Latest Ceton InfiniTV 4 Info Thread - Page 160 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #4771 of 4978 Old 05-31-2014, 12:38 PM
rc05's Avatar
Quoted: 111 Post(s)
Liked: 73
Originally Posted by mo0sic View Post
There is a new beta firmware that came up while I was in the ceton windows app. Has anyone tried it yet?
See this topic: http://www.thegreenbutton.tv/forums/viewtopic.php?f=68&t=7281
Seems to be good for the most part
rc05 is online now
post #4772 of 4978 Old 06-06-2014, 10:20 AM
gtgray's Avatar
Quoted: 77 Post(s)
Liked: 74
Latest Beta, so far, so good.
Mits WD-92840 92" DLP - Lumagen Radiance XS, Martin Logan Motion 40s, Ascend Sierra 2s
Older 58" Panny Plasma -DVDO DUO, JBL Studio 530
Pioneer AJs, PSB Images, Usher S520, JBL HLS-610, Definitive SM45, MusicHall Marimba
gtgray is offline
post #4773 of 4978 Old 06-07-2014, 06:53 AM
Toys7505's Avatar
Quoted: 65 Post(s)
Liked: 25
Anyone know what the list of changes might be? Curious if they fixed the issue where you have Windows setup as 5.1/7.1 audio out and WMC setup as 5.1/7.1 audio out, you would have to have the sounds turned off for navigation in WMC or it wouldn't work right. But if you choose Windows to be 2.0 audio out and setup WMC as 5.1/7.1, you could have the WMC navigation sounds turned on without any issues.
Toys
Denon AVR-3311CI, Denon DVP-602CI, B&K Reference 200.7 S2, Belkin PF60
Sony BDP-S5000ES, Silverstone HTPC (6 Tuner DVR & 10 TB Media)
PSB Stratus Minis, PSB Stratus C6, PSB Alpha S surround, James Subwoofer EMB-1200
Sharp LC-70LE755U, Harmony 880 Remote
Toys7505 is offline
post #4774 of 4978 Old 06-07-2014, 07:58 AM
rc05's Avatar
Quoted: 111 Post(s)
Liked: 73
Toys
That's a WMC issue shared with all tuners, not specific to the infinitv. I really wouldn't expect WMC to ever get fixed frown.gif
rc05 is online now
post #4775 of 4978 Old 06-07-2014, 05:35 PM
Toys7505's Avatar
Quoted: 65 Post(s)
Liked: 25
BUMMER!! Thought that was related to just Ceton........
Toys
Toys7505 is offline
post #4776 of 4978 Old 06-09-2014, 01:55 PM
gtgray's Avatar
Quoted: 77 Post(s)
Liked: 74
yeah and the even weirder thing about is that some WMC installations work just fine with the control panel set to 5.1 speakers and WMC also set to 5.1 with navigation sounds on. In my bedroom that WMC just works fine that way. Go figure if it works, consider yourself lucky. I don't really care about the navigation sounds.
gtgray is offline
post #4777 of 4978 Old 07-26-2014, 06:08 PM
Ken.F's Avatar
Quoted: 999 Post(s)
Liked: 841
Anybody know how I can access the tuner status webpage of my InfiniTV4 PCIe card that's installed in a different computer on my home network?
Ken.F is offline
post #4778 of 4978 Old 07-26-2014, 07:31 PM
robnitro's Avatar
Hey Eric,
FIOS is being annoying. Discovery HD channel, Mythbusters show is showing up with wrong interlacing. I think they aren't flagging TFF or BFF correctly, sometimes after commercial its good, sometimes its bad. Other channels are fine but I haven't checked all.
Ken. F, not sure. I tried to forward the port, but it doesn't seem to work for me!
My setting:
C:\Windows\system32>netsh interface portproxy add v4tov4 listenport=88 listenaddress=192.168.1.51 connectport=80 connectaddress=192.168.200.1
Didn't work!
http://stackoverflow.com/questions/1...ing-in-windows
robnitro is offline
post #4779 of 4978 Old 07-27-2014, 08:21 AM
Paw Paw's Avatar
Open the ceton diagnostic on the computer that has the card installed. Click on the device tab and then click on the "Go to InifiniTV Device" button. Write down the address of the web page ie: http://192.168.....
You can use this address on any computer on your network to get to the web page.
Paw Paw is offline
post #4780 of 4978 Old 07-27-2014, 08:26 AM
Ken.F's Avatar
Quoted: 999 Post(s)
Liked: 841
Thanks but I already tried that.
"The connection has timed out
The server at 192.168.200.1 is taking too long to respond."
Ken.F is offline
post #4781 of 4978 Old 07-27-2014, 08:33 AM
ThurstonX's Avatar
I tried that, too, and it does not load the page.
