Latest Ceton InfiniTV 4 Info Thread - Page 165 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #4921 of 4937 Old 08-18-2015, 12:47 PM
LowTech1's Avatar
Quoted: 351 Post(s)
Liked: 130
Why is my InfinityTV 4 all of the sudden DRVing duplicates of the same show? If its on more than one channel it will DVR it. Also,I set a certain station to record the series. Its on at 9 & 12am. It used to DVR the 9pm show and had no problems,all of the sudden it won't record the 9pm show unless I manually tell it to. It now records the 12am show instead with is driving me nuts. Doesn't anyone know why it does this? Or is this a WMC deal?
LowTech1 is online now
post #4922 of 4937 Old 08-18-2015, 12:55 PM
Ken.F's Avatar
Quoted: 750 Post(s)
Liked: 675
It's a WMC deal. The tuner doesn't have any say in what gets recorded, it only tunes what WMC (or other programs) tell it to.
The problem is likely caused by the WMC guide data provider being switched to Rovi.
Ken.F is offline
post #4923 of 4937 Old 08-18-2015, 12:58 PM
smcmillan2's Avatar
Quoted: 351 Post(s)
Liked: 207
Because it's being told to.
Yes, lots of issues since the Rovi changeover. See
http://www.thegreenbutton.tv/forums/...php?f=5&t=8908
http://www.thegreenbutton.tv/forums/...php?f=5&t=9026
http://www.thegreenbutton.tv/forums/...php?f=5&t=8903
smcmillan2 is online now
post #4924 of 4937 Old 08-18-2015, 01:12 PM
LowTech1's Avatar
Quoted: 351 Post(s)
Liked: 130
What the h*ll is Rovi?
post #4925 of 4937 Old 08-18-2015, 01:29 PM
mdavej's Avatar
Quoted: 1416 Post(s)
Liked: 705
Bottom link in previous post.
Guide used to come from a company called Zap2It (also provides guide data to Tivo). Now it comes from Rovi (TVGuide) and is screwed up on many levels.
mdavej is offline
post #4926 of 4937 Old 08-18-2015, 02:04 PM
LowTech1's Avatar
Quoted: 351 Post(s)
Liked: 130
So did Rovi buy zap2it or what is the deal? I was wondering my my guide was messed up and why some shows were dvr twice. Very irritating!
post #4927 of 4937 Old 08-18-2015, 03:13 PM
smcmillan2's Avatar
Quoted: 351 Post(s)
Liked: 207
No, MS switched to Rovi
http://lmgtfy.com/?q=windows+media+center+rovi
2nd hit
post #4928 of 4937 Old 08-18-2015, 03:21 PM
Super Moderator
DrDon's Avatar
Quoted: 277 Post(s)
Liked: 488
The change is driving a lot of us nuts. Until last week, I couldn't get a daily-scheduled program to record. Weeklies were fine. Manual was fine. Daily shows.. nope. Still getting a good number of duplicate recordings, but haven't sat down to discern a pattern.
There's a thread all about it elsewhere in HTPC.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #4929 of 4937 Old 08-18-2015, 05:19 PM
talljerry's Avatar
how can I get ceton infinitv to work on windows 10?
talljerry is offline
post #4930 of 4937 Old 08-18-2015, 06:59 PM
mdavej's Avatar
Liked: 705
Just about anything should work, except WMC obviously. I've used VLC and RTP protocol for live TV (not very convenient). Here's a pretty complete list:
https://en.wikipedia.org/wiki/Compar...tware_packages
I'm curious though, why were you compelled to "upgrade" to Win 10 knowing you'd lose the best DVR software by far? Are the live tiles in the start menu more entertaining than TV?
smcmillan2 likes this.
mdavej is offline
post #4931 of 4937 Old 08-18-2015, 08:16 PM
LowTech1's Avatar
Quoted: 351 Post(s)
Liked: 130
I wonder why Microsoft changed companies? Why fix something that isn't broken..
post #4932 of 4937 Old 08-19-2015, 05:23 AM
dbailey75's Avatar
Quoted: 52 Post(s)
Liked: 46
Guess we can't blame ballmer for this one, or maybe we can, should have negotiated a longer contract with zap2it.
My guess is cost, they found a lower cost provider, and we see why the cost is lower, wrong tag, wrong images, blah, blah. they have roughly 3 week before the fall season premiers to get it all sorted out, otherwise, I might be in trouble with the wife.
PSN: CAPTDANMAN
dbailey75 is offline
post #4933 of 4937 Old 08-19-2015, 06:36 AM
mdavej's Avatar
Liked: 705
Xbox One uses Rovi. Consolidation.
DrDon and htpcforever like this.
mdavej is offline
post #4934 of 4937 Old 08-19-2015, 10:56 AM
Super Moderator
DrDon's Avatar
Quoted: 277 Post(s)
Liked: 488
First, it's easy to figure out if it's going to screw up. For a series recording, check the guide before primetime. You'll see the familiar red ball with ghosts if the series recording is going to happen. If you don't see it, go into "scheduled recordings" and look. Odds are, it won't show up there, either. Click on "series" and find the program. Delete the series entry and try setting it up, again. BETTER STILL: Skip the guide and set up a Manual Recording. Time and channel. Those don't fail.
Even if you DO have a successful series recording, I highly recommend editing the Series settings to include new + repeats. Seems the "new" tag doesn't get successfully set, though I've had daily series recordings set for new + repeats still fail.
Best to check on it frequently until this gets sorted out.
DrDon is offline
post #4935 of 4937 Old 08-19-2015, 11:59 AM
LowTech1's Avatar
Quoted: 351 Post(s)
Liked: 130
Another thing I've run across is when it DVR's a show for like 3 mins. Did that last night. Most of my stuff is ok tho.
post #4936 of 4937 Old 08-20-2015, 06:17 AM
dbailey75's Avatar
Quoted: 52 Post(s)
Liked: 46
I did a rebuild after the season finales on my primary recording HTPC, still haven't finished all the tweaks, aka, time sync event etc. Going to set aside some time in the next week or so to make sure all that's done and all the series recordings are loaded back up. I plan to take your advice on including new and repeats.
Figure the divorce layers are going to busy enough with the Ashley Madison leaks, that I'll have to live with a grumpy wife indefinitely if her show's don't get recorded.
PSN: CAPTDANMAN
post #4937 of 4937 Old 08-31-2015, 12:52 PM
johnstonk's Avatar
Quoted: 13 Post(s)
I have fought this long enough, my wife wanted an easier DVR and I went back to local Cable Co. DVR.
johnstonk is offline
Reply Home Theater Computers
