Looking to get HD Cable channels on my PC for viewing/recording - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-20-2011, 10:53 AM - Thread Starter
Blackout71854's Avatar
First off.. I don't know if I posted this in the right section.. Sorry if it isn't.
I have a HD tuner device on my pc and currently I'm only able to receive 5 HD channels. So in order to get the rest of the channels from the cable company I need to go through their box right?
Do most of these cable boxes have an coax cable output? I'm guessing they don't since 99% of the time, people just connect an HDMI cable to their HDTV.
Blackout71854 is offline
post #2 of 7 Old 03-20-2011, 11:07 AM
Leedogg's Avatar
Who are you with Charter, Comcast, Time Warner, or somebody else?? If you are with TWC you probably need a SDV converter also.
A Cablecard may work with your pc.
Leedogg is offline
post #3 of 7 Old 03-20-2011, 11:13 AM - Thread Starter
I am with Cableone, a local cable company.
What is a cablecard exactly?
post #4 of 7 Old 03-20-2011, 12:50 PM
scowl's Avatar
Quoted: 122 Post(s)
Liked: 39
http://en.wikipedia.org/wiki/CableCARD
They only work in cable company approved devices and may require the cable company to install it. You won't be able to plug one into any PC and get the encrypted HD channels.
NOW: my post on AVS Forum.
NEXT: someone else's post on AVS Forum.
scowl is offline
post #5 of 7 Old 03-20-2011, 01:51 PM
Ken H's Avatar
Any Digital TV tuner with clear QAM will get at least the local HD channels; ABC, CBS, FOX, NBC, PBC, etc.
For cable/sat HD you'll need a CableCARD host device in the PC, and a CableCARD from your cableco.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #6 of 7 Old 03-20-2011, 02:15 PM
jjeff's Avatar
Quoted: 688 Post(s)
Liked: 245
Another option is a Hauppauge card in your PC and component output from your STB or DVR. Note with this option you can only record what channel your STB/DVR is tuned to, or with the case of DVR what it might be playing.
jjeff is offline
post #7 of 7 Old 03-20-2011, 02:27 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
Please remember, the coaxial output of an HD cable box is not HD.
Only the HDMI and component outputs of an HD box are in HD.
domino92024 is offline
Reply Home Theater Computers
