Latest Ceton InfiniTV 4 Info Thread - Page 164 - AVS | Home Theater Discussions And Reviews
 5Likes
post #4891 of 4909 Old 03-11-2015, 07:43 AM
mdavej's Avatar
Quoted: 1041 Post(s)
Liked: 578
Originally Posted by mbmcallister33 View Post
That is actually what I was afraid of. In front of my mind, I'm happy with parts I picked out to order. BUT! In back of my mind, I'm a little concerned on how warm it may get that could either to breakdown or overheat shut down. That's what I been figuring out what's the best cableCARD tuner. PCIe? or Network tuner? I'm starting to think Network tuner is more FEASIBLE since I can stash it away and build 2 HTPC to receive it. As far performance wise, Doing this so may have to lead me to get new router (Can't remeber what I have right now at this moment will provide later) I'm planning to get me new router cable to Transfer Data up to 300mbps. Mine only does 150 at this moment. Just enough to get me web browser on tablet.) Speaking of thus, May I ask you guys what router do you have?
You definitely need to beef up your routers/switches when you use network tuners. Any gigabit devices will work fine. My router is a $20 Trendnet I got on sale. Handles 6 recording streams and 6 extender streams simultaneously without breaking a sweat. Some spend hundreds on routers, but it's not necessary for normal HTPC purposes.
The 300/150 Mbps number you're thinking of now is for wifi, I believe. So that's not relevant. It's the hard-wired port speeds that are relevant. That needs to be 1Gbps, not just 100Mpbs or 10Mbps. If your wifi is 150, then you probably have 1Gbps port speeds already and have nothing to worry about.
mdavej is offline
post #4892 of 4909 Old 03-11-2015, 08:09 AM
Liked: 0
Actually, that part I understand that network tuner will be hardwired. I'm referring to HTPC that would be on wifi. I read somewhere last year that wifi actually matters of what speed it can transfer. I seen those wifi adapter that can do 150mbps while router can output 300mbps and read that it makes a difference. That having a 300mbps adapter and router for wifi speed would help strengthen streaming process. Could they be wrong?
mbmcallister33 is offline
post #4893 of 4909 Old 03-11-2015, 08:14 AM
mdavej's Avatar
Liked: 578
Putting your PC on wifi is a terrible idea. Pull a cable or use powerline, Moca or Deca. A couple of streams will completely saturate wifi and won't be reliable. Some people have made it work, but not many.
EDIT: I see the warnings are starting to roll in. We speak from experience. Listen to us.
mdavej is offline
post #4894 of 4909 Old 03-11-2015, 08:15 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 343 Post(s)
Liked: 294
It's not a good idea to rely on using WiFi for network tuners. If at all possible, get the HTPC hard wired to your router or use something like a power line network adapter.
gsr is online now
post #4895 of 4909 Old 03-11-2015, 08:26 AM
Liked: 0
Power line network adapter? That device continues to cause me to doubt it. Do I take it that you have tried it before or have it?
post #4896 of 4909 Old 03-11-2015, 08:53 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 343 Post(s)
Liked: 294
No, I've never used one as I went to the trouble of running CAT6 cables to all rooms in the house that need them (in some cases multiple cables to a single room), but they're generally considered better than using WiFi as are Moca and Deca.
gsr is online now
post #4897 of 4909 Old 03-11-2015, 08:55 AM
mdavej's Avatar
Liked: 578
Power line is not ideal but still far better than wifi. Hardwired is best of course, followed by Moca/Deca, power line, then wifi a distant last. I have used power line in the past. Mine required monthly reboots, but the speed was good. My Deca, on the other hand, is 100% reliable. Wifi was totally useless. Wifi is fine for Netflix but can't usually handle TV unless the stars align.
mdavej is offline
post #4898 of 4909 Old 03-11-2015, 10:05 AM
ajhieb's Avatar
Quoted: 607 Post(s)
Liked: 501
Wifi might work.
Moca/Deca/Powerline should work
Cat5e/6 will work.
Wifi and video is a crapshoot.
RAID protection is only for failed drives. That's it. It's no replacement for a proper backup.
ajhieb is online now
post #4899 of 4909 Old 03-11-2015, 02:05 PM
AVS Club Gold
DSperber's Avatar
Quoted: 118 Post(s)
Liked: 129
Originally Posted by ajhieb View Post
Cat5/6 will work.
Personally, I don't think CAT5 is acceptable. Too slow, and with so many network tuners independently sending HD streams TO the router, and then FROM the router TO the HTPC, not to mention the other slew of HD streams from the HTPC TO the router and then FROM the router TO extenders/HDTVs around your house... well you get my point.
Honestly, if you want a reliable glitch-free problem-free setup and you're going to have at least six network-based tuners for recordings, while you're going to be independently watching previously made recordings on 2-5 HDTVs around your house... you've got to build a CAT6 gigabit-router network.
