How do you make a seamless bootup into your media center? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 04-10-2011, 08:03 AM - Thread Starter
joeydrunk's Avatar
Quoted: 14 Post(s)
Does anyone know how to make a seamless startup on your Htpc? I have it setup in BIOS to what I thought would work better. It's better than normal, but not what I want. I turn on the HTPC and its the black screen for a few seconds listing all the system info, then it switches to a cool drawing/picture I have of a big roll of movie film. It's only on there for a second and then switches to the "windows starting" page. Then it switches to the login page wich I have the background of a MPAA green ratings screen and my little picture in the middle is film related also. After that it automatically goes into XBMC. For some reason that last part only works about half the time. I would like to fix that and get rid of the opening systems page and the starting windows page. Any ideas?
joeydrunk is offline
post #2 of 18 Old 04-10-2011, 10:12 AM
whiteboy714's Avatar
Put it to sleep with media center open.
whiteboy714 is offline
post #3 of 18 Old 04-10-2011, 01:01 PM
scfoxman's Avatar
scfoxman is offline
post #4 of 18 Old 04-10-2011, 02:10 PM - Thread Starter
joeydrunk's Avatar
Quoted: 14 Post(s)
Haha. I do this sometimes and it works great. I just have an enormous electricity bill and I need to keep stuff off.
post #5 of 18 Old 04-10-2011, 02:48 PM
I think when they sleep they consume like 5 or less watts.
post #6 of 18 Old 04-10-2011, 06:25 PM
Smitty2k1's Avatar
I like to set the desktop background to black, remove all icons, and hide the task bar.
But yeah sleep mode pretty much doesn't draw power
Smitty2k1 is offline
post #7 of 18 Old 04-10-2011, 07:38 PM
ogormask's Avatar
I think I get more oohs and aahs when people actually see its a computer attached to a tv. They just cant believe its a computer.
ogormask is offline
post #8 of 18 Old 04-12-2011, 09:29 AM
bjterry62's Avatar
My HTPC and clients are on 24/7. Go low power with your HTPC setup. Use a real PC for everything else.
BT
Just remember, to the MPAA "We're all guilty until..............."
bjterry62 is offline
post #9 of 18 Old 04-12-2011, 11:38 AM - Thread Starter
joeydrunk's Avatar
Quoted: 14 Post(s)
BT
I think it would look cool to have it start up seamless when I want it to. Right now i am using my Htpc for just Htpc activities. I use my laptop or phone for everything else.
post #10 of 18 Old 04-12-2011, 11:44 AM
zicoz's Avatar
Are you using Windows or Linux? If you're using Windows, You can try this solution that we worked out over at the mediaportal forums:
http://forum.team-mediaportal.com/in...tml#post645816
It launches Mediaportal instead of the Windows shell. To launch XBMC simply make some changes in the mediaportal.bat
zicoz is offline
post #11 of 18 Old 04-12-2011, 11:46 AM
Flaus's Avatar
You can setup MediaBrowser (if you use that front-end in Windows media center) to start automatically with windows. It is in the advanced settings int he configuration tool.
Flaus is offline
post #12 of 18 Old 04-12-2011, 12:06 PM
Darin's Avatar
Assuming you're using S3, it should only be about 2-3 watts in standby. That's about $1.75/year (assuming 21hrs of standby/day, and $0.09/kwh). If you had spent your time working instead of researching how to do this differently, you probably could have paid for using standby for the rest of your life.
My dual Rythmik Servo sub project (actually quad now, need to update page)
HDM format neutral thanks to the pricing wars of the '07 xmas shopping season :)
Darin is offline
post #13 of 18 Old 04-12-2011, 12:13 PM
tbraden32's Avatar
^^^and if we all took the easy route and did not research anything, I myself could have probably have bought 10 crazy awesome htpc's by now for my time involved in building just one simple HTPC....
but as most people on here say, what fun would that be?
tbraden32 is offline
post #14 of 18 Old 04-12-2011, 12:31 PM
Darin's Avatar
Personally, I think there's a difference between taking the easy route, and not taking the unnecessarily hard route.
I just kind of assumed everyone used sleep. I have an SSD in my HTPC, and it can boot pretty fast. But resuming from sleep is still much faster. When I click the "HTPC" button on my remote, Media Center is up and running before the TV re-syncs after the HDMI handshakes that happen when I change source. Having the PC boot every time would make it seem more like a PC, and less like a typical A/V component (unless we're talking about my HD-DVD player, which is even slower than the HTPC on a cold boot).
Darin is offline
post #15 of 18 Old 04-12-2011, 12:51 PM - Thread Starter
joeydrunk's Avatar
Quoted: 14 Post(s)
I do have it sleep most of the time and probably will continue to. But when it is off I want it look cool starting. More like a set top box than a pc. When your broke, any money saved helps, plus I really think there is somthing wrong with my electrical so it might save quite a bit more than that. Il find out after I test with my kill-a-watt.
post #16 of 18 Old 04-12-2011, 07:37 PM
bjterry62's Avatar
To start up seamless (no post, no windows welcome, no MB flash screen, etc.) you would need a custom boot flashscreen or flash video. You're going to have to use some type of boot screen software and there's no telling how that may effect your stability. The best solution is S3 like others have suggested. No body wants to wait for a full bootup, even with SSD.
BT
post #17 of 18 Old 04-12-2011, 11:04 PM - Thread Starter
joeydrunk's Avatar
Quoted: 14 Post(s)
BT
Maybe I want to wait.
post #18 of 18 Old 04-13-2011, 12:52 AM - Thread Starter
joeydrunk's Avatar
Quoted: 14 Post(s)
Here's some ideas for seamless booting also, incase anybody's interested-http://forum.xbmc.org/showthread.php?t=89168
Reply Home Theater Computers
