Lav Madvr guide?? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
Old 06-04-2011, 07:01 PM
riverhawk79's Avatar
Originally Posted by Tong Chia View Post
Start simple. Softcubic on MadVR produces a pleasing image and there
is a sharpness knob you can play with. After that substitute the chroma
scaling and see what you like.
Catmull-Rom, Mitchell-Netravali and Spline is one group and
Lanczos is the other with cubic in the middle.
The Chronicles of Riddick is a good movie to experiment with the effects
of the various algorithms that MadVR provides.
Luminance and Chrominance are vastly different creatures. The former
is the reference intensity of one of the primary color signals and chrominance
is a pair of values containing the relative intensities of the other
2 primary colors, the color difference signal.
In simple terms the Luma channel needs a good 1D reconstruction filter and
chroma needs one that works well in 2D. Mitchell-Netravali and
its derivitive Catmull-Rom was originally designed as a 2D image reconstruction filters
If you are interested in how the information is encoded in video look
at the link below.
http://en.wikipedia.org/wiki/YUV
What calibration hardware/software did you use to generate your 3dlut?
riverhawk79 is offline
Old 06-04-2011, 08:08 PM
Tong Chia's Avatar
You will need yCms to generate the 3d LUT table
http://forum.doom9.org/showthread.php?t=154719
Put the generated files in the madVR directory
Tong Chia is offline
Old 06-04-2011, 08:56 PM
nightfly85's Avatar
Quoted: 71 Post(s)
Liked: 41
I have a issue with MadVR and video levels. Setting MadVR to output 0-255 (and using custom Nvidia resolution) I get black crush in exclusive full screen mode. In windowed mode video levels are correct. Disabled exclusive fullscreen mode and video levels match between fullscreen and windowed mode.
MadVR .61
LavCUVID .7
LAV Splitter/Audio .28
MPC-HC .3018
ReClock
nightfly85 is offline
Old 06-04-2011, 10:50 PM
Tong Chia's Avatar
MadVR .61
LavCUVID .7
MPC-HC .3018
ReClock
Is exclusive mode running at the same resolution and refresh rate as windowed mode, if not you might have to define a custom resolution for
exclusive mode as well.
Best to check what your TV says and not rely on Windows.
This problem with Nvidia's driver is pretty tiresome.
Your version of MPC-HC is also getting old. .3177 is the current version,
MadVR seems to work better with the later versions.
Old 06-05-2011, 05:16 AM
Eiffel's Avatar
Quoted: 13 Post(s)
Just a quick question, why not use Lanczos or Spline for Luma sampling in MadVR?
Eiffel is offline
Old 06-05-2011, 06:12 AM
balky's Avatar
Quoted: 228 Post(s)
Liked: 132
Originally Posted by Rico66 View Post
Is there anything special that I need to do to get subtitles working when using madvr? On a recent blu ray (native, no rip) I noticed that the subtitles would not show up. This wasn't using lavsplitter, lav audio, and MPC for video. When I switched the renderer to EVR instead the subtitles would display as expected.
I'm just getting to try this out on my test PC with a NVIDIA 8600GT...
The image quality with madVR (+ LAVCUVID) is freaking awesome...
The only current issue is that the subtitile option is greyed out in MPC-HC while using madVR, but subtitles work well with EVR.
I am using the latest LAV, latest MPC-HC tryout, but on vista 32 bit.
Can the subtitile problem be due to vista?
My main HTPC runs win7 with a GTX460... will try setting it up there after Roland Garros is finished today...
In the meanwhile, if anyone has subtitles working with madVR kindly share your settings
balky is online now
Old 06-05-2011, 06:33 AM
joeydrunk's Avatar
Quoted: 14 Post(s)
I'm Sure it will work better with the gtx460, the 8600gt only has like 15 stream processors compared to like 330.
joeydrunk is offline
Old 06-05-2011, 08:19 AM
SamuriHL's Avatar
Well this is a fun thread! Tong Chia, thank you for the invaluable information. I just generated 3DLUT tables for my main HTPC. Remarkable. I'm using MC16 with madVR. Man what an awesome combination.
SamuriHL is offline
Old 06-05-2011, 11:15 AM
jbcain's Avatar
Liked: 64
so after uninstall lav, mpc 64, 32, and reinstalling lav, mpc32, madvr (finally), now 32bit cuvid will not register. (i unpacked it to a folder labeled "lav" in the root directory of C:
C:\\LAV>cd /d "C:\\LAV\\"
C:\\LAV>regsvr32.exe LAVCUVID.ax
C:\\LAV>
I get an error about:
module failed to load. make sure the binary is stored in the specific location.
any ideas?
jbcain is offline
Old 06-05-2011, 11:19 AM
SamuriHL's Avatar
Make sure you get the latest cuvid. It doesn't require the MSVC runtime. Also, madVR 0.62 just came out and has HUGE changes that will affect this crowd. Please go check it out ASAP.
