mini HTPC build (Habey EMC-800B, i3-2100T, SSD, etc.) - KEEPING IT SIMPLE - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 364 Old 07-26-2012, 01:00 PM
zoson's Avatar
Can anyone weigh in on if the habey internal psu will work fine with an 18v supply instead of 12v? the price difference on 12v 10a bricks vs 18v 6.5a is huge... Habey doesn't list the input spec for the supply. frown.gif
I sent an email to habeyusa's contact info and asked for the input spec. I'll post back here if I get a response!
zoson is offline
post #362 of 364 Old 07-26-2012, 02:51 PM
zoson's Avatar
Andres Morales andres.morales@habeyusa.com:
It is 12V only.
We bundled it with 60W brick because most of the boards use with this case
are low power Atom based.
Thanks you,
Andres Morales
Technical Support
HABEY USA
Looks like the 18v adapter listed by the assassin guy will not work(or at least is not supported and thus voids your warranty) with the stock habey psu... sadness.
zoson is offline
post #363 of 364 Old 07-26-2012, 03:27 PM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
The DC powerboard in the Habey is either this one (EMC600): http://www.minicase.net/product_LR1005-120W12VDC.html or this one (EMC800): http://www.minicase.net/product_LR1005-120W12VDC-Q.html. Those pages have the full specs.
StardogChampion is offline
post #364 of 364 Old 07-27-2012, 09:10 AM
rsoares28's Avatar
Quoted: 110 Post(s)
Liked: 26
The 18v won't work with the stock psu but it will work with the 120wide pico
rsoares28 is offline
Reply Home Theater Computers
