ati 5450 yamaha v663 no hd sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 03-11-2011, 04:34 PM - Thread Starter
akhowja's Avatar
I need some help on how to get hd sound thru my htpc and yamaha v663. Currently I have ati 5450 using window xp 32, playing movies with cyberlink pdvd10 on the info panel it says audio: dts hd master audio, and output: lpcm 48khz/16bit. How can I get it to output uncompressed hd... please help
thanks
akhowja is offline
post #2 of 23 Old 03-13-2011, 11:08 AM - Thread Starter
akhowja's Avatar
anyone?, any links that can help?...thanks
akhowja is offline
post #3 of 23 Old 03-13-2011, 11:20 AM
audit13's Avatar
Quoted: 36 Post(s)
Liked: 33
I had an ati 5450 and could never get it to bitstream under WinXP Pro or MCE until I added my Asus HDAV 1.3.
Under Win7, bitstreaming was no problem with just the 5450.
audit13 is offline
post #4 of 23 Old 03-13-2011, 11:46 AM
hotrodbob1976's Avatar
Follow this link, hopefully it should help.
http://www.mediasmartserver.net/2010...7-htpc-part-i/
hotrodbob1976 is offline
post #5 of 23 Old 03-13-2011, 01:35 PM
Davinleeds's Avatar
With XP, the only way I found to bitstream is Xonar.
"The purpose of diplomacy is to prolong a crisis." Spock, Mark of Gideon, TOS
Davinleeds is offline
post #6 of 23 Old 03-13-2011, 01:46 PM
Andrew Hornfeck's Avatar
Quoted: 30 Post(s)
Sure would liek to hear back on what you did... seems you might be able to use the MPC-HC w/FFDshow as the "free" option with Win-XP (although the example in the setup link was using Win 7 from the audio tab), or buy an "expensive" audio card or maybe it's time to upgrade to Win 7 as it would be cheaper than the audio card and would allow you to keep using Cyberlink's PowerDVD.
Andrew Hornfeck is offline
post #7 of 23 Old 03-13-2011, 04:40 PM - Thread Starter
akhowja's Avatar
I will follow the link and upgrade to win7. I'll get back with the results soon. Is Ix processor req'd?
Thanks for the replies.
akhowja is offline
post #8 of 23 Old 03-13-2011, 04:47 PM
audit13's Avatar
Quoted: 36 Post(s)
Liked: 33
Win7 has no built-in software for playing BRs or BR rips.
audit13 is offline
post #9 of 23 Old 03-13-2011, 11:10 PM
fitbrit's Avatar
Quoted: 54 Post(s)
Liked: 50
Another who was never able to get HD bitstreaming through a 5450 (and also V663) until I upgraded to Win7.
fitbrit is offline
post #10 of 23 Old 03-14-2011, 03:06 AM
Qaq
Qaq's Avatar
I had bitstream (SD) with 3200 under XP. After changing 3200 > 5450 I've lost bistream at all. It seems like ATI 5* (6*?) bitstream (no matter SD or HD) only works under Vista/7.
Burned by the Audio Inquisition
Qaq is offline
post #11 of 23 Old 03-14-2011, 10:01 AM
Quoted: 30 Post(s)
What? Are you saying you had an HD3200 (typically iGPU) performing bitstreaming of DolbyTruHD and DTS-MA formats? Hmmm..... Haven't heard that before regardless of OS.
OK, so you're saying SD bitstreaming... as in decoding DD and/or DTS in the PC and sending 6-channel PCM to the receiver... that I'll buy.
post #12 of 23 Old 03-14-2011, 09:14 PM - Thread Starter
akhowja's Avatar
So I tried the procedure on the link, every process was the same as the instructions. I am still getting no bitstream, also reset the receiver to factory just incase. I also did a edid override, which did not help as well.
Only thing I saw different from the instructions was under ffdshow-output-passthrough I only saw ac3 and dts(which I put checks on). The guide shows check marks on truehd, Dtshd, and Dolby digital plus.
Anyone know what the problem could be?
akhowja is offline
post #13 of 23 Old 03-14-2011, 09:26 PM
fitbrit's Avatar
Quoted: 54 Post(s)
Liked: 50
Yes, the problem is XP. The guide is for Windows 7. When you upgrade to Win7, you'll see that in your ATi 5450's HDMI audio out section of playback devices, DTS-HD and TrueHD will be available options in properties.
FFDShow should also give you the options to passthrough those audio formats. I think it's futile trying under WinXP.
fitbrit is offline
post #14 of 23 Old 03-15-2011, 04:25 AM
Qaq
Qaq's Avatar
Originally Posted by Andrew Hornfeck View Post
What? Are you saying you had an HD3200?
3200 only can 5.1 DD/DTS and 2.0 LPCM 48/16 no matter of OS. But 3200 can bitstream under XP at least, while 5* can not at all. User should have Vista/Win7 if he wants acceptable HDMI audio from ATI 5*.
Qaq is offline
post #15 of 23 Old 03-15-2011, 07:24 AM - Thread Starter
akhowja's Avatar
Yes I followed the guide with windows 7 ultimate... Under playback devices I did see truehd and dts hd, but not in ffdshow-passthrough...
akhowja is offline
post #16 of 23 Old 03-15-2011, 07:42 AM
audit13's Avatar
Quoted: 36 Post(s)
Liked: 33
You mean the 3200 can bitstream TrueHD and DTS-HD MA under XP? I'd be surprised if it could as Ati told me it couldn't when I contacted them about this when I started putting together my htpc.
audit13 is offline
post #17 of 23 Old 03-15-2011, 07:47 AM
steelman1991's Avatar
Quoted: 211 Post(s)
Liked: 116
An old version of ffdshow - all newer builds have the option to passthrough DTS-MA etc. in addition to DD/DTS
steelman1991 is online now
post #18 of 23 Old 03-15-2011, 08:03 AM
Qaq
Qaq's Avatar
No. Like I said above: 3200 can only 5.1 DD/DTS and 2.0 LPCM 48/16 no matter of OS
Qaq is offline
post #19 of 23 Old 03-15-2011, 08:51 AM
audit13's Avatar
Quoted: 36 Post(s)
Liked: 33
I guess I was confused by the use of the word "bitstream". When I have seen the word "bitstream" used on this forum, it has always referred to a lossless audio stream; i.e. True HD and DTS-HD MA.
audit13 is offline
post #20 of 23 Old 03-15-2011, 09:01 AM - Thread Starter
akhowja's Avatar
Using ffdshow beta 7... downloaded from http://ffdshow-tryout.sourceforge.net
I think its the lastest ffdshow???
akhowja is offline
post #21 of 23 Old 03-16-2011, 06:21 PM - Thread Starter
akhowja's Avatar
So I finally got bitstreaming hd audio. I downloaded saf v4.0, which gave me options for truehd and dts hd and the other formats that were not showing up before under the passthrough in ffdshow.
I appreciate the members for all the help and for the links which help me solve the issue, thanks.
akhowja is offline
post #22 of 23 Old 03-16-2011, 06:41 PM
Davinleeds's Avatar
Never heard of it. Do you have a link? Thanks
It links (google) to Media Portal - I guess I missed that.
post #23 of 23 Old 03-16-2011, 09:38 PM - Thread Starter
akhowja's Avatar
Yes,
http://forum.team-mediaportal.com/co...-vc-1-a-44614/
Go down to where it says download...This SAF includes both ffdshow and mpc-hc, Just setup them up the same way the link hotrodbob posted...
akhowja is offline
Reply Home Theater Computers
Yamaha Rx V663 Receiver
