AMD Llano - THE great HTPC chip? - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 880 Old 05-28-2011, 12:16 PM
jeffkro's Avatar
Originally Posted by vkristof View Post
This Chinese forum has alleged CPU-Z screenshots, @ 4 GHz, along with interesting translation, such as
"If it is true, ah, other assessments, the way the sofa ~"
Maybe something to ponder with a beer in the backyard, while admiring the flowers:
http://diybbs.zol.com.cn/10/11_99185.html
Huh, at 4ghz it should beat core i3.
jeffkro is offline
post #152 of 880 Old 05-28-2011, 02:24 PM
vkristof's Avatar
Originally Posted by renethx View Post
A quick look at Gigabyte's A75 motherboards by VR-Zone
GIGABYTE GA-A75M-UD2H AMD A75 chipset microATX mb is pictured. This is very different from those at the Greek site!
The Gigabyte GA-A75M-UDH on the Greek site is silkscreened Rev 1.0; the Vr-Zone one is Rev 0.1.
To me, the Rev 1.0 MB makes more sense for it's add-in card slot mix.
vkristof is offline
post #153 of 880 Old 05-28-2011, 07:32 PM
Aluminum's Avatar
Quoted: 22 Post(s)
Liked: 25
I am liking how much real estate the tiny hub frees up on board, compared to the 1155 itx boards it definitely looks like they have more room to work with.
The memory slot position on that asrock is new. Rectangular heatsink profile versus the square too. Usb 3.0 in the A75 saves another chip. Should be real interesting what all the different vendors do with layouts.
Can't wait to see boards from someone like asus or zotac, with a minicard slot of course.
PS: Does the Llano mean that AMD has ended their development of IGPs in the chip(set), i.e. is the 890GX the last and best IGP chip(set) AMD will make?
Yeah, I thought that was a given. IGP was always a low-mid range thing, its wasted transistors paired with discrete cards. (hybrd multi-gpu was always bleh) Bulldozer with only an IGP (AM3+) will be a platform for people that just need monitor outputs
Theres no doubt even the lowest llano (160SP) smokes a 890GX/4290 (40SP) sideport or not. I can't be bothered to check but if you can eliminate the cpu differences I bet the brazos gpu (80SP) wins too.
When I stopped caring about super quiet: E5 1680v2 @ 4.5Ghz, 980ti, i750 SSD - JS9500 & Dell P2715Q for dual 4k@60 because reasons
SAN shares over 56Gb infiniband, microcenter + fleabay = severe risks to my wallet
Aluminum is offline
post #154 of 880 Old 05-29-2011, 09:14 AM
vkristof's Avatar
Thx. I started buying AMD IGPs a few years ago and just continued. I did look more closely at the 890GX in the last couple of days. If you strip away the mktg labels, it looks like basically a slightly souped-up 780G. Of which I have at least two.
I was looking for something to replace this desktop I'm typing on, and a desktop Llano seemed to fit the bill, but then I discovered the FCH did not have RAID5.
Speaking of IGP paired w/ a discrete card being "wasted transistors paired with discrete cards. (hybrd multi-gpu was always bleh)", would I get improved playback by adding a HD6450 to a 880G/890GX? I need three monitors...
vkristof is offline
post #155 of 880 Old 05-29-2011, 10:35 AM
jeffkro's Avatar
Speaking of IGP paired w/ a discrte card being "wasted transistors paired with discrete cards. (hybrd multi-gpu was always bleh)", would I get improved playback by adding a HD6450 to a 880G/890GX? I need three monitors...
Llano should be able to do the SLI thing with a discrete radeon card so it isn't exactly wasted transistors. Still with a discrete card the transistors probably would be better spent on more cpu cores. Intel is the way to go if you want discrete graphics, at least until we see what bulldozer does.
jeffkro is offline
post #156 of 880 Old 05-29-2011, 10:56 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
I am definitely anxious for Llano to come out. My current Clarkdale core i5 Mini-ITX HTPC needs to be upgraded to support BluRay 3D. I could go with SB but honestly I don't feel like dealing with issues with the IGP (poor support with open sources players/decoders and the "24p" issue). Not in a huge rush since I still have my 3D BR Player hooked up to my TV for now, but hoping that Llano comes through
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #157 of 880 Old 05-29-2011, 11:24 AM
jeffkro's Avatar
It would be a lot cheaper to put a gt430, HD6450, or hd6570 in your core i5 system.
jeffkro is offline
post #158 of 880 Old 05-29-2011, 11:41 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Mini itx, too tight to just add a dGpu
Cheers,
Damian
post #159 of 880 Old 05-29-2011, 02:09 PM
vkristof's Avatar
Thx.
