HTPC: NO signal with HDMI cable thru Yamaha RX V367 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-12-2011, 09:20 AM - Thread Starter
haiphan02's Avatar
I'm trying to hook up my HTPC via HDMI thru my Yamaha RX V367 out to my TV, but I'm getting no signal. However when I connect my laptop thru the same cable, it works no problem. Could the problem be with my HTPC? It has a very good video card, a EVGA GTX 295.
But get this, if I by-pass the Yamaha RX V367 and connect the HTPC straight into the HDMI input of the TV, it works.
Is the problem with the receiver or the setting of the HTPC?
Thank you.
haiphan02 is offline
post #2 of 4 Old 03-12-2011, 12:12 PM
Andrew Hornfeck's Avatar
Quoted: 30 Post(s)
This could be based on your video card driver settings -- does it auto-detect the Yammy? Can you force a Detect Display? Compare how the display config panels look on your laptop to the PC and I'll bet you can find the issue. One more thing, switch the input on the Yammy to another Video input and then back - the HDCP handshake may not have acknowledged correctly.
Andrew Hornfeck is offline
post #3 of 4 Old 03-12-2011, 01:13 PM
audit13's Avatar
Quoted: 36 Post(s)
Liked: 33
I had a very smiliar problem with my LG plasma tv and Onkyo 705 avr. Turned out to be an incompatibility between my Onkyo and LG plasma.
My htpc connected to my Onkyo that was connected to my Samsung (all via hdmi) was perfect but not so with my LG.
Are you able to test your set up on another hdtv?
audit13 is offline
post #4 of 4 Old 03-12-2011, 04:46 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Check that resolution is HDTV standard (e.g 1920x1080).
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
Reply Home Theater Computers
