Configure 7MC to start correct version of PowerDVD 9 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-17-2011, 02:24 PM - Thread Starter
Postmoderndesign's Avatar
Quoted: 216 Post(s)
Liked: 85
I cannot figure out how to view and modify which version of PowerDVD 9 7MC is starting. Can anyone tell me where 7MC displays the PowerDVD start up link.
I installed the current patch and ended up with my old version in its own directory and the new version in the Program Files directory. I can run the new version by going into Progam Files-Cyberlink-PowerDVD 9- application. But I cannot get PowerDVD 9 to run from 7MC.
I have an atypical installation done as a Cyberlink work aroud to a previous problem.
Anál nathrach, orth’ bháis’s bethad, do chél dénmha
Postmoderndesign is offline
post #2 of 6 Old 05-17-2011, 02:49 PM
CountryBumkin's Avatar
Quoted: 214 Post(s)
Liked: 54
Can you right click on a movie/video file and then use the "open with" command and point it to the PWDVD9 exe file?
CountryBumkin is offline
post #3 of 6 Old 05-17-2011, 02:58 PM - Thread Starter
Quoted: 216 Post(s)
Liked: 85
The problem is that I cannot start a Blu-ray while running PowerDVD under 7MC. I get a message that the disk is not supported.
post #4 of 6 Old 05-17-2011, 03:01 PM
Quoted: 214 Post(s)
Liked: 54
If you go to 7MC "Extras", do you have an icon for PWDVD9?
post #5 of 6 Old 05-17-2011, 03:53 PM - Thread Starter
Quoted: 216 Post(s)
Liked: 85
Yes...but I do not see a way to view and modify how the icon starts the application...the link
post #6 of 6 Old 05-18-2011, 11:09 AM - Thread Starter
Quoted: 216 Post(s)
Liked: 85
This problem is corrected. I moved the PowerDVDUltra directory to the recycle bin leaving only the version in the Program files directory. That may have fixed the problem or some other things I attempted along the way may have corrected the problem.
Anyway, I doubt it is a problem many other will encounter.
Reply Home Theater Computers
