Lav Madvr guide?? - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 582 Old 06-05-2011, 11:44 AM
SamuriHL's Avatar
Originally Posted by assassin View Post
So am I. Trust me.
You have no idea what my day job is.
I have similar issues. I tend to work 12 hour days most days, but, I'm lucky in that most days I can work from home.
SamuriHL is offline
post #92 of 582 Old 06-05-2011, 12:01 PM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Originally Posted by balky View Post
But how do you add the ffdshow raw audio decoder in the chain?
I have enabled raw video support in ffdshow and added it to the list of filters in MPC-HC, but it still doesn't work
I also registered vsfilter and subtitles don't work either.
All of this is in MPC-HC 3177.
Launch MPC-HC->Options->External Filters, select DirectVobSub and set it to prefer. When playing back right click over the MPC-HC windows, select Filters and check thatf DirectVobSub is there. Select your subititle, it should show up (or set MPC-HC to automatically load subtitles by going to options->Playback and tick "auto-load subtitles").
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
post #93 of 582 Old 06-05-2011, 12:22 PM
byronmhome's Avatar
Originally Posted by SamuriHL View Post
Well, he is a busy man.
Busy playing WoW.. but i guess that is still busy
I wish i had his free time to be honest.. he's committing code on so many projects its not even funny! More power to him though.. lol
byronmhome is offline
post #94 of 582 Old 06-05-2011, 12:23 PM
jbcain's Avatar
Liked: 64
fresh win7 64 install did the trick. blew right through the installs
jbcain is offline
post #95 of 582 Old 06-05-2011, 12:33 PM
balky's Avatar
Quoted: 252 Post(s)
Liked: 170
Thanks Tulli,
I did both and it still doesn't work...
I changed vobsub from v2.3 to 2.4... no go...
This thing is killing me...
balky is offline
post #96 of 582 Old 06-05-2011, 12:44 PM
jbcain's Avatar
Liked: 64
woooooooooooow, you guys were NOT joking. madvr + lav + mpchc is beautiful!
jbcain is offline
post #97 of 582 Old 06-05-2011, 12:45 PM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Thanks Tulli,
No, not vobsub but the directvobsub standalone MPC-HC filter (vsfilter.dll). But it should work without needing to register it (as it's native to MPC-HC): uninstall vobsub and just set MPC-HC to auto-load subtitles. It should work right away.
Tulli is offline
post #98 of 582 Old 06-05-2011, 12:51 PM
Tong Chia's Avatar
Originally Posted by Eiffel View Post
Just a quick question, why not use Lanczos or Spline for Luma sampling in MadVR?
You could. Lanczos with 2 lobes is about equivalent to Catmull-Rom.
Increasing the number of lobes improves the color definition at the expense
of re-introducing color banding.
Spline produces softer results. Catmull-Rom is an improved spline filter.
The other downside of Lanczos it is much more computationally intensive
ie takes more time, which may be important in a reatime application like MadVR
depending of what else is going on in the render chain eg Frame Interpolation,
other post processing filters such as AVI synth and ffdshow postprocessing
Tong Chia is offline
post #99 of 582 Old 06-05-2011, 12:56 PM
assassin's Avatar
Quoted: 167 Post(s)
Liked: 270
Glad you got it. I knew you would like it.
assassin is online now
post #100 of 582 Old 06-05-2011, 01:02 PM
Tong Chia's Avatar
Thanks Tulli,
What is the exact version of MPC-HC you are using ?
post #101 of 582 Old 06-05-2011, 01:14 PM
Tong Chia's Avatar
As a next step, try the 3D Lookup table (3DLUT).
It is 4 text files of 100Mb each generated using yCMS.
If you want to do this add the files before enabling 3DLUT on MadVR otherwise
both it and MPC-HC run into trouble
post #102 of 582 Old 06-05-2011, 01:19 PM
jbcain's Avatar
Liked: 64
you lost me there bud. No idea what you're talking about . only thing i know about 3d is i use tmt5 to dump 3d to my 3d tv
jbcain is offline
post #103 of 582 Old 06-05-2011, 01:42 PM
Tong Chia's Avatar
It is a color correction and calibration feature, nothing to do with 3D images.
post #104 of 582 Old 06-05-2011, 02:15 PM
nightfly85's Avatar
Quoted: 72 Post(s)
Liked: 43
Why not use LAV Splitter? It has great sub title support.
You can just select the sub you want to display or setup automatic display. I use it to auto display only forced English subs. It'll pull forced subs from dedicated tracks or from matching tracks that contain subs marked as forced.
nightfly85 is offline
post #105 of 582 Old 06-05-2011, 02:17 PM
Eiffel's Avatar
Quoted: 13 Post(s)
Thanks for the clear explanation... clearly I have some more experimenting to do, as I liked the result I got with spline
Eiffel is offline
post #106 of 582 Old 06-05-2011, 02:47 PM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
I thought it was a "splitter", i.e. a demuxer of video, audio and subs streams. Does it include a subs directshow filter too? With MC16, for instance, I can't get subs if I don't add directvobsub DS filter to the chain. And with MPC-HC there's the internal directvobsub filter too in the chain.
