Unofficial mini-ITX case thread - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 671 Old 04-07-2011, 06:56 AM
MikeCandler's Avatar
Originally Posted by assassin View Post
This case has been discontinued which is a HUGE problem and leaves a huge void in the ITX HTPC case options.
I agree that this case is by far the best budget ITX out there.
I see the Athena options but those are already deactivated at Newegg as well.
So what's going to be the new go-to ITX case once these models are completely gone???
Crap really? When I saw it no longer on Newegg I figured something was up.
Going to have to make the Apex work...
MikeCandler is offline
post #152 of 671 Old 04-07-2011, 08:57 AM
muddyh2o's Avatar
Hey Guys
I took some photos of my build of fanless Zocate with ISK-100 and ripjaws, if anyone is interested.
I'll be updating the thread with tech details next week.
-mud
muddyh2o is offline
post #153 of 671 Old 04-07-2011, 09:03 AM
assassin's Avatar
Quoted: 171 Post(s)
Liked: 276
There are very few ITX cases that meet my criteria...
1. At least one 3.5" drive
2. At least one optical drive
3. Areas to mount an additional SSD or 2.5" drive
4. Power supply that isn't directly over the CPU fan.
Man, I loved that Rosewill. I am really sad to see it go.
assassin is offline
post #154 of 671 Old 04-07-2011, 09:18 AM
technoHD's Avatar
Here is an interesting list of Intel® Desktop Board Mini-ITX Chassis:
http://www.intel.com/cd/channel/rese...394803.htm?prn
The Rosewill and CFI -A8989 case equivalents are also listed there
technoHD is offline
post #155 of 671 Old 04-07-2011, 10:13 AM
That is exactly my concern, also the size the Rosewill was perfect as I only have a small amount of space and cannot go bigger.
Can you get a smaller PS for the Apex unit by chance? The 250W in it is over kill for most people and if you could get something even an inch or so shorter it would certainly make me feel a lot more comfortable.
post #156 of 671 Old 04-07-2011, 10:26 AM
assassin's Avatar
Quoted: 171 Post(s)
Liked: 276
You can use a PicoPSU.
assassin is offline
post #157 of 671 Old 04-07-2011, 10:39 AM
I have looked at them before, I guess that is the simplest solution if you are going to use the Apex.
I will send you a PM as to not clutter up this thread to much
post #158 of 671 Old 04-07-2011, 12:37 PM
jkleslie's Avatar
Originally Posted by dj4monie View Post
At Fry's they have a $40 mITX case with 300w and I think it looks fine, certainly better than the "cube" type cases you see.
http://www.frys.com/product/6145869
As much as I like the Habey cases, none of they space for expansion. It all has to be based on what you would put in laptops (mini cards) or USB which adds to the clutter.
For $40, I'd say this is pretty good. It has no "feet" so it can't be turned horizontal without covering up a cooling vent. That's easily solved...
That and the InWin Wavy are the only sub-$100 mITX cases I like that have a slot opening. The InWin has Four, not that you would use them all with a mITX board, but at else one additional can be used for extra USB ports, Firewire or eSATA.
Options, Options, Options
Used as a File Server - http://www.silentpcreview.com/forums...ic.php?t=57965
Used as a HTPC - http://www.overclock.net/htpc/835125...tup-wi-fi.html
Sure you can send more and get maybe a better looking case. But I'm driving to build a sub-$300 in parts HTPC and getting the cheapest case possible is important while still remaining stylish and giving me an important expansion slot.
Its either that or a bunch of USB devices...
I've been using one of these for a little under a year in our bedroom. It's a nice case and I like that it takes a full-size optical drive. I intially ran a Zotac ITX board in it but recently replaced it with an ASRock Zacate.
The PSU in it recently went out and had to be replaced, but I honestly didn't expect it to last as long as it did. For $40, it's a good buy.
jkleslie is offline
post #159 of 671 Old 04-07-2011, 03:05 PM
GatoEnFuego's Avatar
Originally Posted by Augus View Post
I am looking at this one regular price $56
APEX MI-008
250W PS
standard size drive bays: External 5.25", External 3.5", Internal 3.5"
front ports behind i/o cover panel
11.80" x 8.70" x 5.1"
I have this case on my Zacate build and it's a tight fit but what do you expect from a mini-ITX case?? Works perfectly, good quality, looks nice in the media center, best sub-$100 case out there IMO.
*edit* Don't let the picture fool you, it DOESN'T have a cheap looking purple power button... It's black and glows a faint blue around the edge when it's on. It's very subtle and looks mellow.
GatoEnFuego is offline
post #160 of 671 Old 04-07-2011, 03:36 PM
assassin's Avatar
Quoted: 171 Post(s)
Liked: 276
I've used that case with the i3. Terrible to use with the i3, imo.
assassin is offline
post #161 of 671 Old 04-07-2011, 03:40 PM - Thread Starter
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
More important: will Llano fit in the Habey 800 case ???
StardogChampion is offline
post #162 of 671 Old 04-07-2011, 04:05 PM
Uh oh, I already requested an RMA on my zacate and ordered the i3 sandy bridge... So does it fit and it's just tight or simply not usable?
post #163 of 671 Old 04-07-2011, 04:12 PM
assassin's Avatar
Quoted: 171 Post(s)
Liked: 276
Extremely tight. You actually have to use a little force to get the cpu and psu to fit.
