Still no 23hz option under screen resolution AMD 6670HD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-08-2011, 01:29 PM - Thread Starter
BigZAJ's Avatar
I just installed a new AMD 6670 HD video card, I added 1080p24 to HDTV Support.
I can select 24Hz but not 23Hz, how can I add 23Hz as an optional display resolution in windows settings?
BigZAJ is offline
post #2 of 7 Old 05-08-2011, 02:22 PM
aequalszero's Avatar
If you right-click your Desktop > click 'screen resolution' > click 'advanced settings' > click the 'Monitor' tab > then check the 'screen refresh rate' drop-down box.
Is the option for 23Hz there? If not, it may be an indication that your TV can't accept a 24p input.
[Also: selecting 24Hz in ATI Catalyst Control Centre when you've added the 1080p24 mode has been known to set the actual refresh rate to 23Hz in the Windows setting above]
aequalszero is offline
post #3 of 7 Old 05-08-2011, 06:44 PM - Thread Starter
BigZAJ's Avatar
No 23Hz option when looking under advanced settings.
JVC projector, it accepts 24P, works fine when selecting 24Hz in advanced settings but there is a skip when watching 23.976 content.
BigZAJ is offline
post #4 of 7 Old 05-08-2011, 08:04 PM
jakmal's Avatar
I had the same trouble with a 6450. However, turning off both 'ITC Processing' and 'Enable GPU Scaling' brought the 23 Hz option back.
Ganesh T S
Sr. Editor, AnandTech Inc.
jakmal is offline
post #5 of 7 Old 05-08-2011, 08:47 PM - Thread Starter
BigZAJ's Avatar
thanks, i'll try that!
BigZAJ is offline
post #6 of 7 Old 10-23-2012, 07:09 AM
ser_renely's Avatar
I had this problem as well.
I had to turn off "Enable GPU Scaling" but what is that really doing and why does it allow me to get the 23.976?
B&W cm5
Pioneer Elite SC-27
Panasonic 50" GT50
HTPC - i5, ATI 7790
Crappy Klipsch sub
ser_renely is offline
post #7 of 7 Old 10-23-2012, 08:59 AM
tootal2's Avatar
Quoted: 33 Post(s)
games play very choppy at 24hz.
tootal2 is offline
Reply Home Theater Computers
