PC Blu Ray picture displaying on DVI device but not HDMI device - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-28-2011, 11:57 AM - Thread Starter
DCritty's Avatar
Hello all,
I recently installed a Samsung Blu Ray drive (SH-B123L) into my HTPC, along with CyberLink PowerDVD 10. Here's my issue:
-BD video displays just fine to my Dell monitor (ST2410B) connected via DVI-D
-Unfortunately, BD video does not display to my Sony monitor (KLV-40ZX1M) connected via either an HDMI cable or a DVI-D-to-HDMI cable.
Note that it is only the video within the PowerDVD software that does not display to my Sony monitor. This suggests to me that there is some sort of HDCP issue (although this monitor is purportedly HDCP compliant).
I'm at my wit's end with this, and would very much appreciate any help. Thanks in advance!
DCritty is offline
post #2 of 3 Old 03-28-2011, 12:37 PM
Calcvictim's Avatar
run the cyberlink blu-ray advisor while connected to the TV, it will let you know if there is a HDCP compliance issue
http://www.cyberlink.com/stat/bd-support/enu/index.jsp
Calcvictim is offline
post #3 of 3 Old 03-28-2011, 01:32 PM
walford's Avatar
What resoloution are you using over DVI to the Dell and what resolution are you using over DVI/HDMI to the Sony Monitor? 1080i/60 should work to both of them wheras 1080p/24 may not.
walford is offline
Reply Home Theater Computers