That was with clarkdale and I bet the Sandy Bridge is the same.
assassin is offline
post #164 of 671 Old 04-07-2011, 04:16 PM
Almost looks like I could dremel off the fan "cage" and just make sure the cables are secured well away from the cpu... I doubt anyone would advise this but can't see much of a purpose of it other than to keep the sloppy errant SATA cable from stopping the fan.
post #165 of 671 Old 04-07-2011, 04:20 PM
chestnu1's Avatar
I belive I read somewhere that the sandy bridge heatsink fans are smaller then the clarkdale fans so you might not have to do anything.
You can never judge a show by its pilot episode or the half season following it.
chestnu1 is offline
post #166 of 671 Old 04-07-2011, 04:23 PM
The new goodies are sitting on the door step right now, can't wait to get home and tear into it. I love new electronics, there is something about breaking that anti-static seal...
post #167 of 671 Old 04-07-2011, 04:23 PM
ilovejedd's Avatar
Quoted: 76 Post(s)
Liked: 67
You know, you could just get a 3rd party cooler such as the Silverstone NT07-1156.
@chestnu1
35w TDP Sandy come with shorter coolers. Regular models come with the same cooler as Clarkdale.
ilovejedd is offline
post #168 of 671 Old 04-07-2011, 04:29 PM
@chestnu1
I'm crafty...where there's a will there's a way.
OT: Don't worry, I'll do the Legend of the Seeker test on the Zacate before I break it down.
post #169 of 671 Old 04-07-2011, 07:35 PM - Thread Starter
Quoted: 93 Post(s)
Liked: 160
I have one of these for my i3-540 in a PC-Q09 case. I am very happy with it. Highly recommended.
post #170 of 671 Old 04-07-2011, 08:10 PM
assassin's Avatar
Quoted: 171 Post(s)
Liked: 276
Well that stinks. That's an extra $25 that was not needed before.
assassin is offline
post #171 of 671 Old 04-08-2011, 10:19 AM - Thread Starter
Quoted: 93 Post(s)
Liked: 160
It wasn't necessary for the PC-Q09. It fits the stock cooler no issues at all except my stock HSF was noisy. The Silverstone is much quieter and I know it'll fit in smaller cases I might move the build into in the future to try out.
post #172 of 671 Old 04-08-2011, 10:34 AM
assassin's Avatar
Quoted: 171 Post(s)
Liked: 276
Good lord. That case is $150!
And it doesn't have room for a 3.5" drive.
assassin is offline
post #173 of 671 Old 04-08-2011, 10:44 AM
Hawkson's Avatar
Can I use a Mini ITX with the XONAR HDAV 1.3 AND the H6 Extension?
I haven't discovered how/where the H6 connects to the Motherboard and how much space it takes up.
Can I use a mini ITX or will I have to go Full ATX with this sound card?
Hawkson is offline
post #174 of 671 Old 04-08-2011, 10:46 AM
I'm an idiot... not sure why thought the fan motor was attached the fins and not the plastic around it. Duh. Well i put it all together last night and the power supply definitely touches the fan but i wouldn't say any "force" was required to get it all to fit.
post #175 of 671 Old 04-08-2011, 10:50 AM
ru4real's Avatar
Hopefully, the fan will still be able to provide enough cooling ability to prevent the CPU from catching on fire, unlike your cat.
My Sandy Bridge Gaming/HTPC Build
Cyrix PR166+ → AMD K6 200 → Intel Celeron 266 → AMD Athlon 1GHz → AMD Athlon 64 X2 6000+ → Intel i5-2500K
ru4real is offline
post #176 of 671 Old 04-08-2011, 10:54 AM
assassin's Avatar
Quoted: 171 Post(s)
Liked: 276
The one I built sounded like a jet engine when it was playing 1080p.
There is a thread on here somewhere with a picture from me which showed how to install another fan in the side of the case. I did that and it REALLY helped with cooling.
I'm just not a fan of a case where 3/4 of the CPU fan is covered and touching the PSU.
Edit: Here it is. 120mm fan.
Another option is to not use an optical drive and put your 3.5" hard drive in the 5.25" optical drive space with an adapter:
assassin is offline
post #177 of 671 Old 04-08-2011, 12:29 PM
mrdinosaur's Avatar
My favorite HTPC case is the Lian Li pc-q08. You can put a bunch of drives in it and use it as a NAS besides a media center. That way you wont need to network stream your HD movies. They will come from the same place.
mrdinosaur is offline
post #178 of 671 Old 04-08-2011, 02:41 PM
assassin's Avatar
Quoted: 171 Post(s)
Liked: 276
That thing is $120 and without a PSU.
assassin is offline
post #179 of 671 Old 04-08-2011, 02:55 PM
I can understand that, i have yet to put any stress on the new chip as i just barely installed windows last night. That 120mm fan is a good idea, I do have a 3.5" hd but there is a bay right below the 5.25" that I can use. Might do the upgraded low profile fan if this one turns out to be too noisy for me.
I like your hd "adapter" in that picture. What is that a long wire tie?
post #180 of 671 Old 04-08-2011, 02:57 PM
ru4real's Avatar
Aluminum costs more than steel, and some buyers find value in that, or in different features, aesthetics or construction quality. This thread appears to be open to discussion of all mini-ITX cases, not just low-cost cases with PSUs.
ru4real is offline
Reply Home Theater Computers
