Remap green button on MCE Remote - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 04-17-2011, 01:29 PM - Thread Starter
Big Foot's Avatar
Is there a way to have the green button on the Microsoft remote launch the Windows start menu instead of Windows Media Center? This is the only piece missing that would allow me to alternate between using Windows Media Center and J. River Media Center with the remote.
Big Foot is offline
post #2 of 17 Old 04-17-2011, 03:55 PM
cybrsage's Avatar
Liked: 154
You cannot remap the remote itself, but I think Event Ghost will allow you to have the buttons do multiple things.
cybrsage is offline
post #3 of 17 Old 04-17-2011, 05:25 PM - Thread Starter
Big Foot's Avatar
Wow, this is even better. I was able to program a button on the MCE Remote to launch J. River MC. This is exactly what I needed. Thanks!
Big Foot is offline
post #4 of 17 Old 04-17-2011, 05:50 PM
cybrsage's Avatar
Liked: 154
Glad to be of help!
cybrsage is offline
post #5 of 17 Old 04-17-2011, 10:48 PM - Thread Starter
Big Foot's Avatar
I spoke too soon. Although I was able to program a button, I lost the functionality of many other buttons. I wasn't able to get all the buttons working again so I ended up removing EventGhost.
Big Foot is offline
post #6 of 17 Old 04-18-2011, 02:31 AM
scoyne88's Avatar
Try intelliremote. I use it and it lets u remap every botton to whatever you want.
Before you criticize someone, you should walk a mile in their shoes.That way, when you criticize them, you're a mile away and you have their shoes.
DIY Speaker Cables
http://www.seancoyne.org
scoyne88 is offline
post #7 of 17 Old 04-18-2011, 02:46 AM
joeydrunk's Avatar
Quoted: 14 Post(s)
Intelliremote and lmgestion are easier to program than eventghost but cost money.
joeydrunk is offline
post #8 of 17 Old 04-18-2011, 06:19 AM
bryansj's Avatar
Quoted: 1130 Post(s)
Liked: 560
You have to map the rest of those buttons in EventGhost as well.
bryansj is offline
post #9 of 17 Old 04-18-2011, 08:51 AM
mbbransc's Avatar
That's what I was going to suggest... remap all of your buttons. Requires some time, but in the end, it's set up exactly the way you want it. (create a backup).
mbbransc is offline
post #10 of 17 Old 04-18-2011, 09:21 AM
mslide's Avatar
I think this is the guide I used to remap those four buttons on the MCE remote...
http://www.hack7mc.com/2009/09/repro...lliremote.html
I didn't have to remap all my buttons. I just remapped the couple I needed.
mslide is offline
post #11 of 17 Old 04-18-2011, 11:24 AM - Thread Starter
Big Foot's Avatar
Thanks for the tips. lmgestion didn't seem to have a trial so I gave Intelliremote a whirl. I was able to get it working easily as the default Intelliremote profile changes the behavior of the green button to the Win key...so actually I didn't have to remap any buttons. I just don't like spending money on software like this, and then finding a problem down the road and I don't use it.
mbbransc, thanks for the heads up that I need to remap all buttons with EventGhost. I think I was also getting the "double press" behavior with the MCE Win7 plug-in that was included; I'm not sure if that is the right plug-in to use. I guess I will have to try it again.
Big Foot is offline
post #12 of 17 Old 04-18-2011, 11:49 AM
brianley's Avatar
You don't have to remap them all when using EventGhost - just make sure the Microsoft MCE Remote Plugin is enabled.
Once you get the hang of EventGhost, it becomes a very useful tool -particularly when controlling apps that have keyboard shortcuts.
brianley is offline
post #13 of 17 Old 04-18-2011, 12:08 PM - Thread Starter
Big Foot's Avatar
So, if I understand you correctly, the remote won't work properly without some remapping after I install EventGhost. Is this what I need to do?
- First, to get the remote working like it does without EventGhost, remap whatever buttons are no longer working as a result of the introduction of EventGhost.
- Second, do my customization (remap the green button to the Win key).
Big Foot is offline
post #14 of 17 Old 04-18-2011, 01:20 PM
brianley's Avatar
If you have the MCE remote plugin enabled, your system should respond pretty much the same way it did before you installed EventGhost. The nice thing is you can see what is being sent by each button press in the left side of the EventGhost window. Assuming things are working as before, its then just a matter of building alternate commands on the right by dragging / dropping the remote command into a new macro.
If you have a programmable remote like a Harmony, you can use EventGhost to remap unused commands to perform pretty much any action you can perform with a keyboard or mouse.
brianley is offline
post #15 of 17 Old 04-18-2011, 01:56 PM - Thread Starter
Big Foot's Avatar
Ok thanks. I see from one of your posts in another thread, that I shouldn't use the MCE Win7 plug-in that is included with EventGhost. Instead I should use this one:
http://www.eventghost.org/forum/view...php?f=2&t=1789
I'll give EventGhost another chance after I finish my taxes.
Big Foot is offline
post #16 of 17 Old 04-18-2011, 02:13 PM
bryansj's Avatar
Liked: 560
I think that the latest version of EventGhost includes the proper Vista/Win7 plug-in. I no longer have a MCE receiver so I can't test it.
bryansj is offline
post #17 of 17 Old 04-18-2011, 10:31 PM - Thread Starter
Big Foot's Avatar
I gave EventGhost another try. Seems to work so far, however it appears that I have joined the "most of the buttons don't work until they are mapped" group. Now that I know to expect that, I have no problem with it, and I can see the potential of the EventGhost platform.
Big Foot is offline
Reply Home Theater Computers
