Windows Media Center 7 dual tuner CPU maxing - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 06-03-2011, 02:23 AM - Thread Starter
drdeathly's Avatar
I built a Windows 7 Media Center HTPC with a dual HD tuner card (avermedia).
processor: Intel Celeron E3300 2.5ghz
ram: 2gig
mobo: gigabyte G31 based mATX
HDD: 64gb Patriot SSD for boot and 1tb green drive for data
graphics: ati 5450 fanless
System runs great except when I'm recording two OTA HD shows at once with WMC then it maxes out the CPU (both cores) completely - 100% and I get errors in the recordings.
My understanding is that this CPU should be more than capable to handle the workload of recording two shows, but that's not turning out to be the case. I've wondered if there isn't some other bottleneck. Could the motherboard be underclocking the CPU for power saving or heat? I keep the side off the case and the door to the cabinet open so it can get enough ventilation.
Thanks for your help,
DrD
drdeathly is offline
post #2 of 12 Old 06-03-2011, 06:28 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
What codecs are you using?
Sammy2 is offline
post #3 of 12 Old 06-03-2011, 08:17 AM
jrwalte's Avatar
It's possible the WMC WTV container requires more processing then the built-in aver software, which recommends a p4 2.4 with hyperthreading. Your CPU is missing hyperthreading, which could be the difference, even though it has 2 cores.
But my C2D e8400 only uses about 5% CPU when recording per tuner with an Aver A188, which should be the same tuner as yours, and I don't think the e8400 is that much better than the celeron E3300.
What process is maxing out the CPU when recording? What does the task manager/resource monitor say EHREC is using while recording?
jrwalte is offline
post #4 of 12 Old 06-03-2011, 09:49 AM - Thread Starter
drdeathly's Avatar
I have shark007's codec pack installed.
post #5 of 12 Old 06-03-2011, 10:00 AM
ilovejedd's Avatar
Quoted: 76 Post(s)
Liked: 67
I've got an E3300 and I had no issues recording four (4) OTA HD streams at the same time (when HDD is relatively empty and defragmented, that is). Speaking from experience, a Pentium 4 2.4 GHz even with HyperThreading is far slower than a Celeron E3300 2.5 GHz. Heck, it's still slower than the E3300 with one core disabled. I've also had no issues recording 4 HD streams at the same time on an Atom 330. Recording storage partition is formatted with 64K sectors/allocation units and using the HDHomeRun for tuners.
ilovejedd is offline
post #6 of 12 Old 06-03-2011, 01:47 PM
user4avsforum's Avatar
I have a Core 2 5400 with 2 Avermedia duets plus a capture card for the satellite. And I can record 5 shows concurrently onto a WD green drive with no issues.
Also have a Core i3 540 with a one Duet card and can record two shows onto a 2.5" notebook drive with no issues.
Maybe you have a driver problem or NCQ/AHCI is not enabled.
user4avsforum is offline
post #7 of 12 Old 06-03-2011, 02:00 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Are you using it with the alternate video decoder? That caused issues for me with recording two shows or watching a show and recording another simultaneously. LAV cleaned things up, even for playback of stuff recorded with Shark.
Sammy2 is offline
post #8 of 12 Old 06-03-2011, 03:25 PM - Thread Starter
drdeathly's Avatar
What is LAV?
post #9 of 12 Old 06-03-2011, 03:57 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Do a search at the top for LAV. There's at least three current threads about LAV.
Sammy2 is offline
post #10 of 12 Old 06-03-2011, 07:46 PM - Thread Starter
drdeathly's Avatar
Your setup sounds pretty close to mine, so clearly something is wrong. I think I'm going to do a clean install of Win7 and see if that corrects the problem. Perhaps the Shark007 codec pack has messed something up, or one of the WMC add-ons I installed.
post #11 of 12 Old 06-03-2011, 11:53 PM - Thread Starter
drdeathly's Avatar
Uninstalled DMNSToolbox and Shark007 codecs. Restarted. Installed LAV. Recorded 2 HD shows simultaneously, processor load varied from <10% to 100%, but only hit 100% a couple of times, and mostly it hovered around 25-30%. Much better.
Thanks for your help!
DrD
post #12 of 12 Old 06-04-2011, 07:24 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Nice.
Sammy2 is offline
Reply Home Theater Computers
