts doing things.
jman7 is offline
Old 03-01-2011, 10:22 PM
tmservo's Avatar
The open source players will catch up. In the end, what is really happening is that those players don't see DXVA options on the E350 yet (it's not in their list) meanwhile, WMP just detects from the driver and does it.
tmservo is offline
Old 03-01-2011, 11:12 PM
gazebo's Avatar
Interesting. I thought this kind of inefficiency is only associated with no-name PSUs that come with cheap cases. The worst I have seen is 12W over a pico for idle power consumption between a $20 case and the pico (42W vs 30W on an AM2 system).
gazebo is offline