Ethernet-over-powerline approaches are commonly limited to 100Mbps, as are ethernet-over-coax. These are the usual substitutes for true ethernet cable home networks where you can't or haven't run ethernet cable through walls or ceilings, and perhaps have an old RF 75ohm coax from the old cable days that gets to the target room and has another end near your router. Ethernet-over-coax is also limited to 100Mbps streams, though there may be multiple of them.
And of course powerlines run through walls throughout your house, but probably also go through circuit breaker boxes (unless you're lucky and find a direct-copper link from one room to another in the same part of the house) and may or may not be grounded properly, etc. So these may or may not work well, depending on distance from a power socket near the router to the target room. But you're still talking 100Mbps, which again is impractical to support a 6-tuner network box from any vendor for an HTPC setup.
Word to the wise: home CAT6 wiring is something you should most seriously consider if you want to build out your own whole-home HTPC-based setup. You can get by with CAT5/CAT5e to the extender/HDTV nodes, but from HTPC to/from router and network-based tuners to/from router, in my opinion you want CAT6.
DSperber is offline
post #4900 of 4909 Old 03-11-2015, 02:19 PM
Ken.F's Avatar
Quoted: 405 Post(s)
Liked: 411
Cat5e works fine. I have two HTPCs, two HDHRs and three extenders all wired with Cat5e and have no network problems.
Last edited by Ken.F; 03-11-2015 at 02:34 PM. Reason: ajhieb made me feel guilty for implying that I used Cat5e when I actually wrote Cat5
Ken.F is offline
post #4901 of 4909 Old 03-11-2015, 02:28 PM
ajhieb's Avatar
Quoted: 607 Post(s)
Liked: 501
Edited for clarity above. (not that it's particularly important though as I think it's difficult to find straight cat5 (not cat5e) these days)
Ken.F likes this.
post #4902 of 4909 Old 03-11-2015, 02:35 PM
mdavej's Avatar
Liked: 578
You'll probably get gigabit speeds on plain old cat5, especially if your runs aren't too terribly long. You'll definitely get gigabit on cat6 (up to 10Gbps if you have a high dollar router).
I have fairly short runs ( < 50') and consistently get 1Gbps on my old cat5. I get 150Mpbs or so on my Moca network, which is fine for a couple of streams at a time. Any more that that, I'll have problems.
Sounds like the OP doesn't plan on many clients at the moment. Best course of action is try cat5 and see how it goes before you start pulling new cables everywhere.
mdavej is offline
post #4903 of 4909 Old 03-11-2015, 02:40 PM
Ken.F's Avatar
Quoted: 405 Post(s)
Liked: 411
If you don't have any cables in place it's not a bad idea to get Cat6 from the start. I don't plan on replacing my existing network cables but since my bulk box of Cat5e is nearly empty any new runs will be Cat6.
Ken.F is offline
post #4904 of 4909 Old 03-11-2015, 04:12 PM
Ken.F's Avatar
Quoted: 405 Post(s)
Liked: 411
Originally Posted by Ken.F View Post
HDHR Prime is on sale for $100 at Newegg right now.
HDHR Prime is on sale for $90 at Woot for the next 6 hours.
http://www.woot.com/offers/silicondu...me-3-tuners-17
Ken.F is offline
post #4905 of 4909 Old 03-11-2015, 04:14 PM
Liked: 0
Interesting.........so......it feels like its 50-50 of between wifi and powerline network.
post #4906 of 4909 Old 03-11-2015, 04:19 PM
mdavej's Avatar
Liked: 578
Since everybody has advised against wifi, I'm not feeling 50-50 ;-)
mdavej is offline
post #4907 of 4909 Old 03-11-2015, 04:37 PM
Liked: 0
hahaha.
post #4908 of 4909 Old 03-25-2015, 07:31 PM
leewcraft's Avatar
I thought I'd point out this thread here since Ceton owners may be interested. I'm working on an add-in for a multi-view app in Windows Media Center for multiple channels on one screen. I find it particularly useful for sports, but others have mentioned news/weather as another application for it. Take a look if you're interested.
Sports Bar - New Windows Media Center add-in
leewcraft is offline
post #4909 of 4909 Unread Today, 10:17 AM
dbailey75's Avatar
Quoted: 41 Post(s)
Liked: 44
interesting, so what it is actually doing is recording the channels with in MCE, and then your using a 3rd party player of sorts to play back those recordings at the same time with a few seconds delay, sounds like very interesting way to make this work. To do this with 4 channels, the HDD activity must be crazy. I'll waiting until you get a littler further along, but sounds like your definitely on to something.
PSN: CAPTDANMAN
dbailey75 is online now
Reply Home Theater Computers
