AMD Llano - THE great HTPC chip? - Page 30 - AVS Forum | Home Theater Discussions And Reviews
post #871 of 880 Old 10-26-2012, 12:45 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
I tested it (and most of Llano APU SKUs) thoroughly. Even A4-3300 supports HA for BR 3D.
renethx is offline
post #872 of 880 Old 10-26-2012, 01:20 PM
e2zippo1's Avatar
This is weird, I just tried another movie, Titanic 3D and the intro just before the menu pops up was hardware accelerated, then it switched itself off again? eek.gif
edit: I got it pinned down, 2D Blu-Ray work just fine, Hardware Acceleration states "2.0" in TMT. But whenever i play something 3D it gets disabled, I used a demo disc to switch between 2D/3D
Also I'm running Windows 8 now, just to rule out the OS, and it behaves exactly like Windows 7.
What's up with this, why can't I get BR 3D to work with HW acceleration?!frown.gif
e2zippo1 is offline
post #873 of 880 Old 10-29-2012, 02:41 AM
e2zippo1's Avatar
Does anyone have any clue what do to?
I just can't get BD 3D to work with HW acceleration, I just reintalled Windows 7 again and it still doesn't work.
BD 2D work great, tried it with the latest TMT and latest catalyst drivers.
e2zippo1 is offline
post #874 of 880 Old 11-27-2012, 01:02 AM
e2zippo1's Avatar
After installing, re-installing, deleting, checking about everything and without success, I went into the AMD control panel and had a look through the video settings, and just to be absolutely sure I'd tried everything before returning the CPU I unchecked everything (De-interlacing, edge enhancement, de-blocking and so on, and the final piece that broke HW acceleration on MPEG4-AVC-3D.... Enforce smooth video playback
So now I'm all good, and damn you AMD for making that setting a default mad.gif
Cheers and thanks all your help!
e2zippo1 is offline
post #875 of 880 Old 11-27-2012, 03:40 PM
Andrew Hornfeck's Avatar
Quoted: 30 Post(s)
OK, so you needed the smooth playback enabled, right? That is how I run my system - having it unchecked (not doing smooth playback) leaves my 2D video rather ugly, jittery and poor quality.
Andrew Hornfeck is offline
post #876 of 880 Old 11-27-2012, 11:22 PM
e2zippo1's Avatar
No man, I have to have it disabled! tongue.gif Othwewise hardware acceleration isn't working.
I watched some 2D video yesterday as well with the setting off and it all looked good.
e2zippo1 is offline
post #877 of 880 Old 02-28-2013, 09:42 AM
IceWilly's Avatar
Quick question for you guys about this chip. I made an HTPC right at the beginning of its life....
System:
A4-3300 (6410D)
Asus F1A75-M Pro
8gb Kingston Hyper-X Blu PC3 12800
Crucial M4 64gb
2x WD Red 3TB Drives (raid0)
It plays 720p pretty well, but I'm not totally confident in its abilities to keep up with 1080p video. On wide shots like landscape panovers and things like that it just doesn't feel like it's running clean. Would I be benefited in this regard by picking up a new discrete GPU? It would have to be low profile and most likely passive cooled.
HIS 6670 isn't passive cooled, but 1gb and only $80
MSI 6570 same deal, ~$54
Would these even help, or is this probably down to a CPU issue? Honestly 720p is fine for me, but I want to understand where the bottleneck probably is for the future. Also, it is really nice right now that it's basically totally silent.
IceWilly is offline
post #878 of 880 Old 02-28-2013, 10:13 AM
Ruiner's Avatar
What media player? What is your cpu and gpu utilization during playback? Use gpu-z for the latter.
Ruiner is offline
post #879 of 880 Old 02-28-2013, 10:15 AM
IceWilly's Avatar
Usually XBMC. Can also test with VLC or MPC.
Will check out the utilization tonight. Didn't realize that would split the performance of both out.
IceWilly is offline
post #880 of 880 Old 02-28-2013, 08:51 PM
IceWilly's Avatar
Well, it seems that I did this so long ago that I didn't fully investigate the options back then. DXVA2 was disabled, and video render was set to auto (but DXVA was one of the options it could apparently choose)
Now I test on MPC HC with DXVA running at it seems better than i remember it being. CPU and GPU usage coast between like 40-70%, but at least I don't seem to be capping out. With the acceleration I apparently have enough power to play it back very smoothly.
Should XMBC work just as well with its DXVA2 enabled. Is there any reason with my setup that I wouldn't want DXVA2 on? It should only use it when the video file is capable correct?
IceWilly is offline
Reply Home Theater Computers