I don't want discrete graphics, but discrete + IGP is how I've been driving three monitors for a few years.
Speaking of three monitors, is there any way of knowing if LLano is limited to driving two monitors maximum via it's DisplayPort output(s)?
vkristof is offline
post #160 of 880 Old 05-29-2011, 02:29 PM
dj4monie's Avatar
Quoted: 37 Post(s)
Liked: 25
Yep Northbridge chipsets are a thing of the past making packaging easier and allowing more features on board, say built-in WiFi or Bluetooth, along with USB 3.0 support and more SATA ports...
A. Thomas
PSN - DJFourMoney
dj4monie is offline
post #161 of 880 Old 05-29-2011, 02:32 PM
dj4monie's Avatar
Quoted: 37 Post(s)
Liked: 25
Thx.
I would say the better APU's might drive triple monitors for basic computing, not gaming. After all you've been able to do triple monitors with cheap HD5450 and onboard IGP for awhile now.
A. Thomas
PSN - DJFourMoney
dj4monie is offline
post #162 of 880 Old 05-30-2011, 10:05 AM
vkristof's Avatar
Vr-Zone has photos taken at the Computex boot setup now ongoning.
MSI & ECS Llano MBs, both ATX and mATx.
ECS must really think legacy PCI has a market: one of their two mATX MB has TWO PCI slots.
http://vr-zone.com/articles/computex...-/12422-1.html
vkristof is offline
post #163 of 880 Old 05-30-2011, 10:13 AM
byronmhome's Avatar
I hope motherboards keep PCI slots.. Just for the sake of onboard PCI tv cards actually have hardware encoding while the PCIX ones use CPU
of course network media recorders skup around this entire problem, but keep 1 pci slot please
byronmhome is offline
post #164 of 880 Old 05-30-2011, 10:34 AM
jeffkro's Avatar
Ya, but legacy support takes up space on the mobo and adds to the cost and complexity. I stopped buying anything pci as soon as pcie was released so I don't have anything that uses pci anymore.
jeffkro is offline
post #165 of 880 Old 05-30-2011, 10:42 AM
vkristof's Avatar
Thx for that comment. One of the ECS mATX MB has a single PCI slot (I'd prefer another PCIe, but fine), the other has TWO. As I said, ECS mktg must be responding to some legacy PCI demand
I wound up looking at a dual TV tuner I had forgotten was in my few year old den HTPC today: it's PCIe.
In any case, there should be a number of ATX, mATX and mini-ITX MBs shown at Computex.
BUT, where are the leaked desktop Llano clock speeds? 4 GHz for that Chinese leak sounds nice, but is it real/turbo/whatever?
PS: PCI-X is another legacy Parallel bus PCI_SIG technology, but the slots look like old legacy PCI, but can be 64-bits wide.
vkristof is offline
post #166 of 880 Old 05-30-2011, 11:08 AM
vkristof's Avatar
Dunno how much it adds to a Llano MB. The PCI circuitry with a 3-slot bus arbiter is already on the Llano die. The extra cost might be the larger, higher pin count, (compared to PCIe x1 or PCIe x4) legacy PCI connector and the extra cost of, maybe, a 33 MHz oscillator.
IF you could eliminate legacy PCI you theoretically could also eliminate the legacy -12V in the power supply. AFAIK hat's only needed for legacy PCI.
But, PCI and the legacy infrastructure related to it will probably be around for a few more years based upon ECS deliberately including TWO legacy PCI slots in a new-for-2011 MB designed for a new-for-2011 CPU/APU.
vkristof is offline
post #167 of 880 Old 05-30-2011, 03:23 PM
vkristof's Avatar
At this stage its really of very little import, but Foxconn also has a Llano/A75 mATX mATX with two PCI slots:
http://vr-zone.com/articles/foxconn-...red/12440.html
vkristof is offline
post #168 of 880 Old 05-30-2011, 05:23 PM
byronmhome's Avatar
Yeah, i meant PCIe.. i just say pcix out of old habit
A lot of the cheaper PCIe capture boards are pretty "Dumb" and consume a crazy amount of CPU to encode shows.. I hope as we move to APU these cards will at least adapt to use some of the "Advanced" part of the processor to do HW assisted encodes so PCI can fade away.
I'm really excited to see what pricepoint AMD hits with CPU+MB combinations.. we'll see if they price for war, or price competitively. Would love to get a new CPU+MB for less than the cost of the Intel Sandybridge CPU like they did with the phenoms but not sure they will price that insane again
post #169 of 880 Old 05-30-2011, 05:36 PM
sneals2000's Avatar
Quoted: 242 Post(s)
Liked: 127
Most capture cards in serious use these days use the broadcasters' encoding don't they?