SamuriHL is offline
Old 06-05-2011, 11:28 AM
jbcain's Avatar
Liked: 64
downloaded lavcuvid .7. looks like th latest release.
jbcain is offline
Old 06-05-2011, 11:31 AM
balky's Avatar
Quoted: 228 Post(s)
Liked: 132
Since installing my GTX460 last November, I never got anything so thrilling out of it 2D wise.
The only issue I'm left with now is subtitle related... I just can't get sutitles to work.
I am wondering if anyone is using the LAV-LAVCUVID-madVR combination in 7MC... is it possible at all?
Anybody got subtitles working?
In MPC-HC, I get a pop up window telling me that I have to switch renderer to EVR, VMR9 et al if I want subtitles. I guess something still needs to be done in madVR for subtitles to work.
Anyone got suggestions?
balky is online now
SamuriHL's Avatar
Nope. LAV CUVID 0.8 was released this morning.
SamuriHL is offline
Old 06-05-2011, 11:32 AM
SamuriHL's Avatar
You won't with just that. You need something that displays subs in the chain. You don't have that. You can add ffdshow raw video decoder to that chain and it should work. That's what I use.
SamuriHL is offline
Old 06-05-2011, 11:45 AM
jbcain's Avatar
Liked: 64
figured the installer would fic the issue.. but (ran as adminstrator)
jbcain is offline
Old 06-05-2011, 11:49 AM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
To deal with subtitles you could also download and register vsfilter.dll from MPC-HC standalone filters (here).
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
Old 06-05-2011, 11:54 AM
jbcain's Avatar
Liked: 64
considering cuvid is ONLY for nvidia, yes, i have a 550ti
jbcain is offline
Old 06-05-2011, 11:57 AM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Sorry, I saw it on first page and deleted my post. Anyway, try unregistering it (e.g with Graphstudio) first, then install it.
Tulli is offline
Old 06-05-2011, 11:58 AM
SamuriHL's Avatar
Yikes. I've not seen that issue. You might want to post that in the LAV CUVID thread on Doom9 and see if Nev has any ideas. (Try Tulli's idea first)
SamuriHL is offline
Old 06-05-2011, 12:02 PM
byronmhome's Avatar
I only have ati cards right now and i culdn't get decent frame rate on anything less than 120 stream processors.. does madvr do something unique to handle lower sp count on nvidia?
byronmhome is offline
jbcain's Avatar
Liked: 64
did the unregister via graph studio, same issue.
jbcain is offline
Old 06-05-2011, 12:04 PM
SamuriHL's Avatar
Then I would see if Nevcairiel has any ideas on the LAV CUVID thread. I don't know what could be causing it.
SamuriHL is offline
Old 06-05-2011, 12:14 PM
jbcain's Avatar
Liked: 64
can't post on doom9 until i've been registered 5 days.
jbcain is offline
Old 06-05-2011, 12:24 PM
SamuriHL's Avatar
You could attempt to PM him on here and see if he has any thoughts.
SamuriHL is offline
Old 06-05-2011, 12:25 PM
jbcain's Avatar
Liked: 64
im reloadin win7 64 from scratch
jbcain is offline
Old 06-05-2011, 12:26 PM
assassin's Avatar
Quoted: 81 Post(s)
Liked: 242
He doesn't answer PMs and he is very blunt.
He might help but he wants specifics.
And when I say specifics I mean S-P-E-C-I-F-I-C-S if you know what I mean.
assassin is offline
Old 06-05-2011, 12:35 PM
SamuriHL's Avatar
Well, he is a busy man.
SamuriHL is offline
Old 06-05-2011, 12:37 PM
balky's Avatar
Quoted: 228 Post(s)
Liked: 132
But how do you add the ffdshow raw audio decoder in the chain?
I have enabled raw video support in ffdshow and added it to the list of filters in MPC-HC, but it still doesn't work
I also registered vsfilter and subtitles don't work either.
All of this is in MPC-HC 3177.
balky is online now
Old 06-05-2011, 12:42 PM
SamuriHL's Avatar
Raw video decoder. Add it to the preferred list in the external filters screen. Open up the properties and make sure it's set to use subtitles. But, if you're using MPC-HC, I would just use MPC's subtitle renderer as the later versions work with madVR. I use ffdshow raw video decoder because I use a different player.
SamuriHL is offline
Old 06-05-2011, 12:43 PM
assassin's Avatar
Quoted: 81 Post(s)
Liked: 242
So am I. Trust me.
You have no idea what my day job is.
assassin is offline
