Does anyone use the riser slot in a Silverstone ML03 case? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-19-2011, 02:10 PM - Thread Starter
Zon2020's Avatar
I would prefer to use a Silverstone ML03 rather than a GD04, but I want to include a Hauppage Colossus which requires a full-height slot. Could I put the Colossus in the horizontal riser slot over the motherboard? Would it fit? Would there still be room for a CPU fan?
Does anyone use that riser slot for anything?
Silverstone's manuals are usually pretty good in describing dimensions, but there is essentially no discussion of what they call the "utility" slot.
Thanks very much.
Zon2020 is offline
post #2 of 3 Old 12-07-2012, 06:34 AM
jayabee's Avatar
Hi Zon2020, did you ever resolve this issue? I'm also thinking of using the Hauppauge Colossus in the utility slot of a ML03 but I'm not sure if it will fit.
jayabee is offline
post #3 of 3 Old 12-07-2012, 06:57 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2695
Zon is not around as much these days
Try pm him
Mfusick is offline
Reply Home Theater Computers