ThurstonX is offline
post #4782 of 4978 Old 07-27-2014, 02:31 PM
AVS Club Gold
DSperber's Avatar
Quoted: 171 Post(s)
Liked: 149
Is everything on the same side of your one-and-only router?
Or do you have multiple routers in your setup?
DSperber is offline
post #4783 of 4978 Old 07-27-2014, 02:49 PM
Ken.F's Avatar
Quoted: 999 Post(s)
Liked: 841
One router.
Ken.F is offline
post #4784 of 4978 Old 07-28-2014, 11:02 AM
robnitro's Avatar
Fixed it! (freaking windows firewall was blocking the port!!)
Do this on windows 7 to forward the port successfully!
ON THE HTPC HOSTING THE CETON:
Go to start, type in firewall, choose windows firewall with advanced security:
Click INBOUND RULES,
Click NEW RULE on the right side.
Choose PORT, TCP, Specific - 88 (or whatever port you want)
Next -- ALLOW, next, choose private and domain only. NEXT.
Rule added.
{Change your NIC IP, to what the HTPC has. Change the 200.1 to whatever your ceton page is. Change the listenport to whatever port you want to use}
Start menu, type in CMD, right click what you see there, choose run as administrator.
Now you can connect by going to another PC, go to the browser and type in
http://192.168.1.51:88
Of course use your own IP, this is my personal settings.
Paw Paw, it might work for you because you are bridging the ceton adapter with the NIC, or are using the ethernet ceton6.
The main problem is this:
On our HTPC, we have ceton nic with address 192.168.200.2, and the ceton itself is .1 (mask 255.255.255.0)
That network is 192.168.200.1-192.168.200.253
The NIC is, in my case, 192.168.1.51, router 192.168.1.1 (mask 255.255.255.0).
You can't just type 192.168.200.1 from outside the HTPC and assume that it will work. My PC for example, is 192.168.1.101. It assumes that 200.1 is some other network outside the router, because it is not in the same subnet mask which is 192.168.1.x aka 192.168.1.1 up to 192.168.1.253.
robnitro is offline
post #4785 of 4978 Old 07-28-2014, 12:15 PM
dbailey75's Avatar
Quoted: 61 Post(s)
Liked: 47
You might want to reboot the PC. You should be able to access the card's web page from any PC on your network by manually entering the tuners IP, or in Win 7 going to windows explorer and then network, should show up there, right click, and select device page.
PSN: CAPTDANMAN
dbailey75 is offline
post #4786 of 4978 Old 07-28-2014, 01:17 PM
ThurstonX's Avatar
Rule added.
Trying to make this work, but either I'm doing something wrong, or it's just not working. My details are:
HTPC: 192.168.1.66
Ceton: 192.168.200.1
Laptop: 192.168.1.11
Firewall Inbound rule added on laptop (double-checked).
Ran this command on laptop:
netsh interface portproxy add v4tov4 listenport=88 listenaddress=192.168.1.66 connectport=80 connectaddress=192.168.200.1
From laptop trying to connect to 192.168.1.66:88 but it times out. When you say "Change your NIC IP, to what the HTPC has." I assume that means in the netsh cmd, yes?
I wasn't sure if I had IPv6 installed, so I ran "Microsoft Fix it 50440" from here:
http://support.microsoft.com/?scid=k...9852&x=11&y=13
and rebooted.
TIA.
post #4787 of 4978 Old 07-28-2014, 02:29 PM
robnitro's Avatar
No, you run that port forward and the firewall stuff on the HTPC that hosts the ceton.
Edited the post to clear up confusion.
robnitro is offline
post #4788 of 4978 Old 07-28-2014, 05:41 PM
ThurstonX's Avatar
D'oh! Makes sense now that I think about it. Thanks for clarifying. Works like a charm
post #4789 of 4978 Old 07-28-2014, 06:09 PM
Ken.F's Avatar
Quoted: 999 Post(s)
Liked: 841
Rule added.
Thanks. I'll give that a try this weekend.
Ken.F is offline
post #4790 of 4978 Old 07-29-2014, 01:33 AM
layziethug's Avatar
Rule added.
Thank you. Work perfectly.
layziethug is online now
post #4791 of 4978 Old 08-14-2014, 11:11 AM
Ken.F's Avatar
Quoted: 999 Post(s)
Liked: 841
I finally got around to messing with the Ceton tuner in the HTPC this morning. I ran the network tuner setup and left all 4 tuners assigned to the HTPC. I had to run the WMC tuner setup again since my channel lineup got cleared out. I can now access the tuner status webpage from my desktop PC. I noticed the IP address of the tuner changed from 192.168.200.1 to 192.168.1.17. I also noticed that I cannot connect to the HTPC from the desktop PC with Remote Desktop now. One step forward, two steps back.
