How to stream MKV movies in WHS to outside network devices - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-21-2011, 09:34 PM - Thread Starter
dzirkelb's Avatar
Quoted: 45 Post(s)
How do I go about streaming my mkv files stored on my whs to an external to my laptop cpu?
I installed WebGuide as an attemp, but the mkv's aren't even listed as being there (when they in fact are).
I do have Air video installed on the whs for my i devices, and that works flipping awesome, so i'd like to have the same quality if possible as air video to other cpus external to my network.
Streaming internally works great, but I connect to the //servername to view the files.
dzirkelb is offline
post #2 of 5 Old 02-22-2011, 02:57 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
You can try to set up a VPN that both your WHS and Laptop can access. The one caveat is that you will be limited by the ISP on both sides, so dependent on this it could greatly impact the streaming performance. I believe there are front ends such as SageTV that will allow for Placeshifting functionality
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #3 of 5 Old 02-22-2011, 06:30 AM - Thread Starter
dzirkelb's Avatar
Quoted: 45 Post(s)
I would like to avoid a VPN solution if at all possible. I would like to make it easy so my wife can connect.
dzirkelb is offline
post #4 of 5 Old 02-22-2011, 07:49 AM
Calcvictim's Avatar
this might work for you, not sure if it's much easier then VPN though
http://smithii.com/map_a_network_dri...ssh_in_windows
You might be able to just port forward TCP 135, 139 and 445 and UDP 137 windows uses for network drives, and login to the external ip. This introduces a security risk, in reality you might be fine.
Calcvictim is offline
post #5 of 5 Old 02-22-2011, 08:42 AM - Thread Starter
dzirkelb's Avatar
Quoted: 45 Post(s)
I'm really looking for a solution like WebGuide or Air Video if at all possible. I read that people were able to stream MKV's using WebGuide, but their forums have been overrun by spammers, so I don't dare post there.
dzirkelb is offline
Reply Home Theater Computers