Tulli is offline
post #107 of 582 Old 06-05-2011, 03:03 PM
jbcain's Avatar
Liked: 64
ya you're definately way beyond me in this field i'm just happy to see video play ha!
jbcain is offline
post #108 of 582 Old 06-05-2011, 03:06 PM
Tong Chia's Avatar
That's the bottom line. Enjoy
post #109 of 582 Old 06-05-2011, 03:09 PM
Tong Chia's Avatar
That's interesting. I use MC16 as well and get the subs without directvobsub.
MC16 has to told to force enable the subs and the auto selection option that is
there is not too smart
post #110 of 582 Old 06-05-2011, 03:14 PM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
So the LAV Splitter includes a subs DS filter?
EDIT:
Unchecked Directvobsub (only sub DS filter in my system) and get no subtitles in MC16. The option "Mode: Show subtitle in selected language if available" is checked.
Also "Playback method" is not set to automatic, so that I manually specify the DS filters required in the chain.
Tulli is offline
post #111 of 582 Old 06-05-2011, 03:22 PM
Tong Chia's Avatar
Not to my knowledge. It is in the Jriver video engine.
Lav splits out the raw sub stream and feeds it to the renderer
Subs not appearing is usually a broken connection or a format the renderer does not understand.
The only way to be sure is take a look with Graphstudio when the thing is running and see if a subtitle processing module such as
directvobsub needs to be connected.
post #112 of 582 Old 06-05-2011, 03:29 PM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Yeah, Graphstudio automatically invokes Directvobsub as it should.
You surely have the latest MC16 beta (with "Red October", I think so it's called), right? That should explain why it's working for you.
Tulli is offline
post #113 of 582 Old 06-05-2011, 03:58 PM
joeydrunk's Avatar
Quoted: 14 Post(s)
downloaded lavcuvid .7. looks like th latest release.
Get the installable version instead of the zip. And/or open as administrator, I think that will get rid of the error message
joeydrunk is offline
post #114 of 582 Old 06-05-2011, 04:36 PM
Tong Chia's Avatar
I am using 16.0.103. Might be a Beta but it does not say so on the help screen.
Yes Red October appears as an option. DirectVOBSub does not appear
in the list of active filters when playing but it is installed on the PC
This is according to MC16. have not checked on Graphstudio.
Given your comments it has to be running otherwise there will
be no subs.
post #115 of 582 Old 06-05-2011, 04:38 PM
SamuriHL's Avatar
It's not beta. And I think they added DirectVOBSub to the white list, so, it SHOULD show up. If not, it may be a bug.
SamuriHL is offline
post #116 of 582 Old 06-05-2011, 04:50 PM
Tulli's Avatar
Quoted: 118 Post(s)
Liked: 103
Well, just for the record I'm on 16.0.87, but when I check for updates it says that I'm up to date. That's why I thought .103 was a beta ...
Tulli is offline
post #117 of 582 Old 06-05-2011, 10:58 PM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
I haven't been playing for month now.
He doesn't answer PMs and he is very blunt.
He might help but he wants specifics.
And when I say specifics I mean S-P-E-C-I-F-I-C-S if you know what I mean.
I answer PMs when i see a use in answering them. If someone PMs me just to say how great he thinks LAV is, well, good for them, but nothing i really care to comment on. If someone has real questions, they are better off asking in a public thread anyway, not only that someone else might also be able to answer them, but if i answer, other people also see it, and that may avoid double questions.
And yes, i'm developer, i'm not in user support. A support person may be willing to ask you loads of follow-up questions to get to the bottom of the problem, but they only do it because they get paid to do it, no-one is happy doing first-level support.
I explained that before, this is my free time, and i do with it as i please, and hand-holding people through the install process is not something i want to spend my free time on, because then i wouldn't get any new work done.
If it makes you happier, i could just behave like most developers, hide in a dark room and just develop, not talking to the users at all.
PS:
The issue that guy had was most likely a too old NVIDIA driver. 0.8 requires a 270 series driver. There is a special build of 0.8 for older drivers, if you for some reason are unwilling to update (which i do not see a really good reason for, these are not ATI drivers)
Nevcairiel is offline
post #118 of 582 Old 06-06-2011, 05:44 AM
SamuriHL's Avatar
Originally Posted by Nevcairiel View Post
PS:
Ah darnit! I should have thought about that. I make the assumption that everyone always uses the latest drivers when in fact I know they don't. sigh.
SamuriHL is offline
post #119 of 582 Old 06-06-2011, 06:09 AM
jbcain's Avatar
Liked: 64
that WAS probly the case. the reason for running older nvidia drivers is cause the newest ones break tmt5 auto fullscreen playback in 3d. this htpc stuff is a fine balance of what you want to be "broken" so something else can work fine
jbcain is offline
post #120 of 582 Old 06-06-2011, 06:11 AM
SamuriHL's Avatar
I haven't had any issue with that.
SamuriHL is offline
Reply Home Theater Computers