Ken.F is offline
post #4792 of 4978 Old 08-15-2014, 07:16 AM
Ken.F's Avatar
Quoted: 999 Post(s)
Liked: 841
Update:
I fixed my Remote Desktop problem - sort of. When the network bridge was created, the bridge got it's own IP address. I need to tell Remote Desktop to connect to the IP address of the network bridge instead of the computer name in order to connect. What I don't know how to do is associate the IP address of the network bridge with the computer name.
Ken.F is offline
post #4793 of 4978 Old 08-15-2014, 10:50 AM
Ken.F's Avatar
Quoted: 999 Post(s)
Liked: 841
Update 2:
Finally fixed. I had a static IP assigned to my HTPC in my router. When the network bridge was created it got a new IP address. The router couldn't change the HTPC IP address because I had it set to static. I deleted the static IP address configuration in the router and rebooted the HTPC. The router then correctly assigned the new network bridge IP address to the HTPC computer name. I then changed the type back to static in the router. I can now connect with Remote Desktop by computer name again.
Ken.F is offline
post #4794 of 4978 Old 08-18-2014, 07:55 PM
robnitro's Avatar
I started to use network tuner sharing with my inifniTV4 pcie.
It works well, but sometimes there is an issue.
I have a tuner that I assigned to a laptop.
It's tuned to a channel, let's say discovery channel.
Works fine, but sometimes you lose connection- ethernet cable falls out, oops.
Now, you plug it back in, and it says "tuner not found blabla conflict". As if the tuner is locked.
Re did the sharing on the laptop and the wmc setup.
Still same message.
I rebooted the PC with the ITV pcie installed, worked fine.
Next time it happened, I took a look at the webpage. For tuner 4, which the laptop uses, it was showing that the streaming rtp was started. I stopped it, and then changed channels on the laptop... and it worked!
So the issue is, when the laptop loses the RTP connection, how long does it take to time out and reconnect?
Because in that "play state" if ethernet (or wireless) connection is lost the WMC client (in my case-laptop) cannot seem to re access the tuner!!!
Any way to disable the rtp and just use normal how it was from a while back? If that was the case, that is.
robnitro is offline
post #4795 of 4978 Old 08-19-2014, 12:20 AM
AVS Club Gold
DSperber's Avatar
Quoted: 171 Post(s)
Liked: 149
I can't guarantee that this will address your problem, or that it will actually work to solve your problem when it occurs, but it might.
I had a problem with the Ceton tuners not being returned correctly for normal use following my use of a VPN connection to a remote mainframe from the HTPC. For security, most VPN software products almost always locks out general TCPIP (and always seems to prevent any secure access to the Internet, e.g. for email, etc.). For sure, the two VPN products used in my case have that effect.
Since the Ceton tuners (even from the internal PCIe card) are accessed using IP addresses, when VPN is active the Ceton tuners are inaccessible. But when the VPN connections are closed the Ceton tuners should once again be visible and usable. Except they are not. Other Internet-related software works perfectly again following the termination of VPN, but the Ceton drivers for some reason do not see the tuners. That meant scheduled recordings would encounter "no available tuners" and would get flushed.
Prior to communicating about this with Ceton my only solution at this point was to re-boot the HTPC, which as you can imagine was annoying and inconvenient. I had to remember to re-boot right after terminating my VPN work, so that any scheduled recordings would succeed.
After working with Ceton on several possible solutions, they eventually provided me with what I packaged into two BAT-file commands which I executed sequentially in a command-prompt window. VPN1.BAT kills EHRECVR.EXE (i.e. Windows Media Center task), and I wait about 15-30 seconds for things to "settle down". Then I run VPN2.BAT, which reinitiates the WMC task and also re-discovers all of the Ceton tuners... which are now operating normally again!
This combination of VPN1 and VPN2 thus allows me to avoid having to re-boot following any VPN work, and gets all four tuners operating visibly and properly. Scheduled recordings now proceed without any problem.
So... you might try these two commands yourself, on any machine where your tuners are not behaving correctly or are "dangling" in some inoperative state. There's certainly no harm in running these two commands as I describe (assuming you have a minute or two with nothing else scheduled to be using WMC), and it might very well be a solution to your problem.
Give it a try, and report back whether it was useful... or harmful... or accomplished nothing.
File Type: zip Kill_ehrecvr.zip (381 Bytes, 23 views)
DSperber is offline
post #4796 of 4978 Old 09-05-2014, 08:08 AM
Quoted: 12 Post(s)
Liked: 1
Apologies in advance for cross-posting, but I wanted to get a summary of my issue into a thread that Ceton monitors.
I can generally tune SD channels with very few issues, but HD channels suffer buffering / image freeze / pixelation; this varies from the ocassional glitch-in-the-matrix to completely unwatchable.
The local Cox tech came by yesterday (truck roll #3 ) and took readings from the RG-6 connection at the cable card and said they were very good.
