Wesena cases for i3 HTPC? Anyone? - AVS Forum | Home Theater Discussions And Reviews
Old 05-19-2011, 05:11 AM - Thread Starter
asmitee20's Avatar
Hi,
Does anybody have any experience with the Wesena Cases? I'm looking to build a i3 HTPC. I was thinking HDD, 4GB RAM, and an internal Bluray. Maybe a SSD for the OS if you guys think its worth it.
Should I go 2100t or 2100?
I would like to:
1. Watch 1080p.
2. Play Bluray discs on an internal drive.
3. Use as DVR with either ceton infinitv4 or HDhomerun prime when it comes out.
4. Streaming online 1080p from the interweb.
5. No gaming.
The case should be as small and pretty as possible to overcome the "wife barrier". So I figured the Wesena is perfect, but i couldn't find any reviews for it. Which is the smallest Wesena case that will fit my build.
I read somewhere that the cases have a problem with the Bluray drive eject button, it being on the wrong side or something. Is this a rumor?
asmitee20 is offline
Old 05-19-2011, 06:19 AM
CountryBumkin's Avatar
Quoted: 214 Post(s)
Liked: 54
If you plan to use the smallest case possible go with the i3-2100T it has a smaller fan profile.
Also check out Assaissin's HTPC building guide (in the stickys) he has picturers of several cases.
CountryBumkin is offline
Old 05-19-2011, 06:39 AM - Thread Starter
asmitee20's Avatar
Thanks, I looked at it thoroughly, but couldn't find references to the Wesena cases. I know the 2100t is shorter but does the 2100 stock fan also fit?
Old 05-19-2011, 06:53 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Zygmund (the owner of the Wesena dealer in US) answered:
Maximum height for motherboard with CPU and cooling system is 1.75" (45mm) in ITX2 chassis.
So the stock cooler of 2100T (~30mm tall) fits fine, but that of 2100 (~45mm tall) won't fit.
renethx is offline
Old 05-19-2011, 08:26 AM
babgvant's Avatar
Liked: 30
Originally Posted by asmitee20 View Post
Hi,
I would like to:
1. Watch 1080p.
5. No gaming.
Which case are you look at? I reviewed the ITX7 a while back.
I had a problem with the eject button, but that was only because the drive I used didn't have one
That said, not all slim line drives have the eject button on the same side. so if you care (I just eject the discs using explorer) make sure that the drive you get lines up with the case.
babgvant is offline
Old 05-19-2011, 08:37 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Buy Sony BS-5600S from the same store. $160 for this discontinued model is terrible, though.
All newer slot-load drives have a button in the middle (as seen ASRock Vision 3D).
renethx is offline
Old 05-19-2011, 08:47 AM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
I'll add a link to your review on the front page of the "Unofficial mini-ITX case" thread.
StardogChampion is offline
Old 05-19-2011, 08:54 AM
babgvant's Avatar
Liked: 30
E-bay is probably the best place to find one for a decent price.
babgvant is offline
Old 05-19-2011, 08:58 AM - Thread Starter
asmitee20's Avatar
I saw the 5600s on ebay for around 60$.
babgvant, I saw in your review that a 3.5 HDD couldn't fit in with the 2100t low profile HSF? Am i correct?
This means that if i intend on using the 2100t i can either use a 2.5 or remove the HSF. This will add about 150$ for a 1TB HDD, or 50$ for a 500GB one.
hard choice
Old 05-19-2011, 09:07 AM
babgvant's Avatar
Liked: 30
hard choice
I was using a regular HSF, a LP HSF might not have that issue.
babgvant is offline
Old 01-23-2012, 12:47 PM
jmpa's Avatar
Hi,
I really like this case - wesena E5. Where can I buy it here in europe - Portugal? What are the feedback about it? Is good?
jmpa is offline
Old 01-23-2012, 12:59 PM
assassin's Avatar
Quoted: 79 Post(s)
Liked: 242
Originally Posted by jmpa View Post
Hi,
I haven't used a e5 but I have used the e7. In fact I have an empty one in the garage that I might use later. Wesena build quality is excellent. Aluminum, rounded corners, etc. A bit pricey for a typical build but if you want to spend a little extra they look nice and are solidly built.
No idea where to buy one in Europe though.
assassin is offline
