Onboard adapter fried? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-20-2011, 03:35 PM - Thread Starter
bilbonvidia's Avatar
The integrated network adapter on my motherboard has stopped working, there are not even any activity lights. It had been working but I knocked the graphics card which feLl on the motherboard. I had to disconnect everything and removed the battery to get it working again but now I appear to have no network card. It is enabled in the BIOS. could I have knocked a jumper or something? Its a P5N7A-VM.
I have tried updating the bios no joy, the adapter will not even show up in device manager. Dya reckon I have fried it?
If so dilemma, a cheap pci - e card to use instead or a new board, if so what board? I dont need onboarg graphics any longer as have a ati 5770.
bilbonvidia is offline
post #2 of 6 Old 03-20-2011, 04:00 PM
whiteboy714's Avatar
This happened to me I just went to frys and got a $10 pci card.
whiteboy714 is offline
post #3 of 6 Old 03-21-2011, 04:05 AM - Thread Starter
I might try a pci-e network card, hopefully nothing else is damaged, although I can see anything on the board, capacitors etc look fine.
post #4 of 6 Old 03-21-2011, 10:28 AM
MrBobb's Avatar
Quoted: 164 Post(s)
Liked: 63
Could. Only you can check the manual see if any jumper(s) applicable. I am not going to do it! ^) The NIC is associated with an interrupt pin, typically jumpered.
If u feel like, disassemble everything, take the mobo out, clean it with a combination brush/compress air re-install and see what happens.
Or, NIC cards are dime-a-dozen, if u have free pci slot, or one of them usb dongle (but would use some cpu) is the lazyman's answer.
MrBobb is offline
post #5 of 6 Old 03-23-2011, 05:38 AM - Thread Starter
I bought a cheap gigabit pci-e card. All is now well. I think the graphics card must have landed on the realtex chip which looking at the mobo is infact directly below the bracket of the gfx card.
post #6 of 6 Old 03-23-2011, 06:52 AM
jkleslie's Avatar
I've seen this happen several times in my home...onboard Realtek adapters that either stop functioning completely, or get unreliable connectivity at nothing better than 100Mbps (when they are Gb compatible).
I'll just echo what's been said already...Ethernet cards are cheap - get one
jkleslie is offline
Reply Home Theater Computers
