Why do I have to turn my receiver volume up so high? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-07-2011, 08:33 AM - Thread Starter
DAUNlewis's Avatar
My HTPC has always had the problem where I have to crank the audio receiver up a lot to get the same audio level output bu my Xbox 360 or Blu Ray player.
I recently upgraded to an ATI 5670, and a Denon AVR-391 so I can use HDMI for audio and video now, and I still have the same problem! My receiver needs to be around -26 for the same volume level my Xbox puts out @ -45.
I run Windows 7 64bit and the same issue is present using WMP, VLC, or Media Portal.
Any ideas? The big issue is when I forget to turn the volume down and switch to XBOX, the xbox start sound almost blows my speakers at that volume.
DAUNlewis is offline
post #2 of 9 Old 03-07-2011, 08:40 AM
Pagali's Avatar
Quoted: 12 Post(s)
Liked: 24
What's the volume output of the HTPC set for? I keep mine at 100%, let the receiver control the volume. Seems to be pretty consistent with other sources.
Pagali is offline
post #3 of 9 Old 03-07-2011, 08:43 AM
bimmerfreak0's Avatar
Quoted: 21 Post(s)
Liked: 24
Source leveling. My xbox is different even internally for games vs. streaming audio vs. netflix.
I hear ya though.
Cable is usually (depending on channel) around -30.
Blu-ray and HD-DVD is -20.
Computer is -20 for movies, -30 for music
Xbox is -40 for games and -25 for netflix streaming.
I think it seriously is source based...I dunno.
bimmerfreak0 is offline
post #4 of 9 Old 03-07-2011, 08:50 AM
Fastslappy's Avatar
Liked: 749
yeah this is your problem ,
I had the same issue
on your desktop the little speaker icon on the lower right click it & make sure the windows volume is @ 100%
Mike
JAZZ IS NOT DEAD IT JUST SMELLS FUNNY ; FRANK ZAPPA
Fastslappy is offline
post #5 of 9 Old 03-07-2011, 08:53 AM
whiteboy714's Avatar
Quoted: 13 Post(s)
I was going to make a thread on this last night. My receiver has to be way louder with the HTPC.
Yes of course all windows volumes are 100%. I was wondering if there was a setting ti get some more sound out of windows.
I know for me it depends on the source because sometimes I download something low quality, but still even on blu ray I have to crank it pretty good compared to having a different source in the AVR.
whiteboy714 is offline
post #6 of 9 Old 03-07-2011, 09:02 AM - Thread Starter
DAUNlewis's Avatar
I am backwards in that I just use my wireless keyboard to change windows volume levels instead of using the remote, but the volume levels I mentioned are with my PC @100%.
post #7 of 9 Old 03-07-2011, 09:16 AM
Fastslappy's Avatar
Liked: 749
it might be the sound/vid card values are not @ 100%
i use a Asus xonar HDAV1.3 & that has a louder gain than my AVR does Onkyo TX-NR5008
but IIRC there is a volume setting on that driver panel
Mike
post #8 of 9 Old 03-07-2011, 09:21 AM
bighick's Avatar
What formats are you playing and are you bistreaming?
bighick is offline
post #9 of 9 Old 03-07-2011, 09:46 AM - Thread Starter
DAUNlewis's Avatar
Just set up the system, I set my CCCP audio codec to "Same as input". I'm playing everything from Youtube to MP3 to HD .MKVs.
Reply Home Theater Computers