Here are the key readings from when a local HD channel locked up:
Carrier Lock: Locked
PCR Lock: Locked
SNR: 36.8dB
Signal Level: -7.4dBmV
Temp: 54.5C
The support tech then suggested the problem is my AMD APU chip and on-motherboard HDMI aren't strong/fast enough to handle the HD channels coming in to my card, nevermind that it plays ripped BluRay MKV files just fine -- do I really need to add a graphics card? My config info below, and I adjusted BIOS to maximum video processing settings.
Here is my build summary:
Win7-64
ASUS F2A85-M PRO A85 FM2
AMD A6-5400K APU 3.6Ghz
8GM Memory
Disk0 - C:\ (System) 50GB, F:\ (Music) 100GB
Disk1 - D:\ (Movies) 500GB
Disk2 - E:\ (Movies, Recorded TV) 1TB (Western Digital Black WD1003FZEX - 1 TB SATA III 7200 RPM 64 MB Cache)
My connections:
Cable: wall > TA > Ceton
A/V: HTP <HDMI> Sony XBR <Toslink> Sony AVR
I have been fighting this for over a month now and so far as Cox is concerned, this is strictly an issue with my HTPC which I translate to a problem with the Ceton InifiniTV4 PCIe card (unless a technically-astute sees an issue with my build or has some cool performance checks/tweaks).
I have a support ticket open and will send a fresh log capture this evening, but this issue is rendering my HTPC useless for live TV.
dshorrosh is offline
post #4797 of 4978 Old 09-05-2014, 08:09 AM
Quoted: 12 Post(s)
Liked: 1
PCR Lock: Locked
SNR: 36.8dB
Temp: 54.5C
Win7-64
8GM Memory
My connections:
Cable: wall > TA > Ceton (plus separate USB link)
I have been fighting this for over a month now and so far as Cox is concerned, this is strictly an issue with my HTPC which I translate to a problem with the Ceton InifiniTV4 PCIe card (unless a technically-astute reader sees an issue with my build or has some cool performance checks/tweaks).
post #4798 of 4978 Old 09-05-2014, 09:04 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 686 Post(s)
Liked: 525
PCR Lock: Locked
SNR: 36.8dB
Temp: 54.5C
A signal level of -7.4dBmV is on the low side. Keep in mind that the input on the InfiniTV 4 is essentially a 4 way splitter, so you're going to lose some signal strength by the time the signal reaches the individual tuners. I would suggest installing a signal amp before the TA. Just don't go with anything overly strong, 6dB or so of boost should get you where you want to be (0dBmV being the ideal).
gsr is online now
post #4799 of 4978 Old 09-05-2014, 09:43 AM
ThurstonX's Avatar
PCR Lock: Locked
SNR: 36.8dB
Temp: 54.5C
Win7-64
8GM Memory
My connections:
I had a similar problem with HD movies (live or playback), primarily from the premium channels. The picture would start to pixelate a bit, and them WMC would crash, and generally restart itself and resume playback. My signal levels on some frequencies were even worse than yours, and a couple Comcast techs verified that the signals they could measure were well within their specs.
As gsr suggests, I got a $25 signal booster, installed it after the splitter that feeds the cable modem (very important) and fed it straight into the Ceton. That helped the signal levels and pixelation in general, but the movies kept crashing. So I decided it was the Saphhire Radeon Ultimate 5670 card. I was building a new PC and had a Sapphire Radeon Ultimate R7 250 (both passively cooled), so I installed it in the problematic HTPC. Bingo. Ordered a second card and haven't had a problem since. I was a little surprised that the 5670 couldn't handle them, as I used it for video file playback, but there ya go.
The only other thing I'd be slightly concerned about are the tuner temps. If the Ceton is in a smallish case without many (any) fans, then that's probably a good temp. I'm pretty sure it's within Ceton's specs. If you wanted to get them down a bit, you could try those small copper heat sinks available from Newegg or wherever.
Anyway, hope that helps, and that you can solve your problem.
post #4800 of 4978 Old 09-06-2014, 05:37 PM
Quoted: 12 Post(s)
Liked: 1
Update -- a previous Cox tech swapped my Radio Shack amp for one off his truck, so I pulled the line feeding the HTPC off that amp and ran it thu mine and BINGO!
Live TV was great with nary a pixelation or freeze, with readings of SNR @ 35.4dB and Signal Level @ 3.0dBmV.
I installed the HDMI Detective and slide everything back in the cabinet, taking care not to put strain on the COAX pigtail.
Well, once I pushed everything back into the cabinet, my old nemesis pixelation/freeze/buffer came back along with the blue-screen 'weak signal' message with SNR @ 35.4dB and Signal Level @ 3.0dBmV (but only on HD channels -- SD channels are relatively fine).
This is driving me nuts.
Reply Home Theater Computers