ATSC, QAM, DVB-S/S2, DVB-T/T2, DVB-C capture cards are surely the norm for broadcast TV capture these days - and none of these require the PC to do any encoding at all - they just pass the already-encoded MPEG2 transport stream (carrying MPEG2 or H264 encoded video and AC3, AAC or MP2 audio) to the PC.
Analogue SD capture solutions were available with both on-board MPEG2 encoding/compression in hardware (PVR-150 from Hauppauge was popular ISTR?), as well as with straight uncompressed video pass-through for the PC to compress in software (Brooktree based devices), though who captures analogue SD video these days?
The HD PVRs and Colossus solutions are analogue (and non-HDCP HDMI for Colossus) HD capture solutions that use onboard H264 encoding.
The Blackmagic Intensity stuff (and similar device) I guess is still capturing uncompressed, and uses CPU rather than on-board hardware for compression/encoding, but that's quite niche.
sneals2000 is offline
post #170 of 880 Old 05-30-2011, 06:30 PM
vkristof's Avatar
Computex is officially opening now in Taipei, the booths have Llano/A75 MBs, so maybe some prices will be mentioned.
vkristof is offline
post #171 of 880 Old 05-31-2011, 07:05 PM
vkristof's Avatar
"I'm hearing late summer for the desktop Llano launch at this point." - Anand today.
This sounds like another delay, if by late summer Anand means September
http://www.anandtech.com/show/4389/c...o-motherboards
vkristof is offline
post #172 of 880 Old 06-01-2011, 01:20 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
renethx is offline
post #173 of 880 Old 06-01-2011, 07:54 AM
jeffkro's Avatar
AMD just can't execute for some reason, sucks.
jeffkro is offline
post #174 of 880 Old 06-01-2011, 10:19 AM
micksh's Avatar
Digitimes says in July. http://digitimes.com/news/a20110529PD202.html
Not sure who is right, but AMD certainly needs to be more clear about their plans.
Also some new benchmarks. Core i3-2100 almost equals quad-core Llano in PCMark Vantage.
http://en.ocworkbench.com/tech/compu...andy-bridge/3/
micksh is offline
post #175 of 880 Old 06-01-2011, 10:50 AM
Zon2020's Avatar
And the i3-2100 is apparently cheaper than what the A8-3550 is going to be. AMD certainly better have substantially better graphics performance, because essentially equal CPU performance and higher heat/power for more money isn't going to cut it.
Zon2020 is offline
post #176 of 880 Old 06-01-2011, 11:02 AM - Thread Starter
ilovejedd's Avatar
Quoted: 76 Post(s)
Liked: 67
It does, although I'd certainly want to see how the i3-2105 compares.
3DMark Vantage: http://en.ocworkbench.com/tech/compu...andy-bridge/2/
Whether it's worth the sacrifice in CPU performance remains to be seen, though. For HTPC duties, really, the only problem with Sandy Bridge is proper 23.976 support. Otherwise, the graphics is sufficient for 1080p playback. The only reason to consider Llano is if you need 24p and/or plan to do some light gaming. Oh well, we'll probably see price cuts for desktop Llano a few months after release. At $170 for the A8-3550P, it's a bit too expensive to be competing with the likes of the i5-2300/2400.
ilovejedd is offline
post #177 of 880 Old 06-01-2011, 11:06 AM
whiteboy714's Avatar
But the point is that the cpu performance is plenty for what it is aimed at. So with the superior gpu performance at similar pricing to the i3 2100 this is a win for amd imo.
whiteboy714 is offline
post #178 of 880 Old 06-01-2011, 11:07 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Actually, aside from 23.976, the main reason I am looking at Llano vs Sandy Bridge is Intel doesn't play nice with the open source players/decoders, whereas AMD does
Cheers,
Damian
post #179 of 880 Old 06-01-2011, 11:15 AM - Thread Starter
ilovejedd's Avatar
Quoted: 76 Post(s)
Liked: 67
That's true. With SNB though, even if it doesn't play nice with freeware/open-source DXVA decoders, the CPU is more than up to the task if you use the software/brute force method.
No question, though, this is likely a major win for AMD in the mobile segment.
post #180 of 880 Old 06-01-2011, 11:18 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
I use MS Video Decoder for h264 and Arcsoft Video Decoder for VC-1 with my Clarkdale to get around this. However, system updates at times have killed this for whatever reason, which is another reason I rather go with AMD and be done with. Since my build is a Mini-ITX I would rather avoid pushing the CPU for video playback via brute force due to heat, etc...
Good thing I am not in a rush, but hopefully a few more months to wait for Llano
Cheers,
Damian
Reply Home Theater Computers
